Descending, turns, and pedaling
Bikes: yes, i have one
Quoted: 1138 Post(s)
Liked 1,182 Times
i've been thinking about peddling during descents for a while now and a recent post by cubewheels now makes me ask this question to the forum...do you peddle hard while descending? even into turns? i do but never really thought about hitting the peddle on the ground during turns. speeds reach 40+ so there can be a fair amount of lean. back home after a ride i've leaned the bike toward the ground with the peddle down and i would really need to be leaning for a peddle to clip the ground.
i used to just coast down becasue i was damn tired after the ascent but as i got better i had more energy for the descent, i started doing this because of the side winds i frequently encounter while descending, peddling seems to give me more stability, maybe that is just in my head though.
Quoted: 2604 Post(s)
Liked 1,933 Times
I'll usually pedal up to about 15-20 and then coast, unless it's a really gradual grade and I need to keep up with a group. I can't really put any power into the pedals above 25-30 mph.
I'll do some desultory spinning if it's a long descent; maybe turn the pedals over for a 5-count, coast for a 10-count, repeat until I hit the bottom of the hill. It helps keep my leg muscles from freezing up, which helps keep my locked-up muscles from contributing from a shimmy. But there's certainly no force in it.
Quoted: 195 Post(s)
Liked 234 Times
Descending, especially around turns i find it much more important to consider balance + your line into the corner. Its not like car racing where you can use the throttle for control.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Are you racing? Then learn to do what the professionals do.
Are you riding for fitness? Then apply your work where and when it counts for you. Power applied in climbs will have more benefit than during descents.
Are riding for utility - to get from point A to point B within an amount of time? Then learn to do what is energy efficient and safe.
As to your pedal strike question, it's usually best not to pedal during a tight turn. Outside foot down, weight low, centered between axles (depending on incline (like horseback riding), and on outside foot. Eyes and head toward the line of turn, allow shoulders to follow. At least, that's how I was taught...
Likes For Phil_gretz:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Well, lately I’m riding SS, so I pretty much have to coast, but even with gearing it’s usually a low value proposition to pedal down steep hills.
You can spend a lot of energy and not go much faster than terminal velocity. Speaking of which, a really good tuck will increase that, assuming you want to go that fast.
For my non-racing purposes, it’s best to really push the climb and recover on the downhill.
Otto
Otto
Quoted: 18415 Post(s)
Liked 15,539 Times
If it's what some of us call a "pedaling descent" (one that you could coast down but will make much better time if you pedal), then yes, I pedal, but generally not in turns. Pedaling gentle descents is particularly helpful when riding loaded. It's a good way to cover ground after spending a lot of time climbing a pass. Bu if the descent is steep enough that pedaling won't add that much more speed I will simply coast, especially when loaded. Road surface conditions also factor into my decisions.
Likes For indyfabz:
Quoted: 850 Post(s)
Liked 344 Times
If you're going 40mph through a turn and there's even a remote chance that you might clip the pedals... don't pedal. No amount of power you could (safely) put down through that turn for 1 second is worth the life-altering damage crashing at that speed could do. Especially since clipping pedals causes highsides, where the mechanisms of injury are at least an order of magnitude worse than lowsiding.
At 40mph, you hit an aero brick wall anyway.
That being said, you should be VERY familiar with what your lean limit while pedaling is. I would practice in a parking lot. Wear thick jeans and a hoodie. Or actual pads if you have those. I have a somewhat pedal-y descent where I hit 45+ mph and I'll hold a solid 300+ watts through that turn because it's fairly long and easy, and the road flattens out afterwards, so maintaining momentum is key.
Likes For smashndash:
Kamen Rider
Bikes: Fuji Transonic Elite, Marechal Soul Ultimate, Dahon Dash Altena
Quoted: 351 Post(s)
Liked 277 Times
I think more specifically, eyes towards the apex as you're coming up to the turn, then as you approach the apex, eyes towards the exit? This allows you to look ahead and be better prepared to handle anything unexpected that comes up.
Likes For atwl77:
Bikes: 2019 Specialized Diverge, 2021 Cervelo Caledonia
Quoted: 258 Post(s)
Liked 378 Times
Depends on the situation. On my regular almost-daily ride, there's one hill that has a shallow turn at the bottom, and I pedal pretty hard all the way through the turn and get as much speed as I can. It's fun to go fast. On another hill on the same ride, I take a sharp right turn before I get to the bottom of the hill. Slightly scary. Not only do I not pedal, I sit straight up on the descent to create air resistance to slow my speed. Same ride, different hills. If it seems safe, I'll pedal, but it doesn't always seem safe.
Expired Member
Quoted: 3672 Post(s)
Liked 5,428 Times
As a public service.
Likes For shelbyfv:
Quoted: 2323 Post(s)
Liked 4,988 Times
Steel is real...and comfy.
Likes For jamesdak:
Quoted: 850 Post(s)
Liked 344 Times
Needless to say, I don't need anything bigger than a 50:11 LOL
but yeah. My pedal stroke is flawless. It's less mopar and more ferrari. I know I can get upto 50mph in my 50:11 with no problems. Beyond that it doesn't make sense a) because it's difficult to put down power at 140+ rpm and b) it's usually far more efficient to supertuck, which I do often. In fact I usually supertuck above 35 mph on descents unless I really want to set a time.
Quoted: 850 Post(s)
Liked 344 Times
You need to be somewhat careful with this technique. It lets you go way faster, way more confidently. But if your vision isn't great, you might miss debris/sand in the road while looking too far ahead. You also might ignore your limits (mechanical or skill) and end up writing a check you can't cash. I'd say practice this technique while going slow and gradually ramp up the pace.
Likes For spelger:
Quoted: 365 Post(s)
Liked 419 Times
Pedal during descents - often, I like to go fast, I'm nearly always the passer rather than the passee on a descent (on the flats and uphill it's a VERY different story...). As others have said above, though, once I get much above 40 mph I'm spun out. Also on a long descent, pedaling helps to keep my muscles from tightening up.
Pedaling through corners - most times, yes, when I'm not going too fast, and when there's no fresh-ish chip 'n seal (yes, it's that time of year again around here). I'm not sure of the speed at my limit, I'm looking at where I'm going rather than my cycle computer when cornering. I've only had one significant pedal strike, it was a big jolt, but I kept it upright. It actually didn't throw me off my line that much, and fortunately didn't break any equipment, though my pedal has a big scar, glad it's aluminum and not carbon or composite. It wasn't at anything like 40 mph, it was probably sub-20 mph (90° corner at a light, less room than normal passing a car waiting to turn left).
Doing these things routinely and habitually when no one else rides that way any longer is extremely unusual. And commendable. Thank you for posting.
Likes For 63rickert:
Sunshine
Quoted: 10963 Post(s)
Liked 7,490 Times
To answer you though- I pedal depending on how hard the curve is, how fast I am going, and how steep the hill is. If its a really steep sharp turn, not only am I not pedaling, but I may actively brake. If its a gentle 2% grade and the turn is mild, sure I will pedal.
Sunshine
Liked 7,490 Times
Between 200rpm seated and 130rpm standing, I bet you are in the top .1% of cyclists. And even among cyclists that are enthusiasts or higher, you are probably in the top .5%.
Quoted: 850 Post(s)
Liked 344 Times
I think I'm a bit of a freak mainly because I don't specifically train for it nor do I particularly mind it. Like 120-130rpm is not exactly an event for me. I wish my PM's cadence sensor a) went up to 200 rpm and b) recorded 3 second max rather than instantaneous max. Pretty much every single ride, my "max rpm" is 169rpm - the max my PM will record.
Bikes: 2010 Fuji Absolute 3.0 1994 Trek 850
Quoted: 762 Post(s)
Liked 555 Times
I mean, how much risk are you comfortable with? If you pedal strike at those speeds, you will alter your riding after that
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
In my case, I don't even think about it because I likely won't see the sand/debris until it's too late due to color-blindness. I know I harp on this a lot, but about 8% of men are colorblind to one extent or another (mine is mild, and I didn't realize I had it until my 20s, I'm still surprised from time to time by finding out I'm missing certain cues). It's very easy to self-test for color blindness online, if you're going to try something like this, you might want to test this first before attempting this stuff at speed. An amazing number of people don't know they're not seeing what they're not seeing.
Sunshine
Liked 7,490 Times
I don't know about this. As 63rickert said, it's pretty common for trackies. Maybe I just hung around some hitters but I know at least one other guy who could easily match my rpms. But he also went on to win collegiate track nationals.
For every one of those guys, I could point to 500 cyclists that can barely hit 110rpm.
It was a compliment- its cool that you can spin that fast.
Quoted: 365 Post(s)
Liked 419 Times
Yeah, 130 rpm is about my (seated) max, maybe I could hit 90 rpm standing, never tried to max out standing cadence. I've been cycling many years, but have never competed. I don't have a lot of fast-twitch muscle, and now I'm on the far side of 55, so...
Quoted: 850 Post(s)
Liked 344 Times
Fair enough. I'm very hesitant to accept compliments because I'm not actually very fast or successful in racing. The idea of being in the top 1% of anything is a little weird. But I guess I'll wear this badge
Liked 1,182 Times
I like fast and i go generally go as fast as i can on descents that i know really really well. on my local favorite i know every turn, divot, and crack, and i pay very good attention to any rocks on the way up, only occasionally are there new rocks that weren't there before. there are certainly times where i get as low as possible and don't peddle (for you shelbyfv) when the grade and my tiredness warrant it. for those not so familiar descents or ones with really crappy tarmac i generally don't pedal.
the best gearing i have is 50-11 and i do spin out on that, no clue what my cadence is and its not a number i look after.
