thin wrench for hubs
Old 07-02-22, 06:34 AM
sweeks
sweeks's Avatar
Quoted: 810 Post(s)
Liked 350 Times in 256 Posts
Originally Posted by Bill Kapaun View Post
Since the lock nut is on the end, you don't need a thin wrench. (with the wheel removed).
This ^^.
Here's a possible exception. Nexus hubs have a 17mm nut on the non-drive side, which is amenable to a normal ("thick") wrench especially with the wheel out of the frame. However, with a roller brake module in place, and the wheel in the frame, only a cone wrench will fit. The nut has to be tightened *after* the brake module's torque link is attached to the chainstay, which has to be done after the wheel is positioned for proper chain tension. I suppose the nut could be left a bit loose, as it's not actually locking the NDS cone, but I like it to be tight. A 17mm Park wrench is ideal for this.
sweeks is offline
Old 07-02-22, 12:48 PM
sean.hwy
sean.hwy's Avatar
Bikes: Blur / Ibis Hakka MX
Quoted: 287 Post(s)
Liked 172 Times in 129 Posts
look at my post #9. on my wheel you need a thin wrench to hold the bottom nut in place so you can loosen the top nut. It will spin freely other wise.
kind of like this
sean.hwy is offline
Old 07-02-22, 01:49 PM
SJX426
SJX426's Avatar
Quoted: 1256 Post(s)
Liked 1,261 Times in 694 Posts
The pair of Park wrenches were really soft. I can't recommend them. I found some in a garage sale that are chrome, hard enough not to deform like the Park tools.
SJX426 is offline
Old 07-02-22, 04:20 PM
Trakhak
Quoted: 1186 Post(s)
Liked 1,093 Times in 637 Posts
kind of like this
That's an example of what was mentioned earlier in the thread - while a cone wrench is needed for the cone, a box wrench, or even an adjustable wrench, would work fine for the lock nut.
Trakhak is offline
Likes For Trakhak:
Old 07-03-22, 07:36 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2999 Post(s)
Liked 2,095 Times in 1,246 Posts
But not always:
File Type: jpg
JohnDThompson is offline
Likes For JohnDThompson:
Old 07-03-22, 09:37 AM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 1498 Post(s)
Liked 761 Times in 558 Posts
kind of like this
Which would be MUCH better served with a standard 17mm box wrench.
Less likely to slip off.
Bill Kapaun is online now
Likes For Bill Kapaun:
Old 07-03-22, 09:40 AM
Bill Kapaun
But not always:
Which was kind of covered in post #12, but with this many posts over a simple cone wrench, who pays attention to what was already posted?
Old 07-03-22, 09:47 AM
JohnDThompson
Old fart
Post #12 addressed thin wrenches for cones, not locknuts.
Old 07-03-22, 10:35 AM
Bill Kapaun
So you know what I was thinking and I don't?
Old 07-04-22, 02:11 AM
jccaclimber
Bikes: n, I would like n+1
Quoted: 85 Post(s)
Liked 97 Times in 77 Posts
Every day I browse the mechanics sub and am always amazed that this thread, which has long since solved the OPs issue, continues to gain new posts. When ever will it die?
Based on other comments, it seems likely that the OP knows when they can use a standard wrench. Id guess they also have some thoughts about the use of adjustable hammers, AKA adjustable wrenches.
jccaclimber is offline
Likes For jccaclimber:
Old 07-04-22, 01:42 PM
sweeks
sweeks's Avatar
Quoted: 810 Post(s)
I've used a 15mm Park cone wrench as a pedal wrench for the couplers on my MKS detachable pedals many times. There is no distortion.
sweeks is offline
Old 07-05-22, 06:38 AM
JohnDThompson
Old fart
No, I only know what you wrote. And in post #12, all you wrote about locknuts is that "most (it seems) lock nuts are 17mm. Since the lock nut is on the end, you don't need a thin wrench. (with the wheel removed)." The Campagnolo Record hubs I referenced above use a 14mm cone wrench for both the cone and the locknut. The flats on the locknut are too narrow to accept anything else. Other high-end hubs are similar.
