Single speed freewheel wobbling a little
Quoted: 5 Post(s)
Hi all, I’ve got a specialized langster and have recently noticed there is a slight wobble on the hub. From what I’ve read this can be normal on the freewheel side?
ive noticed recently I hear a slight slight rubbing noise when I’m pedalling and thought this may be the cause? Or could it be a chain that is too loose?
I can post video if need be
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Quoted: 5 Post(s)
In terms of the rubbing noise its not the front wheel, I feel like its coming from the rear wheel but just when I pedal. The noise is like a rubbing/whirring noise. I have since given the chain etc a really good clean, thought perhaps there may have been something on the chain or cassete causing the noise possibly. Will head out for a ride later and see how I go.
Quoted: 4201 Post(s)
Liked 3,859 Times
Just to be sure there are two common noise generating situations with a single speed that can be confused.
One is a too tight chain. As many low cost bikes have less then perfect world machining of parts there's nearly always some variation of chain tension as the bike is pedaled. The correct chain tension at it's tighest point is no tension. Anything more and the tight spots will complain with noise and in time increased BB and hub bearing wear.
Next is a freewheel that sits cocked WRT the hub's rotations. Poor machining of the hub's or freewheels threading and related parts cause this. Most often noticed as a orbital float/wobble of the rear cog when coasting. Unless the off axial wobble is big the issue is minor but adds the attempts at making a drive system run quietly. Revisit chain tension. Andy
AndrewRStewart
AndrewRStewart
