What are Some Good yet Basic Upgrades New Gravel Bike Owners Should Look at?
Quoted: 61 Post(s)
Liked 164 Times
After getting a bike and riding again a little over a year ago I've bought: 1) Padded liner shorts, as they make rides more comfortable (I mainly wear standard workout clothes over them). 2) A bell as hikers/runners with headphones weren't hearing me give notice. I think it's been more effective in alerting animals, though. 3) Front and rear lights for early morning and evening rides. 4) Small bag with a spare inner-tube, multi-tool, tire levers, and patch kit. 5) Water bottle and cage. 6) Maintenance and cleaning supplies. That's been it, except for replacing worn parts.
I've been using a couple GPS/tracking apps, though. I may get a bike computer, especially as I want to explore longer rides in unfamiliar places. And I plan to convert to tubeless at some point.
Likes For Sertsa:
Quoted: 1109 Post(s)
Liked 1,200 Times
Haven't read the entire thread, and know that this has already been mentioned, but....
#1 thru #10 priorites: spare no expense or effort on finding a saddle you like! If the stock saddle is satisfactory, that's great, you can put on 500-1000 miles and then decide what you'd like to improve upon (lots of people change tires and wheels next).
If the saddle is not satisfactory for at the very least a two hour ride (preferably more), you need to find a better one. Find a shop or online company that will allow you to test them and return for full credit until you find the one you like.
Likes For Camilo:
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
What kind of pedals does it have? If it came with those plastic sort of "temporary" pedals, that's something I'd swap out right away even if you're not sure yet if you want to stick with flats or try clipless(whatever works for you--plenty of people, myself included, prefer flat mountain bike-style pedals on gravel bikes, but clipless certainly has it's appeal as well - neither is "better" than the other, it's personal preference).
If you take that rig out on any remotely rough stuff you're gonna want more grip than those cheapo stock pedals provide, IMHO. I just got some Kona Wah Wahs--the composite/plastic ones--for my son's bike and they're great bang for buck at $60. Plenty of grippy pins, and light. At least your feet won't be slipping around while you get used to riding this beast.
Other than that, tubeless FTW - no reason to wait on that.
Bikes: 2020 Lynskey GR300, 1987 Diamondback Ascent, 1991 Skykomish Marble Point, 1994 Specialized Stumpjumper FSR, 1996 Specialized Stumpjumper M2 FS, 1992 GT Karakoram
Quoted: 69 Post(s)
Liked 226 Times
On my 3rd handlebar and stem combo now. Increasing cockpit height by going from FSA A-wing Pro bars with aero flats to Surly Truck Stops with 30mm rise. Also throwing on some foam pipe insulation (from the plumbing section at Home Depot) under parts of the bar tape for extra cushioning. Those handlebar-specific gel cushion inserts aren’t cushy enough.
Likes For Wilbur76:
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
That is a long way to say, IMO, this is unlikely to provide the result you're looking for. Honestly, if the bumping and buzzing in the handlebar on gravel is bothersome, don't ride gravel. It's a feature of the surface. There are ways to reduce it, it is impossible, in my experience, to eliminate it.
Quoted: 69 Post(s)
Liked 226 Times
Interesting approach, though not one I'd ever be inclined to experiment with. Regular round bars are about 1" (27-28mm) diameter at the outer dimension. That pipe insulation would add significantly to the OD. I'm guessing your plan is to install it to just one side of the bar. For round numbers based on eyeballing that picture, your ~1" bar would become 1.5-1.6" total OD if applied to just the bar tops...before you put tape on it. The greater circumference (would increase by the same amount as the OD) would cause the bar tape to be too short. Something else to consider, pipe insulation is designed to insulate and it is made with closed cell foam that isn't very compressible–thicker likely won't mean more shock absorption.
Quoted: 532 Post(s)
Liked 621 Times
I figured you weren't trying to make your bars the size of the business end of a baseball stick...but, I'm really curious what making them significantly fatter does? The purpose of a gel insert is to provide cushion, and it invariably adds size. Closed cell foam is far less compressible than the gel, but definitely more than an aluminum or carbon bar. In essence while minimally softening the actual place you grip, it really is just making the bar fatter....maybe I am missing something, does making the bar fatter increase comfort? Legitimately asking.
I wanted to close the loop on this, but also let people know about a shoe I found. I ended up getting the Shimano 540 pedals (they were out of the A60s). Then the woman at the shop showed me a Shimano shoe for about $120 but when she looked for it, they were sold out of that model. Then she showed me the Shimano XC7 which were about $220. I appreciated her recommending the lesser-priced shoe first, also I was sure about the plastic looking cable on the XC7. But I really like the micro adjust mechanism on these shoes, it's easy to adjust on the fly.
I didn't want to spend $320 that day but there you have it.
Likes For m2244:
Quoted: 590 Post(s)
Liked 445 Times
A lot depends on what kind of terrain you'll be on:
A dropper post can be helpful, if you take the gravel bike down any steep dirt descents.
Tubeless at a lower psi, for better traction over roots and rock gardens, if that's what you deal with on your gravel routes.
I prefer clipless pedals/shoes when doing slow technical uphill climbs, so I can engage more of the pedal stroke using the hamstrings.
