Another di2 upgrade thread. 6770 to 6870.
Old 05-30-16, 01:43 PM
unearth078
unearth078's Avatar
Bikes: Cervelo One w/ Drop bars, Focus Cayo Evo 2.0 Di2
TLDR; Can i use 6770 shifters with matched 6870 derailleurs? Can i use 11-28 cassette, being that i have 53x39 chain rings on my crank, with a short cage rear derailleur?
In lieu of an accident Saturday, I am looking to replace my rear derailleur. Thus I have now found out firsthand how impossible it is to find new stock 6770 parts.This is making me seriously look at possibly going 6870. In addition to being able to find parts easier, I'm currently looking to get a couple extra teeth climbing. Currently riding 53x39 with 10 speed 11-25; i am thinking about taking advantage of the 11 speed cassette 11-28.
Now - to pull this off, I believe I need:
chain (maybe, maybe not... i could use a new chain anyhow)
11 speed cassette
rear derailleur
front derailleur - thanks to firmware v3.0.5
I want to solidify that the Brifters are only switches. Thus the paired 6870 derailleurs will not care about being sent commands from 6770 shifters.
Also, with cranks being 53x39, can i use the short cage rear derailleur with 11-28 cassette?
Thank you!
Mike
unearth078 is offline
Old 05-30-16, 01:51 PM
unearth078
unearth078's Avatar
as for short cage compatibility, i believe the formula to use:
top gear minus low gear for crank + top gear minus low gear cassette, should be lower then 32?
not sure if this is correct, but (53-39)+(11-28)=31
am i good to go there?
Old 05-30-16, 09:27 PM
sch
Quoted: 303 Post(s)
Liked 136 Times in 104 Posts
6770 brifters work fine with 6870 FD/RD. On mine, I just bought an 11-32 11 spd cassette, a GS 6870 and FD 6870 and bolted
them on. Left the 10 spd chain on as it was fairly new and everything works great. I was mostly interested in the 32t
available on the cassette with the GS RD. The SS RD should be fine with your 53/39 and 11/28
sch is offline
Old 05-30-16, 09:36 PM
shrimp123
Quoted: 38 Post(s)
Liked 26 Times in 17 Posts
as sch said, 6770 and 6870 are (almost) compatible... depending on firmware version. for the sake of others, the article is CarltonBale.com » Shimano Ultegra and Dura-Ace Di2 Electronic Shifting ? Everything You Need to Know
shrimp123 is offline
Old 05-31-16, 06:47 AM
unearth078
unearth078's Avatar
First hand knowledge! Perfect! thank you.
Old 05-31-16, 06:50 AM
unearth078
unearth078's Avatar
so much here-say out on the internet its good to hear from some people who done it. not from their brothers, uncles LBS guru.
i hope my research was apparent, but still was looking for some peace of mind. Thank you again!
Old 06-02-16, 03:03 PM
unearth078
unearth078's Avatar
Got both derailleurs today. Confirmed 6770 shifters will work fine with 6870 mechs.
To be a bit smart, i plugged in the rear first and tried to shift - Nope! Plugged the front in, and they were both happy.
Cant wait to get my cassette and chain.
Old 06-21-20, 01:57 PM
Larry230
Hi,
I tried to mix 6770fd with 6870rd, but it doesn't work and on my researches from google I found out that they won't work if the battery mount is updated to the latest version.
Now I found a battery mount with 2.1.1 firmware.Do you guys think it will work?Should I buy it?
Thank you.
Larry230 is offline
Old 06-22-20, 06:51 AM
TerryDi2C
Di2 fanatic
TerryDi2C's Avatar
Quoted: 53 Post(s)
Liked 65 Times in 42 Posts
You cannot mix 10 speed derailleurs with 11 speed derailleurs. Shimano blocked this in firmware at some point..
Now.. you could of course get a battery mount with older firmware (I'm not 100% sure that would work), but I would rather upgrade the front derailleur. An FD-6870 shouldn't be that expensive nowadays.. ;-)
(you also cannot mix MTB and road/grx derailleurs)
TerryDi2C is offline
Old 06-22-20, 07:02 AM
Larry230
I know I can't mix them, found out by myself ).
Found out on other thread on google that they will work wit the 2.0.6 battery mounyt firmware version or older.
Now I found a battery mount with 2.1.1 firmware version and would like to know if it works.
Larry230 is offline
Old 06-22-20, 07:11 AM
TerryDi2C
Di2 fanatic
TerryDi2C's Avatar
Quoted: 53 Post(s)
2.0.6 doesn't exist for the SM-BMR1 / SM-BMR2 according to Shimano Unfortunately the changelog doesn't mention anything about blocking 10s / 11s derailleurs from working together
However... if you _really_ want to get it to work.. there is a bit on carlton bale's page about downgrading firmware. Never tried that though..
Look for "INCLUDED FOR VERY MOTIVATED INDIVIDUALS ONLY" - https://carltonbale.com/shimano-di2-...-need-to-know/
Nose4it
Bicycle Mechanics
8
06-26-17 06:17 AM
Spookytooth22
Bicycle Mechanics
6
09-27-15 10:21 AM
Ozan Guner
Road Cycling
3
05-19-15 02:34 AM
BearSGD
Bicycle Mechanics
4
08-31-14 08:46 PM
clarkbre
Bicycle Mechanics
25
07-31-13 01:23 PM
