Shim 105 STI Lever and Canti breaks
Old 04-15-20, 09:50 PM
Dord
So I have Shim 105 levers to install on a 11sp Shim drivetrain.
I have a new fork thats a caliper/canti/disc combo and a new frame that is only canti. I've seen some posts about drilling the hole to accept rim on a frame but the reach would need to be almost 70mm.
Does anyone have any recommendations about what canti breaks I can use on the rear wheel?! There is a lot of conflicting info about.
This is my first build and I have definitely made some mistakes already without actually getting around to the building with my decision on frames etc etc. So I would like to see if I can make this work before considering switching out the frame!
Many thanks for the help!!
Dord is offline
Old 04-15-20, 10:04 PM
base2
Doesn't brain good.
base2's Avatar
Bikes: 5 good ones, and the occasional project.
Quoted: 1239 Post(s)
Liked 916 Times in 537 Posts
By: "Shim," I assume you mean Shimano.
By: "Breaks," I assume you mean brakes.
If I have the correct understanding:
Cantilever brakes have the same pull ratio as road brake levers as road disc brakes...So yes, all your parts road Shimano 105, road disc brakes, cantilever brakes, road caliper brakes are compatible & will work together.
Shimano BR-CT91 are about $14. For the rear, this is a given.
For the front, since you have the option, I like TRP Spyre. But another BR-CT91 would work. Pick according to your wheel.
Where you run into issues is with linear pull v-brakes, mountain disc brakes & road brake levers. Not enough lever travel to to make pads contact & still have enough to actually brake with. Or vice/versa with road brakes & mountain levers. Super firm brake & not enough leverage to effect a stop.
Neither is your case.
Install & have fun.
base2 is offline
Old 04-15-20, 10:15 PM
Dord
Install & have fun.
Thanks Base. You were correct in deciphering my abbreviation and typo. Good info re linear pull.
I shall look for some Shimano canti brakes and enjoy!
Dord is offline
