Titanium Bike Build Ride Report
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
Took this bad boy out for a ride today. 26 miles .....my first ride since mid October.
First the good things.
1. Ride quality is excellent.
2. A few adjustments during the ride and the shifting was excellent.
3. Saddle height was spot on and the saddle was comfortable.
4. No weird squeaks or unexpected rattles save one.
Minor issues.
1.A slight sound from the front wheel under braking. I think its where the wheel hoop is joined and read it is a known quirk of the C24s and diminishes over time. We will see.
2.Derailleur may need some more adjustments as the cable stretches.
3. The seat shifted (nose tilted up a few times on some bumps) despite the clamp being tight. I will have to figure that out.
4. The handlebars are lower than my Domane and this is a more difficult position for my rebuilt neck. Also may have had issues due to my first ride after a long layoff.
I am very happy with how it turned out. For those who haven't read the build thread it's a Litespeed Classic frame from 2001 with all new DA 9100 components. I even put the decals on! It has DA C24 Carbon/Aluminum wheels. Padded Bontrager Isocore bars on a blendr stem and a Selle Italia Boost Endurance seat. Chris King BB and headset..
The bike is super smooth and super quiet. I'm used to the noisy hub on the Domane. This one is very subtle. Its quiet as a mouse with sore feet when pedaling. The Dura Ace pedals are also quite nice (obviously !!)I love riding bikes I have built from the ground up and its been a long time since I have done it.
Thanks to BF for encouragement and a few laughs. Last year at this point I was in a rigid cervical collar with a broken neck and non weight bearing on a shattered leg. Its no overstatement to say that cycling has been a major part of my recovery. I put down 1500 miles last year and when I started my left leg was a twig. It us still a tad undersized but it does its part. My ortho surgeon was ecstatic that I didn't have a limp.
Thanks for looking.
Minor issues.
Thanks for looking.
Likes For Rdmonster69:
Quoted: 1109 Post(s)
Liked 1,200 Times
BUT... it won't work unless you are interested in buying a new fork and cutting the new steer tube accordingly longer.
I had a similar issue with the '96 Classic I built up "modern-ish" (Sram Force 10 speed, etc). The handlebars were quite a bit too low in spite of maximum 40mm spacers below stem allowed by the fork spec. Turns out I wanted to buy a new fork anyway (to replace a perfectly functional, but rather heavy and kind of ugly aero fork with a metal steerer), so I bought a very nice and light full CF Columbus Minimal fork and am happy I invested in a fork for my new-to-me titanium bike. I figured that the frame deserved a top notch fork and I got the double value of being able to raise the handlebars.
PS: I re-brushed my Classic and then applied the same decals as yours - I think they're '01 Classic decals? I just happened to like them better than the original '96 ones that were also available. I searched the Litespeed decal pages and they were the ones I liked best that had the same basic features as the original - iconic yellow Litespeed decals on the downtube, and the Lynskey signature. In the name of transparency, I made a little label to go alongside the "Classic" decal on the top tube so it now says 96 Classic (the "96" being small and unobtrusive).
perhaps the slipping seat post is trying to tell you something
swapping on a straighter seat post that moves you closer to the bars could be less aerodynamic, but may be easier on your neck
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
I have made several adjustments during the build for a few things .....for example. The reach to the bars is similar to the reach on my Domane as far as top tube length. I achieved this by using a set of bars with modestly less reach. Otherwise they are identical to those bars. They are lower but similar in reach from the seat to the hoods. I also ran the sear very slightly forward in the seat post clamp but well within the limits on the seat rails. I can adjust it a little. There is also the possibility that I didn't have the seat clamp properly tightened : /
The Litespeed is slightly longer in reach than my Trek 2.3 but the handlebars are they same height. Its a 60 and the 2.3 is a 58 as is the Domane.
A word on comfort and cycling for me .....there will never be any comfort. My neck is a wreck. (Sweet rhyme). It was severely broken in December 2020 with attendant basilar skull fractures and snapped ligaments. I am held together with screws, rods and luck. A higher handlebar position only does so much. I have bone spurs in every joint in my neck. I made a mistake by making my first ride this year 26 miles instead of 15 or 20. My joints, muscles and the like aren't ready like they were at the end of last season when I was able to do a few 60 milers. That being said my neck is telling me I can ride again today and I WILL keep it around 20 and reassess the seating position etc of my new build.
