Stuck Seat Post Removal
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
Attempt number 10.
It can't be stuck if it's liquid
Car dependency is a tax.
Quoted: 6193 Post(s)
Liked 4,809 Times
Sometimes I find myself wishing I could try out such things. However I've never had a stuck seat post or stuck quill in my steerer tube that a rap with a hammer wouldn't cure.
Oh woe is me!
Pretty frame color. What groupset is going back on it?
Oh woe is me!
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1947 Post(s)
Liked 1,468 Times
I am potato.
Liked 1,629 Times
The whole project is contingent upon satisfactory results from the alignment table. This frame was dumped at our Co-Op so bent the wheel was binding in one chainstay, & the crank arm binding on the other. So this whole project really is just for the challenge & for the gamble.
The seatpost was a Thompson that was evidently never greased before being put out to pasture where by the frame filled with water & subsequent freeze/thaw cycles pushed out all the chainstay shaping & tire clearance dimple.
Nothing is cracked. So I think some judicious use of some wooden blocks & clamps might return the chainstay to original form.
The bubbling cauldron-of-doom you see here, is powered by Potassium Hydroxide & tap water. My wife only makes soap as a hobby now. But, her business has been shut down for a few years. The Potassium Hydroxide was a mis-ship from a supplier that had been collecting dust in storage. So, I figured this was as good a' use as any.
(For general info: Potassium Hydroxide is usually used for liquid soap like dish or hands. Sodium Hydroxide is usually used for solid bar soap.)
Steel doesn't much react to strong bases in the way that Aluminum does. Just another way "steel is real."
Likes For base2:
Liked 1,468 Times
I see! I [probably] had a steel bike in my childhood, but that was before I learned any chemistry.
Quoted: 1303 Post(s)
Liked 1,911 Times
The caustic residue running down the seat tube and stays will eat the paint up, Kind of takes constant washing down of the frame to keep the paint from being destroyed. HTH, MH
I am potato.
Liked 1,629 Times
Thompson seat posts are formed with the unnecessary material on either side removed.
Fortunately, the caustic soda/potash solution made quick work of the thinner areas. To get a nub to grab on to I cut the seat post down the seat stay slot & folded in either side of the cut. This allowed for easy removal by means of vice-grips attached to the tiny nub of overlap & light taps in the outward direction with a hammer.
SUCCESS!
Stuck seatpost success! by Richard Mozzarella, on Flickr
Grease your seat post.
SUCCESS!
Bikes: 2013 Wilier Gran Turismo, 1983 Trek 760, 80's Colnago Super, 90's De Rosa SLX, 2009 Waterford 22 Series Singlespeed, 85 Medici Pro Strada, De Rosa Alumino frameset, Dave Molten Fuso frameset, 70's beater Peugeot PX10, Zizzo Liberte, 2022 Yoeleo R12
Quoted: 122 Post(s)
Liked 199 Times
I just saw this on Instagram and had to share it. Use a hydraulic lifter/stacker to pull the stuck Seatpost out!
Hydraulic lifter
Or is that an electric lifter/stacker?
Hydraulic lifter
