Chain Length calculation?
Old 06-29-22, 05:51 AM
ronnydee
Thought it would be interesting in using the chain length calculation and compare to sizing the chain using Largest cog and largest chainring method.
The calculation is:
L = 2 (C) + (F/4 + R/4 + 1)
  • L = Chain length in inches
  • C = Chain stay length in inches
  • F= Number of teeth on biggest front chainring
  • R= Number of teeth on biggest back cog.
My question does the chain length include the master link? For example if the chain length result is 55, is this include the master link? Was wondering if the "+ 1" in the calculation is the master link?
ronnydee is offline
Old 06-29-22, 07:03 AM
HillRider
Quoted: 1870 Post(s)
Liked 824 Times in 589 Posts
Yes, a master link is included in the chain length. Without a master link the chain would be joined by reusing a standard pin (older 5/6-speed) or a special joining pin (7+ speed). The "+1" accounts for the extra chain length required to allow the chain to clear the cog or chainring teeth height while shifting.
HillRider is offline
Old 06-29-22, 09:13 AM
squirtdad
squirtdad's Avatar
Quoted: 1745 Post(s)
Liked 1,376 Times in 834 Posts
I never calculate.... what works well for me for both modern and vintage (friction) setups is small/small sizing
and of course Big/Big combo has to work
(looking for Torpado Super light 56,57 or so)
squirtdad is offline
Likes For squirtdad:
Old 06-29-22, 10:34 AM
KerryIrons
Quoted: 152 Post(s)
Liked 172 Times in 101 Posts
Yup. No need for a calculator, and the numbers put into the calculation are subject to operator error in measurement. Small/small gives the right length and if you are cheating by needing more chain wrap than the derailleur can handle then you need to double check with a big/big confirmation and expect the chain to hang slack in the small/small.
KerryIrons is offline
Old 06-29-22, 10:43 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1644 Post(s)
Liked 2,427 Times in 1,255 Posts
Calculating chain length is about the most stupid way to figure it out. Put the chain on the bike and use the recommended method for the particular drivetrain you have.
cxwrench is offline
Likes For cxwrench:
Old 06-29-22, 12:03 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 1498 Post(s)
Liked 762 Times in 559 Posts
No need to overthink this-
Bill Kapaun is offline
Old 06-29-22, 12:24 PM
smd4
Bikes: 1989 Cinelli Super Corsa
Quoted: 828 Post(s)
Liked 607 Times in 392 Posts
To me, this is also overthinking it.
smd4 is offline
Old 06-29-22, 12:26 PM
Bill Kapaun
Everybody has their limits.
Old 06-29-22, 12:28 PM
smd4
Quoted: 828 Post(s)
At least I don't need to use a pair of tiny screwdrivers to know if my chain is the right length.
smd4 is offline
Old 06-29-22, 12:45 PM
ronnydee
aaah ok then my chain is a bit long. I wasn't sure if the master link was part of the calculation so i didn't cut the chain and added the master link. So, I will attached one side of the master link, and re-measure the chain from end to end.
thankx for the heads up on this.
ronnydee is offline
Old 06-29-22, 12:51 PM
Bill Kapaun
Ignore list so I don't have to deal with your pettiness.
Old 06-29-22, 01:22 PM
esasjl
Bikes: '84 Chas Roberts, '91 Peugeot Galibier, '90 Gitane Leader, '51 Dayton Elite, '90 Verago ATB, '08 Dawes Sardar
Quoted: 12 Post(s)
Liked 72 Times in 22 Posts
The master link is 0.5 in the +1 of the calculation. All the above approaches work but testing big-big in the stand is critical.
esasjl is offline
Likes For esasjl:
Old 06-29-22, 02:12 PM
Camilo
Quoted: 641 Post(s)
Liked 510 Times in 336 Posts
I was going to write the same thing, so thanks.
I almost think such posts which use math instead of simply measuring stuff are intended to be ironic?
