What tool do I need to unfasten my back wheel? (Photo)
Hello everyone,
I got a bike trailer and need to unfasten my back wheel to install the bike hitch. I would need some type of 3/16" Allen key with a hole in the middle to fit the pin. (As a new member, I can't post photos, but the image is on imgur at HCNbkql .) What is the name of this tool? Thanks.
Expired Member
Quoted: 3662 Post(s)
Liked 5,408 Times
I can't find the image but it sounds like some sort of locking skewer. There are various brands. Pitlock, Pinhead, etc. Google locking skewer and see if one looks like what you have.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4337 Post(s)
Liked 2,980 Times
Hello everyone,
https://imgur.com/gallery/HCNbkql
Fix that and then split it up and we can help with the photo... like this : http s://imgur. com/gallery/HCNbkql
Quoted: 18372 Post(s)
Liked 4,507 Times
@Blaq's Album:
https://www.bikeforums.net/g/user/543007
https://www.bikeforums.net/g/album/22081262
As expected, it looks like some kind of security skewer.
But, you're in luck that it is a basic 6-point allen wrench nut with the security hole.
Do you have the size from flat to flat?
Harbor Freight sells security bits (one set may be limited to 1/4"), as well as many auto parts stores.
I'd encourage you to have the tools to remove your wheel in case you need to do maintenance. You'll have to judge the security needs in your neighborhood and the way you use the bike.
Likes For CliffordK:
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
Or you can grab it with pliers & loosen it up, remove it & replace it with something more conventional.
Your local bike shop will have conventional skewers for sale. Usually around ~$20 a set.
Car dependency is a tax.
Bikes: Downtube IX NS&FS, Dahon Speed8Pro/Matrix/Curve, Brom S2L,Montague Para, ICE-XL w/Rollie/Schlumpf, Trident Spike, ebikes, BFSatRDay
Quoted: 172 Post(s)
Liked 95 Times
otherwise it would just be a cap nut, and not secure the wheel.
May need to destructively remove the security skewer. Other end looks. like what?
Oh I just hate those things. If I have to think like a thief, they have stolen a part of me.
Quoted: 836 Post(s)
Liked 1,061 Times
No need to destroy the axle to undo it. Either buy the proper security Allen wrench mentioned above to preserve the security feature or just stick a screwdriver in the head and lever it against the stud in the center to break it off and a standard Allen tool will work. Personally I would just buy the proper security wrenches which can also be used on all standard Allen heads.
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Hello everyone,
https://www.mcmaster.com/metric-allen-keys/system-of-measurement~metric/for-drive-style~tamper-resistant-hex/individual-set~set/driver-style~l-key/
Liked 4,507 Times
And the HF security bit set.
https://www.harborfreight.com/securi...-pc-68457.html
There are a few different styles that might work. You may need more torque than a screwdriver gives you. So, for example a 1/4" wrench.
Quoted: 1074 Post(s)
Liked 295 Times
Not always that easy. The black sleeve around the Allen head can spin, and need to be compressed hard enough against the Allen head to bring the Allen with it when you turn it.