Bikes: Grazzini,Litespeed,and Pinarello
Quoted: 33 Post(s)
Liked 92 Times
Beautiful bike. I’m so glad you used Dura-Ace. Your bike was worth putting a top end group set on!
I cringed when you described how your neck is held together, you are one tough customer! Good luck and enjoy your great bike
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
Second ride .....neck feels much better so I think I just need to build up my bike stamina. No movement on the seat and its super comfy. Shifting was absolutely perfect so no new adjustments for now. Still a ticking under braking from the front ...... about 90% sure its the seam in the brake track.
Bike got some appreciative looks from my fellow riders ..... no mistaking Titanium!!
I did have a flat today .... perfect puncture right through the tread. Glad I packed a spare tube because it was too darn cold to futz around with a patch.
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1126 Post(s)
Liked 253 Times
get a stem with a greater degree of angle, or put spacers in to bring the stem up if you find yourself with problems later.
You might need a better seat post clamp, if you over tighten the one you have you will probably break the clamp at the treads. Ask me how I know.
My only concern is, did your doctor ok you to ride a bike? Most crashes involve the head and neck, I would be concerned about something really bad happening to the rods in your neck as a result of a crash, and of course the neck itself. It seems like to me you're taking a chance of becoming paralyzed? or did the doc say that could never happen?
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
Now that I am fully recovered he says he understands that life has to be lived and I should understand the risks. That I am more likely to suffer a neck injury if I have an accident that stresses my neck. I choose to live much the same as I did before. I gave up dirtbike dreams and don't wheelie my sport bike or drag knees anymore, I bought an airbag vest, I ride my bike pretty careful. But I will live life.
gratuitous neck pic .....now thats some serious Titanium there
Quoted: 1561 Post(s)
Liked 1,734 Times
Those seatposts with the round cylindrical clamping fixtures are not as foolproof as the good ole fashion two-bolt pedestal clamps.
Also- is that a Ti seatpost? Probably not the best idea to have a Ti seatpost in a Ti frame.
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,993 Times
I can see the first point that is fair but ti on ti is not bad if you follow proper seatpost maintenance.
Likes For veganbikes:
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
What would be the problem with a Ti seatpost in a Ti bike ? Its an option from most Ti bike manufacturers. It was rock solid after the last ride so I dont think I had it torqued down enough.
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
What is wrong with a ti seatpost in a ti frame that would radically change from carbon or aluminum or steel in the end treat it like any seatpost and make sure it has the proper grease or paste on it and check it with some regularity to make sure it doesn't seize.
Liked 1,734 Times
There is a tendency for Titanium to 'self-weld' together. As Veganbike said- you can prevent this from happening with grease, etc. But the safest thing to do would be to use run a carbon seatpost there.
Clark W. Griswold
Liked 3,993 Times
Yeah but in the end with a little bit of removing the seatpost once and a while and checking things, maybe cleaning and re-greasing or using anti seize I wouldn't worry too much. If you are a triathlete who is serious enough to do bathroom stuff on your bike and also do the normal never really take care of it then yeah I might do something different but removing a seatpost once in a while ain't so bad for the potential extra comfort and safety of having metal posts rather than crabons.
Quoted: 1163 Post(s)
Liked 442 Times
Rdmonster69 - just curious about the amount of setback on that titanium post: from the photo it looks like a significant amount of setback like a person with a really long torso might use. For most folks with more normal proportions, I’m thinking just a slight setback might be more natural / comfortable right out of the box, especially considering your neck issues.
Can I ask what the top tube length on the Litespeed frame is? And can you share how tall you are?
Klaatu..Verata..Necktie?
