What Did You Do To Your Bike Today?
#128
I had been riding with a pedal that I had accidentally cross-threaded into my non-drive side crank arm for quite a while. It was really jammed in there, and was never going to be coming out again, so I finally got around to buying a new non-drive side crank arm and a new set of pedals which I kind of needed anyway as the pedals I had were pretty ancient. Installed the new crank arm and pedals without a hitch in only a few minutes.
#129
Quoted: 800 Post(s)
Liked 512 Times
After getting caught in the rain a few days ago I gave my bike a good wash and chain lube today. No photos so you'll have to take my word for it.
#131
Was having no end of trouble with the quick release for my seatpost recently - simply could not get it to hold the seatpost in place properly. Yesterday it came to a head with the aluminum lever snapping when I was trying to force it into position. So today I removed the quick release skewer from the clamp entirely and replaced it with a suitable nut and bolt that I was able to scrounge up. SO much better. My seatpost is now very firmly in the place I want it.
I did order a couple of cheapish seatpost clamps online as well (one with quick release, the other not) so if my bodged solution turns out to not work well, I can always install an entirely new clamp.
#134
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
So the Karate Monkey is basically done though I may try a really wide riser
#135
Thread Killer
Quoted: 3129 Post(s)
Liked 1,697 Times
I swapped out 35mm Herse file tread rubber in favor of 42mm Ultradynamico Rosé JFF tires in anticipation of the seasonal weather change. The weather in SE MI has been great and will probably remain pretty decent for awhile, but I had time today, have been off the bike/trainer for two weeks now, and have another week of appendectomy recovery before I’m clear to ride again, so it’s gonna be awhile before I’m out riding anyway, so it seemed a good call. I was also really eager to see what tan sidewalls looked like on this bike, so that pushed the agenda, too! Unfortunately, I cannot say I love the look, but I am looking forward to getting it out on gravel, mud, and snow this winter.
Likes For chaadster:
#136
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2565 Post(s)
Liked 5,595 Times
OMG an electric tandem - just like I predicted! What I would have given to get an extra boost with my wife on the back during 5-9% climbs. I see brake levers for the stoker which I find unusual since the pilot has a much better vantage point of when to apply the binders. Please explain.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
#137
Quoted: 680 Post(s)
Liked 947 Times
Likes For mschwett:
#139
Quoted: 383 Post(s)
Liked 690 Times
Since I can't seem to get to the last page other than coming without logging in!!!
re: Electric tandem. Within the last few months, friends got an electrified Bike Friday tandem and just returned from a trip on the bike trail from Pittsburgh to Cumberland (??) Md. And just today the stoker (she) said she wanted a rear brake from when the captain (he) let's it rip too much. And I, too, was interested in the stoker having a brake!
re: Varia, just yesterday, on my ride to Edmonds, my Edge stopped communicating with the Varia. I was almost lost with no radar. The light and radar obviously worked because the light would blink when cars approached. I did not mess during the ride since I did not want to potentially lose the data but I have to try pairing them again, I guess.
#140
Likes For The Chemist:
#141
Quoted: 680 Post(s)
Liked 947 Times
#142
Quoted: 383 Post(s)
Liked 690 Times
@fooferdoggie
"if you jsut put the garmin to sleep it will cause issues so turn it off once in awhile. sometimes you have to remove it and repair too. ANT+ lights can be finicky."
re: Varia - I've the radar/light combo. I occasionally get a prompt on the Edge: "Lights are not connected to the network" or something similar. Do the radar and the light have to be paired separately or it is one unit?
#143
Veteran, Pacifist
Quoted: 3897 Post(s)
Liked 4,825 Times
I should glue 4 (or more) tyres on wheels, but nice weather means a ride and yard work. Maybe tomorrow.
here’s a pic - but it still hasn’t happened.
Nice thing about a bunch of bikes is that deferred maintenance does not affect the ride schedule - which should be the priority. Or so it is assumed.
#145
Bikes: Trek Émonda SL 5, Trek Checkpoint SL 5, Giant Trance X 2, Trek Farley
Quoted: 73 Post(s)
Liked 94 Times
Ha! Today, I wiped most of the dirt off and then took it to the LBS to have the derailleurs adjusted (and, it turns out, to have the derailleur hanger straightened).
#146
Quoted: 680 Post(s)
Liked 947 Times
@fooferdoggie
#148
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 760 Post(s)
Liked 1,562 Times
For going on 2 months nearly every day on a ride I've said to myself, "I really need to get this FD properly adjusted." Going from the large chainring to the middle it would sometimes drop to the small, getting from the small to the middle sometimes would require additional 'trimming' to make the change, a tiny bit of rubbing in some gear combinations.... But then I'd get home from my ride and forget, or have other more pressing things to do. Finally pulled out the stand and spent some time with it this AM, then went out for a chilly, hilly fall ride. Geez, so nice not to really even have to think about my FD shifts. I should've just done it weeks (and weeks) ago.
#150
Grupetto Bob
Liked 5,595 Times
Didn’t know that my Garmin HRM would pair with anything other than my Garmin device but wanted it to pair with Zwift. This meant I would have to buy a Wahoo compatible HRM, which is not a big deal, but already having one seemed ridiculous. So I ordered one on Amazon and as a lark just decided to see if my Garmin would pair with Zwift - and I don’t know what smoke and mirrors were used, but the app paired immediately. I cancelled the Amazon purchase. Oh happy day.
