New wheel doesn't fit??
Hello guys
I need a little help, if possible.
I have a Merida Scultura Endurance 4000: ***.merida-bikes.com/pt-pt/bike/3111/scultura-endurance-4000
I bought for it a new set of wheels: ***.fulcrumwheels.com/en/wheels/road-bike-wheels/racing-4-db
My problem now is that it seems that the rear wheel doesn't fit the frame. After I screw it on, the brake touches the disc. If I unscrew one or 2 turns, it fits well and spins well. It's like there some kind of spacer needed (a couple of mm) between the wheel screw and the frame.
The "original" wheel fits perfectly.
Does this make any sense?
Any hints?
Thanks
Any hints?
Thanks
Quoted: 714 Post(s)
Liked 800 Times
The wheel fits the frame, but the disc rotor is not in the exact same place as your other wheel. You need to adjust the brake caliper to match the rotor location on the new wheel. Loosen the two bolts that hold the brake caliper to the frame and you will see that it can move sideways. If you want to be able to use both wheels, you will probably want to use shims on the rotor to move it over and match the old wheel.
If you were missing an endcap, it would be more than a few mm short.
Quoted: 324 Post(s)
Liked 731 Times
You probably just need to readjust your brake caliper to the new rotor. If you plan on switching between the new and original wheels regularly, you might be able to use spacers for the rotor so you don’t have to adjust your brake whenever you switch.
Hey guys
Thanks for the replies.
I don't thing it's a brake issue, because we tested to remove the brake of the frame, just to fit the wheel and the disc stays at a very few millimeters from the frame.
Comparing both wheels sizes, the original it's a little more "wider" if you know what I mean.
I found that the Fulcrum wheel have this part on it: ***.bike-discount.de/en/fulcrum-adjusting-ring-hub
Can this be needed an adjustment?
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