Quoted: 532 Post(s)
Liked 621 Times
That plastic cable is actually a wire cable that has been coated. It is super durable. In 6 years using Boa adjusters, I've never had a cable break...but Boa has a really awesome warranty, and they will replace it if the adjuster or cable malfunction or break. Ride with confidence!
Quoted: 69 Post(s)
Liked 226 Times
Likes For Wilbur76:
Quoted: 286 Post(s)
Liked 261 Times
Regarding the benefit of tubeless...I have a good direct comparison that I found a little surprising. On my previous gravel bike I had 650x47mm GKSK on 25mm internal rims. I ran them with a tube, and went as low as I felt save to do so avoiding pinch flats. Never got a pinch flat and the ride on my local double track was good. My current bike has 700x40, 23mm internal rims, tubeless, and they're way better at cornering and handling than the previous set up, even though the Touareg tire isn't as flat across as the GKSK. Not sure exactly why, but I chalk it up to tubeless and lower pressure.
Quoted: 284 Post(s)
Liked 313 Times
Yep. 61 this year, right behind ya. There's a coupla guys in my area who look like Gandalf - gotta be 70-something - who shred the singletrack I regularly ride like beasts. And their rigs are also old - nothin' fancy there!
Likes For pbass:
Quoted: 286 Post(s)
Liked 261 Times
Regarding "rigs are also old - nothin' fancy there!", I'm starting to get jaded about new, high end components. I'm not sure the quest for lighter, slick looking, and more gears is the way to go. Give me something with a solid track record, that is easy to service and not expensive to replace/repair.
Likes For Noonievut:
Liked 1,200 Times
Consider the Redshift Shockstop stem. Because of arthritis in my elbows I've gone from minimalist tape and gloves to gel inserts, padded tape and gloves. I got a Shockstop stem last year it's really nice for rough surfaces. Subtle, but at the end of the ride you realize that it was working well, kind of at a background level.
Likes For Camilo:
Quoted: 69 Post(s)
Liked 226 Times
Likes For Wilbur76:
Bikes: 1984 homemade 531SL road bike; 1988 Ritchey TimberComp; 1997 Nashbar tandem; 1998 Kona Explosif; Specialized Epic, Scott CR1 Pro; Salsa Beargrease; Curtlo custom Tandem, Curtlo custom S3 steel gravel bike.
Quoted: 67 Post(s)
Liked 49 Times
I agree with the general recommendation of tubeless being the number one thing to do - if you have not already. Being able to run low tire pressure will do more than just soften the ride (like suspension parts) as it also improves traction.
Bars are a very personal choice - I really like my flared low-drop bars (Ritchey VentureMax). You want to be really comfortable in the drops as it is the best position for tricky descents.
Quoted: 445 Post(s)
Liked 1,040 Times
I was wondering if I could get some advice on forks? My current gravel bike is an alloy frame with steel fork, hydraulic brakes and running a QR hub on the front wheel. Is it worth getting a carbon fork to lighten the weight? Also is there any recommendations on what CF forks to look at? Thanks!
Quoted: 67 Post(s)
Liked 49 Times
Whisky carbon forks are well regarded and they make QR with disc brake mounts.
Likes For Chilepines:
Redshift ShockStop stem
After setting up my bike tubeless, the next most significant and worthwhile upgrade I made was buying a Redshift ShockStop stem. The ShockStop stem completely transformed my bike (2020 Specialized Diverge Elite E5). I’ve never seen a negative review of the ShockStop stem anywhere (though many of the positive reviews are recreational riders using the high-rise version).
Redshift already sells a +30 degree version of the ShockStop stem. That's not enough up angle?
After setting up my bike tubeless, the next most significant and worthwhile upgrade I made was buying a Redshift ShockStop stem. I’m VERY surprised that no one mentioned this one item. The ShockStop stem completely transformed my bike (2020 Specialized Diverge Elite E5). I’ve never seen a negative review of the ShockStop stem anywhere (though many of the positive reviews are recreational riders using the high-rise version).
Likes For pipeliner:
Sunshine
Quoted: 10947 Post(s)
Liked 7,473 Times
Things you need to know to change your fork-
- what size headtube do you have? Does it only handle a 1 1/8 straight steerer tube or is it larger and can handle a tapered steerer tube? This matters since most modern gravel forks come with a tapered steerer. There are some carbon forks with a straight steerer tube though.
- what is your current forks axle to crown measurement? To replicate your current steering feeling, you will want to buy a replacement fork with that same measurement, or close to it.
- what is your current forks rake? Again, matching this will help make steering feel the same.
Post these numbers here if you can find em.
Sunshine
Liked 7,473 Times
Straight steerer forks can still be good- Ritchey actually only made straight steerer forks until very recently, and most of their fork offerings are still straight steerer.
Ritchey, fixation sparta, and Soma have qr disc gravel forks.
a lot of thru axle wheelsets come with adapters for QR too.
As for the tapered fork...meh. tapering the steerer stiffens the fork, but I've ridden straight steerer steel forks and a tapered steerer carbon, but can't say ive ever felt like any of the bikes had a noodly flexible front end.
Likes For mstateglfr:
