Deep Sigh
Bikes: Bicycles? Yup.
Quoted: 477 Post(s)
Liked 1,550 Times
Deep Sigh
Finished the 3 month Centurion Prestige build. Adjusted everything on the stand. Test rode up and down the block, brifters and brakes, it's working nicely so I go to end of the block, turn left uphill and stand on the pedals. I didn't finish the second rotation when it came apart violently.
This was a tough lesson; when building on an old frame with unknown history, build and test before any cosmetic work.
Only 10 minutes to live
So, the worst has happened; n-1, and this will be rectified soon!
Likes For BTinNYC:
Likes For 3speedslow:
Quoted: 3490 Post(s)
Liked 2,910 Times
Ugh. I feel your pain! I've never seen a failure like that. I wonder what kind of forces, and in what direction(s), caused such a failure.
Likes For smd4:
Get it fixed. It will be worth it.
Likes For Bad Lag:
Bikes: 1981 Bianchi Specialissim, 1976 Colnago Super. 1971 Bob Jackson. 2012 Kestrel 4000. 2012 Willier. 2016 Fuji Cross 1.1
Quoted: 275 Post(s)
Liked 940 Times
Holy crap, never seen that before. Hopefully you came out of it unscathed.
Likes For BTinNYC:
seņor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3869 Post(s)
Liked 6,456 Times
Likes For BTinNYC:
Bikes: 2010 Cannondale CAAD 5 Potenza 66cm, 1984 Basso Gap Nuovo Record 65cm, 1989 Cannondale ST Racing Triple 27", 1974 Schwinn Paramount Nuovo Record 26", 198? Scapin MKII 66cm Victory, 1994 Havnoonian Chorus 8sp 27"
Quoted: 45 Post(s)
Liked 101 Times
Awful... Though the half a dropout is proof positive of the enormous wattage that you clearly put out. If it were mine, I'd hang it on the wall and recount the story to houseguests. Good luck finding your n+1!
Likes For jrg1244:
Liked 2,910 Times
I would think the force exerted would tend to pull the axle towards the front of the dropout, along the slot. What caused it to force the bottom part of the dropout (I'm guessing), down, vertically?
Old fart
Quoted: 3582 Post(s)
Liked 3,395 Times
Usually it happens as a result of the chain jamming and pulling on the derailleur. This could have happened under a previous owner, who straightened the damage. A subsequent hard shift may have been enough to cause the failure in that previously weakened spot.
Liked 2,910 Times
Well, all the old books say that a great benefit of steel frames is that they can be relatively easily/cheaply repaired. Time to place that ancient wisdom into practice!
Quoted: 359 Post(s)
Liked 582 Times
2. Worth fixing.
3. Take the picture, frame it, mount that on the wall as proof of your wattage.
4. Refine the story to generate swoonage.
Quoted: 964 Post(s)
Liked 1,451 Times
Long drive, but...
Come to Harvard and I'll MIG it for you.
Bring a nice Calvados or green chartreuse and be prepared for an evening of fun.
My prior dropout work is here. I'm confident I can do this. Super easy, especially if you can forego the adjuster. I can redrill and tap the adjuster as well, just a bit more work.
Likes For scarlson:
Quoted: 477 Post(s)
Liked 1,550 Times
Long drive, but...
Quoted: 964 Post(s)
Liked 1,451 Times
Sure I would. For a bottle of green chartreuse and some agreeable company. Would also consider aņejo mezcal or tequila. You know, the stuff that's been aged on oak. Come over on the megabus, tell them it's a folding bike, they won't know!
I'd rather do that than try to source another dropout, melt and grind and file the old one out, prep everything, and braze it. The bottom of the dropout doesn't see much stress. This is way easier than the one I just did, linked to above. Only risky thing is trying to drill through the weld and tapping that hole for the adjuster. Much easier and stronger if you forego the adjuster on that side. But I can drill it too, if you must.
feros ferio
Quoted: 1390 Post(s)
Liked 1,322 Times
This is the one argument in favor of stamped dropouts over forged.
It is also possible that the dropouts were not properly aligned, or that the previous owner had broken a rear axle and stressed the drive side dropout in the process.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
"...so there I was, rolling easily along at about 8/10ths when I decided to pour on the coal..." Etc., etc.
Quoted: 4559 Post(s)
Liked 2,802 Times
Any signs of corrosion in the threads of the adjuster hole? Just grasping at straws here.
That's gonna be a pretty build once it's back together.
Likes For plonz:
Quoted: 1104 Post(s)
Liked 1,824 Times
I've seen that before. In those cases, it was from putting a longer OLD axle in frame designed for 120/126mm without cold setting and making sure the dropout faces were parallel to each other. Mind you, that's not what I'm saying is the case here.
Quoted: 477 Post(s)
Liked 1,550 Times
I will very closely check the DOs after fixing.
I did not successfully cold set because the stays were like spring steel (wouldn't hold a mm of bend, even after spreading to 165mm, yet relatively easy to spread by hand) and now my check for parallel with a homemade tool feels cursory.
Edit PS
Wouldn't that misalignment become evident while setting up the RD?
