Cost of shipping, Peugeot mixte
Not lost wanderer.
Quoted: 885 Post(s)
Liked 989 Times
Free frame, lots of rustina. Headset is good and the BB spins well.
Just pay shipping. I will try to get the crankset off, not sure how yet.
Given away.
Given away.
Quoted: 1372 Post(s)
Liked 1,751 Times
Separate the fork from the frame and remove the crank and bottom bracket. Get a bike box and cut it down to just fit length, width and height to get the best shipping price. It takes a while to do this but the saving is dramatic as compared to leaving the fork attached.
Not lost wanderer.
Quoted: 885 Post(s)
Liked 989 Times
The fork easily comes off, not sure about the crank.
Quoted: 1106 Post(s)
Liked 1,326 Times
If it's been on since the factory it may be easier than the exterior would suggest; the pins would have been installed clean and correctly. Get appropriate tools (press if you can,hammer and punch and support otherwise) and have a go. For packing you only need to do the drive side,
Likes For oneclick:
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Likes For thumpism:
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,390 Times
Not lost wanderer.
Quoted: 885 Post(s)
Liked 989 Times
So nlerner is even saving on shipping, I am heading to the Boston area this weekend.
Liked 1,326 Times
That is a prime candidate for an oxalic acid bath.
I have done this so often recently I built a box, it's about 4 feet long, 7 inches wide, and 24 inches deep.
Single sheet of 1/4 ply each side, 1x8 for the bottom and ends, all screwed every 6 inches and braced along all the corners, and I made a removable brace to put across the middle when filling to keep the sides from bowing out too much.
Got a single sheet of 6 mil vapour barrier folded into the box to make a water-tight liner, fiddly folds they were.
I put about 8 inches of water in the box, put the frame in a BIG tough garbage bag in the box, put about a gallon of oxalic acid solution in the bag, keeping the top of the bag uppermost.
Then I put the brace on top, hang the frame in the bag from the brace, and fill the box with water.
This keeps the oxalic acid concentrated inside the bag, but allows it to contact the whole frame.
You need to be careful putting the frame in the bag not to puncture it, the whole point is it is a barrier keeping the acid and water apart.
For that frame I'd give it at least a day, think it will take more - but at the end, it'll be WHITE.
And afterwards, carefully lift out the bag and frame; if you can get the frame out without losing the acid, put it over a bucket and snip a bottom corner with scissors, save it for next time.
Liked 1,326 Times
This keeps the oxalic acid inside the bag, but makes sure it contacts the whole frame.
Quoted: 3808 Post(s)
Liked 6,681 Times
I’ve done the oxalic acid bath thing previously. I used half of a cardboard box, sized for the frame, and lined it with heavy duty plastic. A problem was what do to with that “tub” once the process was complete. It was too heavy to lift and dump in the sink; too low to siphon. I think this time I’ll use a smaller container and go one tube at a time or try the soaked paper towels wrapped in Saran method.
Likes For nlerner:
Liked 1,326 Times
It sounds as if your box had the frame lying flat. I did that the first time, built a frame about 8 inches high on a 4x8 sheet of ply - the frame just large enough to contain the bicycle frame plus an inch or so. I lined the thing the same way (was easier) and filled it as was with the acid. The I put bricks in between the frame tubes to take up space and make the acid level rise high enough to cover the bike frame. It worked, but now I have the vertical arrangement I like that much better. For a one-off a flat cardboard box tub (with bricks) sounds like a great simple solution.
Old bikes, Older guy
Location: Fiscal Conservative on the Lefty Coast - Oregon
Bikes: A few modern, Several vintage, All ridden when weather allows.
Quoted: 250 Post(s)
Liked 165 Times
Kiddie pool also works well. I’m fortunate & have a a sloping lot. One side has a raised section held back with a 3 foot retaining wall. I just put the kiddie pool up there. Makes siphoning easy.
Cheers,
Van
Cheers,
Van
Remember: Real bikes have pedals.
...and never put a yellow tail on a Red, White and Blue kite!
Not lost wanderer.
Quoted: 885 Post(s)
Liked 989 Times
Delivered today, good luck Neal.
Edumacator
Quoted: 2436 Post(s)
Liked 3,119 Times
It'll buff right out...
Likes For jdawginsc:
Liked 6,681 Times
Likes For nlerner:
