Do XT cassettes last longer?
Old 10-08-21, 04:59 PM
stratman
Quoted: 33 Post(s)
Liked 12 Times in 9 Posts
I run nine speed triple on a road bike. I'm keen to future proof my set up, so have bought spare derailleurs, shifters. What I haven't stocked up on is spare cassettes (or chains). There are still some XT M770 cassettes available. They are about double the price of available Sora (HG50?) cassettes. Will they last twice as long? Or are there any other reasons to pay the extra? My rear shifts are perfect at the moment, on a Sora cassette with M772 RD.
Thanks.
stratman is offline
Old 10-08-21, 05:10 PM
Crankycrank
Quoted: 836 Post(s)
Liked 1,058 Times in 742 Posts
Thanks.
Performance and durability will be about the same. What you're paying for is lighter weight usually. Pricier Shimano cassettes will have cogs riveted to aluminum carriers and better finishing/plating requiring more complex manufacturing ($$$) but the teeth are much the same.
Crankycrank is offline
Likes For Crankycrank:
Old 10-08-21, 06:10 PM
HillRider
Quoted: 2026 Post(s)
Liked 1,095 Times in 741 Posts
A quick Google search turned up dozens of listings for 9-speed cassettes from Shimano, SRAM and a couple of lesser known brands in a variety of quality levels from HG50 up to Ultegra. Even Amazon lists them so I wouldn't worry about future supply problems. For that matter, even 7 and 8-speed cassettes are still fairly easy to find.
As to 9-speed chains, if you have problems finding them, 10-speed chains will work just fine on a 9-speed cassette. I've used 10-speed chains on an 8-speed cassette and it worked perfectly.
HillRider is offline
Old 10-08-21, 06:55 PM
stratman
Quoted: 33 Post(s)
Do you think an XT cassette will last twice as long as a Sora cassette?
stratman is offline
Old 10-08-21, 07:12 PM
Rolla
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times in 1,439 Posts
That depends entirely on how you use and maintain it, but there's nothing inherently more durable about XT. They do claim that the pins behind the biggest cog can help prevent spoke damage in the event of an overshift.
Rolla is offline
Old 10-08-21, 07:28 PM
SoSmellyAir
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1938 Post(s)
Liked 1,460 Times in 1,011 Posts
This hoarding priority seems wrong. In order of importance: chain, cassette, derailleurs, then shifters.
SoSmellyAir is offline
Old 10-08-21, 07:39 PM
stratman
Quoted: 33 Post(s)
Do you think an XT cassette will last longer than a Sora cassette?
stratman is offline
Old 10-08-21, 07:41 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4191 Post(s)
Liked 3,836 Times in 2,294 Posts
Some basic understandings are due here. The steels used for cogs are chosen for their manufacturing ease and cost before any wear rate. For any significantly longer wear the steel in a specific cassette will need to be hardened and I don't know of any claim of this from any brand. What I do hear a lot is about the coatings on the steel. Oxide/bluing type finishes on the low cost and various harder coatings on the better stuff. These coatings are still softer then the grit that a chain gets coated with in time. And that's the heart of the issue. The abrasives that are grit and grime will wear any coating or base steel given enough neglect or miles. Think about using sand paper on the various cogs and name one that won't be scratched by that. The better cog coatings will aid the chain's smoothness a tiny bit, reduce engagement friction slightly until the coating is worn through. BTW these coatings are only scant ten thousandths to a a few thousandths thick and tend to be brittle so they can break down and flake off off with stress.
I consider cogs, like chains, rings, pads, and bar tape to be consumables (and rims too but others spend so much for their wheels that they can't get past the investment aspects). Sometimes I get lower cost stuff for myself and sometimes I splurge and get the fancy and lighter weight expensive stuff. But My eyes are open to what I am expecting. Andy
AndrewRStewart
Last edited by Andrew R Stewart; 10-08-21 at 07:59 PM. Reason: late evening keyboard challenges
Andrew R Stewart is offline
Likes For Andrew R Stewart:
Old 10-08-21, 07:46 PM
stratman
Quoted: 33 Post(s)
Originally Posted by Andrew R Stewart
Some basic understandings are due here. The steels used for cogs are chosen for their manufacturing ease and cost before any wear rate. For any significantly longer wear the steel in a specific cassette will need to be hardened and I don't know of any claim of this from any brand. What I do hear a lot is about the coatings on the steel. Oxide/bluing type finishes on the low cost and various harder coatings on the better stuff. These coatings are still softer then the grit that a chain gets coated with in time. And that's the heart of the issue. The abrasives that are grit and grime will wear any coating or base steel given enough neglect or miles. Think about using sand paper on the various cogs and name one that won't be scratched by that. The better cog coatings will aid the chain's smoothness a tiny bit, reduce engagement friction slightly and until the coating is worn through BTW these coatings are only scant ten thousandths to a a few thousandths thick and tens to be brittle so they can break down and flake off off with stress.
Thank you for a useful reply.
stratman is offline
Old 10-08-21, 08:11 PM
HillRider
Given the same care and riding style, no. As above, the more expensive cassette will be lighter and prettier but not significantly more durable.
Old 10-08-21, 09:21 PM
SoSmellyAir
Doubtful.
When I went 1X conversion on my hybrid bike, I decided to replace my 8 speed 11-32 Altus CS-HG31 cassette to get the slightly different 11-30 gearing, and paid a few more dollars for an Alivio CS-HG51 which has a shinier finish than an Acera CS-HG41.
Old 10-08-21, 10:05 PM
Cyclist0108
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times in 1,164 Posts
No
Cyclist0108 is offline
Old 10-08-21, 10:06 PM
Cyclist0108
Occam's Rotor
No X 2
Old 10-08-21, 10:07 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3870 Post(s)
Liked 2,563 Times in 1,577 Posts
Thanks.
Don't forget spare chainrings. Triples have fallen from favor.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 10-08-21, 10:08 PM
Cyclist0108
Occam's Rotor
I don't know if this is true for 9 speed, but for some of the 11 and 12 speed cassettes, the largest cogs are aluminum, so they are likely to be shorter lived.
Old 10-08-21, 10:26 PM
alcjphil
alcjphil's Avatar
Quoted: 1813 Post(s)
Liked 1,692 Times in 973 Posts
No, they don't. However, they are lighter
alcjphil is offline
Old 10-08-21, 10:50 PM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 3126 Post(s)
Liked 2,102 Times in 1,366 Posts
The coatings Andy mentioned aren’t really there for wear, for the most part. They are rust prevention, and gunk doesn’t stick as hard to glossy surfaces. So in that sense, yes, they help. They’re also prettier.
The best way to future proof your bike is… not to worry about that, it’s doomed. Premium 9 speed is a snapshot of 15-20 years ago.
Darth Lefty is offline
Likes For Darth Lefty:
Old 10-11-21, 10:16 AM
sch
Quoted: 303 Post(s)
Liked 136 Times in 104 Posts
OTOH the large cogs are about the same size as the chainwheels which IME last longer than steel cassettes.
sch is offline