Quoted: 10424 Post(s)
Liked 11,898 Times
They make titanium press-fit head tube extenders for press-fit type head tubes which allow you to use a fork with a longer steer tube and get the handlebars up higher without exceeding the maximum spacer allowance spec'd by the fork. I believe Litespeed might make one for 1-1/8" head tubes, but my head tube is 1". I was able to find a 1" 20mm extender from Ti Cycles. I took out the Chris King headset, pressed in the extender (same as pressing in a headset) and then cut my new fork (see below) steer tube accordingly and pressed the headset back in (all with DIY tools). If you look close, you can see that there's an extender in place, but it looks pretty OEM because the ti matches, and you don't even notice it from a normal viewing distance. You might check that out.
Liked 1,200 Times
Litespeeds seem to have short headtubes for the size. It's one reason I passed on a bunch of 57cm frames that showed up various places, and waited for an Ultimate in 59cm to show up. Since it's a '95, it also came with a threaded fork, and as luck would have it, a Chorus headset which has a tall stack height, so a standard stem puts the bars in the right place for me.
My 96 Classic has a top tube that is within my size range, but the head tube is very short. I maybe should have gotten a larger size - with a longer top tube requiring a shorter stem, but with a taller head tube. Luckily I stumbled on the press-fit titanium extension option as a quick way to remedy the situation, since I was planning on replacing the fork anyway
If the frame had come with the original threaded fork and headset, I would have just used a tall Nitto quill stem (which I happen to have). And, knowing the head tube was short, it was my vague plan to convert back to threaded and do that. But the path of least resistance at the time was to go with the readily available immediate solution: the 1" X 20mm head tube extension from TiCycles, and 1" Columbus Minimal all CF fork. It was easy and quick, but not exactly cheap - but worthy of the of the beautiful frame. Converting to threaded with a "worthy" threaded steel, ti or CF fork - not one of the cheap steel ones that are readily available - wouldn't have been any cheaper I don't think. Plus I would have had to replace the nice Chris King threadless headset it came with!
Liked 442 Times
I’m 5’11” & ride this little titanium frame that has a 54cm virtual top tube length:
The head tube is like 135mm. The 13cm stem does have a 5 degree upward rise to help if I have a sore back.
Likes For masi61:
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
Rdmonster69 -
The reach to the bars is a little bit more than my Domane. I'm gonna give it a few more rides as is but may swap it out for one of my other posts if it still bothers me. My mtb post and older Trek seem to have less set back.
Liked 253 Times
I appreciate the suggestion and the concern ! I think I just need to get my body in riding shape to mitigate some of the issues. I will see if my Domane is easier on me pretty soon. As for my neck .... I have a super active lifestyle. When I had my first post surgical appointment with my Neurosurgeon I ran down the list of my favorite ativities like Cycling, Motorcycling, Jet Skiing, Dirtbikes etc. They were all in hisdry professional tone "Not Recommended". He tells me my neck is at risk for injury since it is fused and doesn't rotate very much.
Liked 1,200 Times
Both Litespeed and Lynskey (The only two I'm familiar with) sell titanium seat posts for their titanium bikes and have very simple installation for ti-ti connections: I was told by both to use copper anti-sieze. No matter what combination of seat post to frame material you use, you need to use something aluminum to metal: grease or it might sieze; CF to anything: friction paste or it might slip and/or sieze; titanium to titanium: copper antisieze. So there's no difference in difficulty in keeping a titanium from siezing than other metal seat posts or keeping a carbon seat post from slipping.
Likes For Camilo:
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
That plating looks nasty. I have two small straight TI rods in my lower back, I have fallen and crashed the bike once and landed on my back doing something and fell, and nothing happened to it, but it's not as nasty as yours is. I hear you on living your life, that's why I still ride my bike regardless of the rods. I just brought it up for you to make sure you knew the risks, for you the risk is far greater than for me from the looks of it. As long as you are aware of the possible outcome of a crash gone bad, and you accept that, then like you said, you need to live your life, for better or for worse.
The last year and change taught me how borrowed our time on earth is. When you are sitting in your truck spitting out broken glass and wondering if your truck is gonna explode before ems can cut you out you don't take anything for granted.
I'm gonna be careful for sure....but ride motorcycles and bicycles.
Liked 1,734 Times
It's a matter of what is the worst case scenerio. With the carbon post the worst case scenerio is the post slipping. With the Ti post the worst case is seizing. Which one would you rather deal with?
