What The Bike Shop Says
Quoted: 358 Post(s)
Liked 136 Times
I have an old road bike that I would like convert to a Fix Gear bike. The only problem is the LBS. They say without a F.G. dropouts, you will never get the Rear Wheel tight enough. All I can hope for is a Single Speed. Is this true or a load that the shop is trying to sell me?
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
Likes For TejanoTrackie:
Bikes: I don't even
Quoted: 81 Post(s)
Liked 193 Times
Yeah, if I were a LBS I wouldn't touch that project. Magic gear may be possible, but then you have to manage chain stretch. A gear that works one with a new chain may be too slack in a few hundred miles. There is also the option of building up a rear wheel using a white industries eno eccentric hub. Although, that may set you back about the cost of just getting a frame better suited for the job.
Likes For theblackbullet:
Quoted: 581 Post(s)
Liked 921 Times
Shop is right. You need horizontal dropouts to provide chain tension adjustment. A single speed can be set up with a chain tensioner, but that is because the bottom dun of chain on a single speed (with a freewheel) is not under tension, while a fixed gear bike gets tension in both top and bottom runs of chain and you are likely to rip off a chain tensioner the first time you try to slow down using back force on the pedals.
Likes For ClydeClydeson:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Vertical dropout are the problem -- not the LBS. I can't imagine why you'd think they would tell you this if it wasn't true.
Likes For Rolla:
Bikes: 2017 BMC Roadmachine 01 Enve wheels, Sram red etap,Cinelli Vigorelli single speed, 2009 Cannondale Capo, 2016 trek Domane 6.9, disc and Di2, 2016 Scott Scale 710, 27.5 plus tires and boost rims
Quoted: 110 Post(s)
Liked 203 Times
I see a few vertical drop out bikes for sale on eBay being sold as fixed gear and think I wouldn't want to stand on those petals, I wouldn't even set up a single speed with VD's.
There is this:
convert a road frame to a track frame - YouTube
There is this:
"ready to navigate"
"ready to navigate"
Quoted: 4802 Post(s)
Liked 3,923 Times
"rear wheel tight enough"? Did the shop mean getting the axle nut tight enough to keep the wheel from slipping? A 6" crescent wrench did that job for me just fine when I was a bike racer and stronger than I'd ever be again. Did they mean getting the chain tight enough? Simply bad! The chain should always have ~1/2" vertical play midway between chainring and cog to ensure it never goes tight.
If you have vertical dropouts, you "can" pick one of the chainring/cog combos that yields the right size to produce a chain circle with proper chain slack but that is living life the hard way. You can also buy an eccentric bottom bracket to adjust chainslack. Expensive. Cog changes might alter effective seat height. Far easier is to pass on that bike and get one with either track ends (truly horizontal and opening to the rear) or horizontal dropouts. Horizontal dropouts work and are the choice of many.
Clark W. Griswold
Quoted: 4348 Post(s)
Liked 3,985 Times
Get a proper fixed gear frame, there are tons of them out there and plenty of companies making custom bikes and you can get them built to do whatever you need.
Are the dropouts vertical or semi horizontal? Vertical you can go singlespeed with derailleur or a Surly Singulator. If it's an old road frame with semi horizontal drops you can make it into a fixie .
Back in 02 I asked a bike shop if they could convert an old Raleigh. They fed me this garbage that frame would crack under the pressure of a fixed wheel and advised that I buy fixed bike from them.
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
If you have vertical dropouts then your best option is a wheel built with the White Industries ENO hub. It's a fantastic hub but not cheap and nor is a complete wheel build.
https://www.whiteind.com/product/eno...ric-flip-flop/
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
Shop should have told you the only way (which kinda is true) is with a $300 ENO laced up by their wheelbuilder. Figure spokes and rim at full retail, plus labor, $500 wheel minimum.
