understanding new drivetrain component gearing
Quoted: 5224 Post(s)
Liked 3,581 Times
I had the drivetrain components replaced on an older, entry level MTB. it seems fine, the gearing feels fine on a known hill I'm used to. however, I see a difference in the gearing when I look at specs on the paperwork. I don't think I need to be concerned, but it would be good to hear from someone, with actual knowledge, tell me it wasn't a bad move
I bought the bike 2nd hand (in the Spring of 2019), I don't know exactly what year it is. the only specs I could find easily are on the REI website
GT Timberline 1.0 29er Bike - 2014
https://www.rei.com/product/867504/g...29er-bike-2014
OEM - Rear Cogs Sunrace, 11-34, 8-speed (I can't confirm that it was an 8 speed not 7speed, I think it was a 7 speed)
NEW - SHIMANO CS-HG200 12-28 7 Speed Cassette
OEM - Crankset Forged Alloy, 42/34/24
NEW - SHIMANO ALTUS FC-M311 CRANKSET (BLACK) (3 X 7/8 SPEED) (SQUARE TAPER) (175MM) (42/32/22T) (RIVETED)
I'm hoping that losing some teeth in the back is compensated by also losing some teeth in the front? am I looking at this correctly?
Bikes: 2018 Jamis Renegade Exploit, 1996 Trek 930, mid-90's Dean El Diente, 2010 Scott Addict SL, 1998 Trek 730, Xtracycle EdgeRunner 30D, Xtracycle Swoop, 1992 Trek 790
Quoted: 87 Post(s)
Liked 107 Times
You can look at a gear-inch calculator such as https://www.bikecalc.com/gear_inches to see how close the gearing is. The 24/34 combination is about 18.7 gear-inches; the 22/28 combination is about 20.8 gear-inches. Not sure what the next largest cog was on the old cassette, but if it was a 30T, then the new gearing is close to that - basically you've lost just the very lowest gear.
Likes For nathand:
Liked 3,581 Times
Liked 3,581 Times
using that calculator (700c/29er w/ 2.25" tires)
I think my OEM smallest gear inches was 20.58
& with the new stuff I think it is 22.90
so I think it is harder to pedal, but not much harder?
Quoted: 87 Post(s)
Liked 107 Times
Likes For nathand:
Quoted: 1943 Post(s)
Liked 2,164 Times
Everything depends on how often you used the old 24/34 and if it was not low enough, or barely, on some climbs.
If there are no issues climbing with the new setup, you may have improved the gap between ratios; unless the old one was a mega with a 24 to 34 jump. If that is the case then you substituted the 34t for a 28t and the rest of the cassette might be identical.
But using smaller inner and middle chainrings lowered the overall ratios of the 11-24 cogs when in those chainrings.
John
John
Likes For 70sSanO:
Liked 3,581 Times
THANK YOU
losing my lowest gear is a drag. kinda important @63 with old joints, etc. I can fudge around with the other mid gears, but when you need LOW nothing else will do, except walking up the climb
Liked 3,581 Times
Liked 3,581 Times
THANK YOU wish I discussed it at the shop when I was dropping it off. I asked about it when I picked it up. they gave me the only thing they had in the shop & didn't save the old one. I'm a little disappointed in myself & the shop. I'll live with it for a while & see if it really matters. mostly today, I was just trying to understand what happened with the switch
Quoted: 2338 Post(s)
Liked 2,822 Times
what derailler do you have? you cold put a 12/32 cassette on for $20 if the range of the derailer will handle it https://www.rei.com/product/737175/s...E&gclsrc=aw.ds
Likes For squirtdad:
Liked 3,581 Times
Liked 2,822 Times
THANK YOU!, from the spec sheet above it only shows "Shimano Acera" another website was more specific: "Shimano Acera, RD-M360"
acera spec are 11 min rear cog, 34 max rear cog
43 tooth change wrap
so you would be good with the 12 -32 in terms of cog capacity
and you would be good with chain warp as you need 40 and derailer can handle 43 (see below)
might need a new/longer chain
change wrap = Difference between hi/lo front rings + difference between hi/lo rear cogs
change warp = (42-22 = 20) + (32-12 = 20)
chain warp = 20+20 = 40
Liked 3,581 Times
I'm a little perplexed here. You, Rumrunn6, have been around BF a very long time. This seems like such a basic question.
Likes For zacster:
Liked 3,581 Times
anyway, even when I know something, asking an expert for a fresh explanation, can educate me a little bit more
the older I get, the more respect I have for others' expertise. I may be on here a lot & for many years, but one learns what's relevant to themselves. I've never had an entire drivetrain replaced & as a visual artist I shy away from math problems. even when I was SCUBA diving I struggled w/ dive tables, but could swim like fish. when I was in my teens, I asked a bike shop for a smaller rear cassette on my 10 speed, cuz I wanted to go faster. hehe kids on the street, eh? I remember 1 killer hill that got tougher. but at that age, I could still climb it. don't have those legs/knees 46? years later
Likes For zacster:
Liked 2,164 Times
I have to agree with everyone else that a 12-32 7 speed is a good choice.
John
John
Likes For 70sSanO:
Liked 3,581 Times
Liked 3,581 Times
- if I change the cassette myself
- can I just see how the chain does on all gears before deciding about replacing? I don't ever see myself using large front to large rear gear
- I'll figure out the Rear Der. adjustment. do you think maybe I'll get lucky with just a cable/barrel adjustment? or the chain tension (for "B" adjustment)
Liked 2,822 Times
thank you.
Here are 2 great videos for chain sizing and derailler adjustment. both are pretty easy if you follow the steps IME
chain sizing small/small is my favorite
park tool derailler adjustment video
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 912 Times
You have compacted your ratios slightly, more on the top than on the bottom.
old: 11 34
42 103 33
34 83 27
24 59 19
new: 12 28
42 95 41
32 72 31
22 50 21
If it works for you, you can just keep using it!
old: 11 34
42 103 33
34 83 27
24 59 19
new: 12 28
42 95 41
32 72 31
22 50 21
Likes For Fredo76:
Liked 3,581 Times
IMHO never safe to not be able to run big/big, no matter how much you tell your self you won't use it, there will be a situation where it happens, and that can mean stops, with potential breakage of parts and body depending on speed, been there, done that, will not repeat New chain if needed is cheap insurance
Liked 3,581 Times
thank you. I don't totally understand that. my only concern is losing my lowest gear & getting it back or improving it, getting it lower. I rarely ever use the big ring up front
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,217 Times
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 3,581 Times
This calculator is one of the best I’ve run across for comparing drivetrains. Below is your old and new drivetrains. The number above the triangles are gear inches. The calculator also allows for those values to be speed or development or gear ratios. You’ve lost both high end and low end with the 12-28 cassette.
considering they also changed the front chain rings, what effect will installing a 12-32 rear, do for me? (which I am leaning toward doing)
I expect my low will be lower than OEM, (which I would welcome for the rare need) I'm not too concerned about the high gear, I rarely used it if ever
