60mm or 80mm presta valves for 50mm rims?
Old 10-19-21, 10:32 AM
sw20
Quoted: 99 Post(s)
Liked 41 Times in 26 Posts
what length presta valves do everyone use for their 50mm rims? just bit the bullet on some new wheels so need to new tubes!
sw20 is offline
Old 10-19-21, 10:55 AM
SpedFast
Just Pedaling
SpedFast's Avatar
Bikes: YEP!
Quoted: 332 Post(s)
Liked 521 Times in 348 Posts
It depends on how Aero your rims are.
SpedFast is offline
Likes For SpedFast:
Old 10-19-21, 12:11 PM
hrdknox1
hrdknox1's Avatar
Quoted: 85 Post(s)
Liked 53 Times in 40 Posts
I have both 50mm rims and 60mm rims. I use 60mm presta valves with the 50mm, and 80mm valves with the 60mm rims. For 50mm rims the 60mm valves are long enough for pump and inflator heads.
hrdknox1 is offline
Likes For hrdknox1:
Old 10-19-21, 12:39 PM
burnthesheep
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times in 974 Posts
Silca valve extenders are the answer. I got tired of being crippled to specific tubes with permanent length valves on them. I played that game a while and got bitten when I double flatted and had one tube. Folks who offered help road side for the second tube........I had no extenders and their tube didn't have long valves.
More convenient to buy the tube you want and run extender.
These extenders do NOT require any thread tape or sealant. Just screw it on
burnthesheep is offline
Likes For burnthesheep:
Old 10-22-21, 11:41 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
I'd probably go with 80mm. Worst case, it's a little too long. But that's no problem -- most of the 700C bikes in my collection have valves that are way longer than needed because that's all that was available at the time I needed a new tube.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 10-23-21, 06:59 AM
jaxgtr
jaxgtr's Avatar
Quoted: 763 Post(s)
Liked 1,731 Times in 1,008 Posts
yep, I have some 50mm depth tubeless and use a 65 mm valve, but could not find 60mm tubes, so had to go to 80mm which I think are too long.
Brian | 2023 Trek Domane SLR 7 AXS | 2023 Trek CheckPoint SL 7 AXS | 2016 Trek Emonda ALR | 2022 Trek FX Sport 5
Originally Posted by AEO
you should learn to embrace change, and mock it's failings every step of the way.
jaxgtr is offline
Old 10-23-21, 10:15 AM
Troul
Troul's Avatar
Liked 2,966 Times in 1,915 Posts
you could go with shorter reach & use these:
https://www.amazon.com/dp/B000FIE5SU..._it&th=1&psc=1
I have not used these, but might be just as good:
https://www.amazon.com/UNICHE-Presta.../dp/B07B8DCBMY
-Oh Hey!
Troul is offline
Old 10-23-21, 07:36 PM
BlazingPedals
BlazingPedals's Avatar
Quoted: 1513 Post(s)
Liked 734 Times in 455 Posts
For me, the perfect length would leave 15 mm of stem showing. I round up whenever I need to because 10 mm might not be enough for a good connection to some pump chucks.
BlazingPedals is offline
Old 10-24-21, 02:28 AM
sw20
Quoted: 99 Post(s)
65mm would be the ideal solution but I can't find any inner tubes that are 65 or even 70mm. Will buy a 60mm and see if that works for my track pump, out on the road I use co2 and have a Specialized Swat mini co2 head so I think that should fit no problem. Just wondered how many people use 60mm in their 50mm rims. Might try the Continental 30mm extenders otherwise as I think 80mm would be too long.
sw20 is offline
Old 10-24-21, 06:14 PM
jaxgtr
jaxgtr's Avatar
Quoted: 763 Post(s)
I've used extenders on 34mm length valves on some tubes and it worked very well
jaxgtr is offline
Likes For jaxgtr:
Old 10-25-21, 12:58 AM
Fredo76
The Wheezing Geezer
Fredo76's Avatar
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 910 Times in 445 Posts
I have 60 mm valves on my aero 50 mm rims and they protrude just barely enough.
Fredo76 is offline
Likes For Fredo76:
Old 10-25-21, 07:23 PM
MinnMan
MinnMan's Avatar
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4381 Post(s)
Liked 3,014 Times in 1,864 Posts
My rims are 55 mm and I use 80 mm valve stems. They stick out too far, but 60 mm are definitely too short. I guess i need 70 mm, which of course, doesn't exist.
For 50 mm rims, 60 mm valve stems seem skimpy, but 80 would be really long. Not that that's a problem. Just fugly.
MinnMan is online now
Old 10-25-21, 08:10 PM
Hiro11
Bikes: 2022 Specialized Allez Sprint custom build, 2019 Giant Defy Advanced Pro 0, 2018 Seven Mudhoney Pro custom build, 2017 Raleigh Stuntman, various others
Quoted: 782 Post(s)
Liked 475 Times in 238 Posts
I'd get the 80s.
Hiro11 is offline
Old 10-26-21, 04:22 AM
sw20
Quoted: 99 Post(s)
just seen this on youtube, looks like there should be enough for track pump!
sw20 is offline
