Are 105 9sp brake levers different?
I read somewhere in this forum that the pull on the brake levers is different. I was going to put 105 brifters on a Cannondale that has the OEM Coda brakes on them. I have the 105 calipers too, but was just going to leave the Codas. Is there a problem with doing that? I am taking the 105 group from a Specialized to a Cannondale because my daughter outgrew the Spec that was a 44 frame to the 48 C'dale, and that 44 frame is tiny. I tried riding it once and could barely pedal it I was so cramped.
SE Wis
Quoted: 2746 Post(s)
Liked 3,391 Times
I believe it has to do with whether its SLR or Super SLR
https://www.cyclabo.com/topics/hr6mzphvey/
Likes For dedhed:
Likes For zacster:
Quoted: 4201 Post(s)
Liked 3,859 Times
I agree with the confusing use of terms like "pull width". I have never read/heard that used to describe either pad movement with lever pull or cable travel per pull.
I believe that the New SLR has seen the calipers getting longer cable anchor and adjuster arm lengths and the levers have thus needed a similar increase of cable pull. So with the most current levers and the old SLR calipers the lever will have a hard/stiff feel when the pads contact the rim. This to some will think this makes for more powerful braking action but actually the leverage has gone down. For those of us with strong hands and like that solid feel this can be OK. But do know the lever pull effort will need to be more for the same pad/rim clamping force. Andy (who hope he has this right and not backwards)
I'll add that levers and calipers from other than Shimano might not fully copy the geometry of the "matching" Shimano system, independent of the year of production.
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
I'm used to the terms short pull and long pull for road/cantis and V-brakes. Do these levers fall somewhere in between? Or are they even shorter pull? And will the levers work with the Codas? I use Campy levers with Campy brakes, Tektro levers with Tektro brakes and Shimano Deore levers with XT V-Brakes and they all work perfectly, but they also all match. I also have one bike set up with Tektro levers and Campy Veloce brakes, but this one has cross levers too. It all just works.
If I were guessing, I'd think the Codas from the Cannondale are completely Shimano compatible. But I'm guessing.
SE Wis
Liked 3,391 Times
9 speed you're likely just fine
Quoted: 836 Post(s)
Liked 1,061 Times
I would just install the 105 brifters and see how it goes. As mentioned, there are different pull ratios between different calipers and generations of calipers that you might be able to find with some time-consuming searching. But, since you also have the 105 calipers, I would think it's just faster, and will give you a real-world answer, to just mount everything, try it out, and then switch calipers if necessary.
Likes For Crankycrank:
And one thing I haven't checked is the brake pads on these Codas. If I need new pads I'll just use the 105s since those are still good I think. Who makes those brakes anyway? Tektro? They look more like Campy than Shimano.
Quoted: 1944 Post(s)
Liked 2,164 Times
Here is a very informative, but at times somewhat difficult to follow, thread on cable pull...
https://www.bikeforums.net/bicycle-m...ll-ratios.html
John
John