Camilo is offline
Likes For Camilo:
Old 06-29-22, 02:13 PM
Camilo
Quoted: 641 Post(s)
So you actually size the chain based on the calculation rather than just sizing it the way it's supposed to according to every authoritative source? (derailleur manufacturers, professional shops, etc.) Wouldn't you actually test the chain length after cutting it according to the calculation, and if so, why would you not do it the easy/correct way first?
Yeah, this sounds critical, but maybe there's a good reason to use a calculation that I don't understand? Can you explain if so.
Camilo is offline
Likes For Camilo:
Old 06-29-22, 03:46 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Exactly @Camilo, this is why not any drivetrain manufacturer uses a formula of any kind.
cxwrench is offline
Likes For cxwrench:
Old 06-30-22, 08:46 AM
Iride01
MotuekaCascadeChinook
Iride01's Avatar
Quoted: 4472 Post(s)
Liked 2,992 Times in 2,086 Posts
Formulas tend to be very exact and don't take into account every possible component group, cassette range or chain ring difference.
In reality there isn't an exact number of links your chain must be and one more or less might do better or might perform the same for a particular bike.
The big thing in sizing a chain is just knowing what to look for. If your chain sags when in the small/small then it might be too long. If the rear DR cage is stretched to it's forward limit when in the big/big then your chain might be too short.
Iride01 is offline
Old 06-30-22, 09:49 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Not exactly true, at least not anymore. Shimano and SRAM both have more involved instructions for chain length for both road and mtb. They don't involve formulas but they're more complicated than small/small.
cxwrench is offline
Old 06-30-22, 09:57 AM
squirtdad
squirtdad's Avatar
never mind where exactly a wheel might be if the rear drop outs allow for sliding position
Old 06-30-22, 12:03 PM
smd4
Quoted: 828 Post(s)
Here's how you determine chain length for my DA 7700 derailleur: With the chain on the smallest cog and the largest chainring, the two pulleys on the rear derailleur should be perfectly vertical--90 degrees perpendicular to the ground. Straight from the manual.
Works every time for me.
smd4 is offline
Old 06-30-22, 04:07 PM
ronnydee
oh i always size the chain large cog large chainring. Was just curious if the calculation works out the same thats all
ronnydee is offline
Likes For ronnydee:
Old 06-30-22, 05:42 PM
HillRider
About the only use for doing the calculation in advance rather than actually fitting the chain would be to see if the chain you want to buy will be long enough. New chains come in different lengths, 112, 114, 116, etc links. If your calculation says you need 114 links you would want to avoid buying a chain 112 links long.
Likes For HillRider:
Old 06-30-22, 08:18 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Totally depends on how far forward you pull the derailleur cage.That's why you should follow the drivetrain manufactures recommendations. On older road bikes and mtbs that are completely within capacity spec you can use small/small and you'll get the longest chain possible, which is a good thing. Big/big is totally dependent on the chain installers preference.
cxwrench is offline
Old 06-30-22, 08:58 PM
SoSmellyAir
Method to My Madness
Bikes: Cannondale Synapse, Cannondale CAAD4, Trek FX 2
Quoted: 866 Post(s)
Liked 549 Times in 422 Posts
Having both RD pulleys "perfectly vertical" also depends on using a cassette that is officially within specifications and the B screw adjustment.
SoSmellyAir is offline
Old 06-30-22, 09:36 PM
Camilo
Quoted: 641 Post(s)
Thanks - did it? I'd be curious too (although just theoretically!).
Camilo is offline
Old 07-01-22, 06:12 AM
smd4
Quoted: 828 Post(s)
The B screw adjustment? Seriously? That has absolutely nothing to do with sizing a chain. It almost sounds like you don't know what the B adjustment screw is for. And of course the cassette has to be within the limits of the derailleur capacity. Duh.
Feel free to argue with Shimano if you must:
RD-7700
God, for some reason you guys make sizing a chain the most complicated thing about bikes.
smd4 is offline
Likes For smd4:
