dahon folded bike on dirt paths
hiya, slightly worried now after my purchase of the 20" Vybe D7. I have always used my normal bike for slight off-road purposes, e.g. on foot paths, canal paths, woody paths... and i seem to have read somewhere about a Dahon rider who used his bike offroad. but i've just read my manual and it says there one should only use the bike on paved surfaces....
obviously, non-paved uneven surfaces will put a higher strain on the bike, but the Dahon comes supposedly with a frame that according to its manufacturers is virtually indestructable. So does this mean I would need to worry only about the wheels?
anyone has experience of off-road on your folding bike??? Advice greatly appreciated!
I would say my first concern would be the thin tires that are usually on these machines. The control might not be there.
Slight irregular ground on a ride every now an again should be okay if your worried about the hinges.
since it’s your bike the choice is yours to make. Let us know what you choose and how it goes!
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 264 Post(s)
Liked 239 Times
Depends of your weight. @68 to 70kg, I rode my Helios (and jetstream and smooth hound) on gravel path, jump curbs, muddy path etc. and it is fine. I have a monoblock TT handle post, Rear Kinetix Comp wheel (28 spokes) and Front Kinetix comp pro wheel (14 spokes) on kojak 35-406
Those bikes are rated for 105kg so with 50% safety factor, I am fine. I would admit that with 2% safety factor, I would not ride them as I do.
Quoted: 556 Post(s)
Liked 641 Times
That said, the wheels will simply wear out 2x more quickly.
Not the end of the world.
The failure mode will likely be with a broken spoke.
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
I routinely ride my folding bikes off-road, but all my bikes have steel frames. The bikes have too narrow tires for some sandy paths but then it is normal for life to be imperfect. When it makes no sense to insist on riding a given stretch, I just walk to save energy for other parts of the route. The steel frames have been chosen intentionally considering banging up of the bikes in transport, but presumably the steel helps in the off-road endurance too.
Dahon folded bike on dirt paths
hi Guys and thanks a lot for your input! Made me feel good - I don't think I have to worry TOOOO much then, just need to expect a few earlier part replacements and adjustments.
Palmer
Quoted: 1667 Post(s)
Liked 1,820 Times
