Carbon seatpost keeps slipping
Quoted: 1557 Post(s)
Liked 1,732 Times
I have a 25.4mm carbon seatpost together with an adapter shim in my road bike which takes a 26.8mm seatpost. It would gradually slip down over time. I am tightening it to 'scary tight' and I am using carbon paste, and it still slips. What gives? Is this how 25.4mm seatposts are ? Or are adapter shims prone to slipping somehow?
Quoted: 1163 Post(s)
Liked 441 Times
Is your shim for a 25.4 to 26.8 specifically? Is it aluminum or Delrin? When it comes to shimming a carbon post, you’ll have better success with a shim that is as long as possible and that fits somewhat snug as you go to set the post to your desired seat height.
I put a 27.2 carbon post in my 30.0 ti frame with the correct size sleeve in aluminum and it made an annoying “tick” sound and then my Hope seat collar bolt broke twice when I overtorqued it. It wasn’t until I went with a U.S.E. branded Delrin sleeve that was a bit thicker than I thought I needed. I pushed it in with copper antiseize and found a stronger bolt for my Hope seat collar and it never ever slipped or made any ticking noises again.
Liked 2,946 Times
wrap the post with one layer of carbon fabric laced with carbon paste.
-Oh Hey!
-Oh Hey!
Likes For Troul:
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
Ive had the same problems with 27.2mm seat posts, no shim. Unfortunately the problem is my 270# body.....
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Why would you do this? Get a simple 26.8 mm aluminum seatpost and be done with it. What advantage do you believe your existing carbon seatpost provides, except that it's paid for?
Likes For Phil_gretz:
Sr Member on Sr bikes
Fiber Grip paste is specifically for this issue.
Usually available at your LBS.
https://www.amazon.com/Finish-Line-C.../dp/B018FT9HOW
Dan
Dan
Bikes: GR300, Grail, Live Wire, 5010
Quoted: 189 Post(s)
Liked 241 Times
Dan
Dan
Liked 2,946 Times
Just one layer leaving a slight gap from where it wraps around the post.
-Oh Hey!
-Oh Hey!
Bikes: Optima Baron LR, '14 Nishiki Maricopa,'87 Trek 330 Elance, '89 Miyata 1400, '85 Peugeot PGN10, '04 Fuji Ace, '06 Giant Rincon, '95 Giant Allegre, '83 Trek 620, '86 Schwinn High Sierra
Quoted: 224 Post(s)
Liked 162 Times
I had the same issue. Carbon seatpost, shim'd to a larger seat tube. Kept slipping. I didn't want to overtorque it and crack the tube. I tried carbon fiber grease. This helped a little. But Michigan roads, you know, a big bump and down went the seat.
I just gave up and bought a larger seat diameter seat post from Bezos's shop. Haven't had a problem since.
Numerous good, maybe, great, suggestions.
But, how about beer?
Take a can of beer, empty it, and cut shims to fit out of the can.
If one can doesn't do it, add another.
Of course, some thought should be given to match the beer to the bike. Some trial and error may be required.
Liked 2,946 Times
-Oh Hey!
-Oh Hey!
If Grolsch is the only match, that's great! Because he would have to go to Europe to get a can, or two. I'd call that "essential travel."
But a 26.8mm seatpost?? Carbon slipping under load like that is really hard on them
Liked 2,946 Times
Quoted: 18397 Post(s)
Liked 15,494 Times
Likes For indyfabz:
Quoted: 1109 Post(s)
Liked 1,200 Times
Liked 2,946 Times
if the seat post has an opening at the top in the center, apply carbon paste to an expansion plug & insert it in the seat post section that is overlapped by the frame seat tube. Once the seat height is set, increase the expansion plug's tension.
-Oh Hey!
-Oh Hey!
don't try this at home.
Quoted: 972 Post(s)
Liked 509 Times
Is the shim itself slipping, or does it stay in place and the post slides down?
On my titanium bike, I had to use some 320 grit sandpaper on the inside of the frame, it was machined way too smooth for the aluminum seatpost. No problems since.
Try scuffing the shim with some 220 or 320 sandpaper, then reapply the carbon assembly paste. The paste has tiny plastic grit in it for grip, but perhaps the shim is too smooth.
( And carbon assembly grit works great on aluminum to aluminum, like handlebars to stems. It allows a lot less torque on the bolts.)
