Tolerance for tire width?
Quoted: 14 Post(s)
I am replacing a tire that is 700x23c. I can't tell from the wheel what the size spec is, so I am going from the previous tire. The store only has a 700x25c in stock, and the guy tells me such a small change in width won't matter.
Is he right, or just trying to sell me a tire?
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
He's right. Note, you'll inflate the 25s to a sightly lower pressure than the 23s.
And you will get much more comf when riding it
Quoted: 14 Post(s)
Thanks. The specs on the box do say that the pressure for 700x23c is 110 psi. Oddly most of the other sizes, smaller and larger, are 95.
I'm not really after comfort. I'm not a competitive rider but I've been riding on 115 psi just fine for years.
Quoted: 4404 Post(s)
Liked 4,856 Times
Is that 110 psi recommendation for your weight or just a generic figure for all?
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
How much clearance do you have now and what is the inside with of your wheels. The 25mm tires may rubb.
I had a Madone 5.0 and upgraded to carbon wheel with inside width of 19.5mm. The old 14mm inside width rims worked with both 23 and 25mm tires. Even GP4000. Not so with the 19.5mm wheel. Opened the tires up. The 25mm tire rubbed on the chainstay in back and the fork crown up front. Newer bikes tend to have more clearance.
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,993 Times
Generally I recommend going as wide as possible so if your frame has clearance go for a wider tire, You will thank me and the person who sold you the tires. Wider is better up to a point. Certain bikes are for racing or are quite old school and have limited tire clearance (Clarence) but generally 23-25 isn't so bad and will likely fit unless you have a bike designed purely for racing that is older. A lot of Keirin bikes have almost no clearance nor do they need it for track racing where everything must be the same.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Pressure is based on rider+bike weight and tire size. 115psi is ridiculous. Period. If you 'need' that pressure what you really need is bigger tires.
Likes For cxwrench:
Quoted: 18375 Post(s)
Liked 4,510 Times
It will really depend on the bike. My Funny Bike really doesn't like anything wider than 23mm. I suppose I can fit 25mm in, but it will be awfully tight.
I've heard of quite a few bikes from around 2000 to 2010 that did better with 23mm (TT, Tri, etc).
Quoted: 532 Post(s)
Liked 621 Times
Use this calculator to get the right pressure for any width tire, as measured.
And, wider is more comfortable, because wider means more volume, and can be run at lower pressures which means the carcass can flex a bit more. 25s won't be plush, but they'll be slightly more compliant than 23s.
Quoted: 14 Post(s)
I don't "need" that pressure. It's the recommended pressure for my tires, which show a max inflation of 160. And what would bigger tires do for me?
Quoted: 14 Post(s)
The internet has a store with more sizes than just that one.
While it's true that fatter tires feel more "comfy," for many people, that's not always the case. However, you usually can't go wrong with 25c on a road bike, as long as it's a good quality tire and not el cheapo.
Quoted: 5224 Post(s)
Liked 3,581 Times
fwiw - past several years, I've been running my fronts approx. 10 psi lower (less diff. w/ the MTB). for example at my last pumping of the road bike I went to 100 rear 90 front. but since they burp when I take the chuck off they are closer to 90/80. these are 25mm tires & I'm approx 225lbs +bike, etc
Quoted: 14 Post(s)
That spec is somewhere between a guess and wish.
Use this calculator [link removed, not allowed for new poster] to get the right pressure for any width tire, as measured.
If the carcass is flexing more, doesn't that increase rolling resistance? Comfort is not really an issue.
Quoted: 1074 Post(s)
Liked 295 Times
And let’s not forget the influence off the surface you ride on.
If you have infinitely hard tires, then anything you hit, you have to roll up-and-over. And that upwards motion steals some forward movement. A softer tire allows minor irregularities to sink into the tire instead, preserving forward motion better
Likes For dabac:
Quoted: 532 Post(s)
Liked 621 Times
As for comfort, I didn't;t know what I was missing until I tried it. I can remember the rides and the conversation clear as day that I had with a guy on Veterans Day, 2014....the topic of tire width came up, he told me he was on 25s, recommended it, I tried it the following week....today I roll on 27s (summer) or 30s (winter) on my road bikes, and 32s on my "rain bike", and I can assure you the comfort matters. I live in a land of busted roads, and some are still made with cobblestones. Unless you only ride on pristine, new tarmac....comfort matters and will make you faster.
Bikes: lots
Liked 2,932 Times
No, it doesn't...it actually improves it. As posted before a very hard tire will bounce off every little imperfection in the pavement. By definition that is rolling (or bouncing) resistance. Tires are the only suspension on a road bike, you have to let them do that job to a certain degree. There are no negatives to reducing pressure to a reasonable level. Why would you not want any of those things? How do you know comfort is not an issue if you've never tried it? You don't know til you know. And...why are you so worried about speed as a recreational rider? None of these things make sense. And of course, it's free to try. This has been such a hot topic for the last decade I can't imagine how stubborn you'd have to be to totally ignore it.
Likes For cxwrench:
Quoted: 6193 Post(s)
Liked 4,809 Times
My tires don't have any coarse aggregate to bounce off. They roll better at 125 PSI than they do with 90 PSI. My legs and data collected have told me so.
Bikes: lots
Liked 2,932 Times
If that is the most important thing to you...I don't know what to say. I can promise you that you have less traction and lower comfort at 125 than anything lower. And I'm pretty sure not every road you ride on is velodrome smooth...that doesn't happen in our country. No way. It doesn't have to be 'coarse aggregate'.
Likes For cxwrench:
Quoted: 1944 Post(s)
Liked 2,164 Times
You can look up your inflated widths online, bicyclerollingresistance.com, to see if it will fit.
I personally could care less what pressure you like, the only thing that is important is to make sure it will fit in your frame.
John
Liked 4,510 Times
The trick is to plan ahead on consumables, so you just have to grab the part out of the closet.
Likes For CliffordK:
Bikes: lots
Liked 2,932 Times
An entire week?!? Oh no...that's a tragedy.
Likes For cxwrench:
Should Be More Popular
Quoted: 22597 Post(s)
Liked 8,925 Times
Liked 4,856 Times
Back in the day when I was still running 23c tyres and you had to download websites to read them, I just ran them at 90 psi and that was a plenty harsh enough ride! Now I run 30c and 32c tubeless at around 60-70 psi. I weigh 175 lbs.
If you have clearance for 25c I would take those and experiment with lower pressure. Unless you weigh a lot more than me, 90 psi should be more than enough.
Quoted: 14 Post(s)
OK, thanks to everyone for your help. I decided to go with Continental Grand Prix 5000, and I found them on Amazon for Prime delivery for free tomorrow. (My regional bike shop stocks these for $80; I just ordered two for $100.) I'm sticking with 700x23. Based on other comments here I will probably roll the pressure down a bit, but as I said comfort has not been an issue.
I am not plugged into cycling discussions so I'm unaware of this as a hot topic, or what people are saying. All I know is my own experience. The hot topic I follow is whether round-wound or flat-wound strings are better, and what scale to play on a half-diminished 7th chord.
Yes, that's why I keep a couple of tubes on hand but now I will keep an extra tire, too.
Re: Weight, bike + me = 190 lbs.
Also: I found that I could not post more than 5 times in a 24-hour period so I had to wait to post this. Also I cannot post links or images yet.
