Bottom Bracket Removal Question
Old 04-30-22, 08:32 AM
JRD
JRD's Avatar
Bikes: 2014 Giant Defy Composite with Campagnolo Record 11 Groupo - 2015 Giant Talon 4 27.5
Quoted: 20 Post(s)
Liked 19 Times in 10 Posts
I have a question...Which direction will loosen this bottom bracket? First time I have ever serviced one and this is a new learning experience for me. Thanks in advance for the help! I am thinking that they loosen going toward the rear of the frame?
1995 Bianchi Trofeo
JRD is offline
Old 04-30-22, 08:52 AM
Rolla
Groucho Marxist
Quoted: 1230 Post(s)
Liked 3,042 Times in 1,328 Posts
Ah, the miracle that is Google:
"The common threading for bottom bracket shells is called “English.” The left-side cup is a right-hand thread direction, which tightens clockwise and removes counterclockwise. The right-side (drive-side) thread is a left-hand thread, which tightens counterclockwise and loosen clockwise."
"The less common Italian has both left and right sides with right-hand threading. Both sides tighten clockwise and loosen counterclockwise. Italian threaded cups will have marking stating '36x24.'"
https://www.parktool.com/blog/repair...ation-threaded
Rolla is offline
Old 04-30-22, 08:53 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1923 Post(s)
Liked 2,837 Times in 1,451 Posts
The NDS will ALWAYS be right hand thread, so normal right-tight left-loose. The DS...who knows on the frame. Measure the wide of the bb shell and it's 68mm then you have an English bb so it's left hand thread. If it's 70mm then it's Italian and will be right hand thread.
cxwrench is online now
Likes For cxwrench:
Old 04-30-22, 09:23 AM
JRD
JRD's Avatar
Quoted: 20 Post(s)
I love this place lots of great information and quick too. Thanks for the help. Is there anything I need to do to this sealed unit before I reinstall?
JRD is offline
Old 04-30-22, 09:34 AM
delbiker1
Mother Nature's Son
delbiker1's Avatar
Quoted: 694 Post(s)
Liked 1,011 Times in 593 Posts
Clean it really well, grease on the threads, good to go. While your at it, clean the inside of the bb shell along with the threads. You can put a thin layer of grease on the inside surface.
delbiker1 is offline
Likes For delbiker1:
Old 04-30-22, 09:35 AM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1891 Post(s)
Liked 669 Times in 391 Posts
Hmmm.... I've never seen a square taper axle with marks on the end like that. Was someone ponding on the axle with a hammer?
Why did you need to take it off in the first place?
trailangel is offline
Old 04-30-22, 09:45 AM
MudPie
MudPie's Avatar
Quoted: 98 Post(s)
Liked 98 Times in 76 Posts
It looks like you successfully removed the BB. Was it English or Italian threaded? Did you remove the drive side cup cw or ccw? I would assume it's Italian threaded based on the frame brand, but that's just an assumption.
MudPie is offline
Old 04-30-22, 10:05 AM
JRD
JRD's Avatar
Quoted: 20 Post(s)
It was english threaded drive side was cw
JRD is offline
Likes For JRD:
Old 04-30-22, 10:08 AM
JRD
JRD's Avatar
Quoted: 20 Post(s)
To my knowledge no one was pounding on it. I just wanted to gain some experience and this bike is my learning bike for a complete tear down and rebuild. I also considered repainting the frame The Bianchi Celeste color and the bracket would have to be removed for that. I am still considering a repaint and new decals just to gain the whole learning experience.
JRD is offline
Old 04-30-22, 10:11 AM
JRD
JRD's Avatar
Quoted: 20 Post(s)
Thank you for that info!
JRD is offline
Old 04-30-22, 02:24 PM
SoSmellyAir
Method to My Madness
Bikes: Cannondale Synapse, Cannondale CAAD4, Trek FX 2
Quoted: 983 Post(s)
Liked 635 Times in 482 Posts
If the bottom bracket is in good condition, then no. If it does not spin smoothly, then you might as well replace it now that you have removed it. (An excellent Made in Japan Tange Seiki BB is only $30: Tange LN-3922 Square Taper Bottom Bracket – The Bikesmiths, and can often be found even cheaper on eBay.) Otherwise, you may ding the nice new paint job you are about to put on the bike if you have to replace the bottom bracket in the future.
SoSmellyAir is offline
