Brooks width, you make the call.
Old 09-16-14, 09:26 PM
DOS
DOS's Avatar
Quoted: 251 Post(s)
Liked 69 Times in 56 Posts
I will probably get flamed for posting since much has been said on the subject, but I have read everything I can find about how to determine what width brooks to get and find no clear consensus. Was thinking of getting a 150mm swift for a road bike I ride in afairly aggressive position ( 5cm drop, fast group riding) but guidance on width is all over Map so I am opening up to a vote here as to whether it's too narrow for me and my 110mm sit bones
Backstory
I have a Brooks pro that I love, at 160mm, seems to fit my 110mm sit bones just fine on a bike with relatively upright set up (shortish reach with more moderate drop from saddle to handlebar than my other bike). This makes sense to me because once I account for the 1.5 cm on either side of the saddle taken up by the cantle, the rideable width is 130mm, giving me a cm on either side to ensure my sit bones rest on leather not cantle. By extrapolation, a 150mm swift would appear only to provide 120mm ridable surface area. Leaving me only 5mm on either side before contacting the cantle. this seems kinda tight to me.
Rivendell seems to think everything Brooks makes beside B17 (170mm) is too narrow Brooks Saddles from Rivendell Bicycle Works, while this site indicates Swift is too narrow for anyone with sit bones wider than 95mm
Leather saddles: Brooks, Lepper, Selle Anatomica, seat covers, saddle maintenance, etc..
But others testify to riding comfortable on a swift despite relatively wide sit bones.
So what say you BF, too narrow or wide enough for aggressive rider with 110 sit bones?
DOS is offline
Old 09-16-14, 10:16 PM
JTTDF
JTTDF's Avatar
I am impressed and somewhat bemused that you actually measured the distance between your ischial tuberosities. How did you do that? Is this is something commonly done nowadays?
Have you tried your Brooks Pro to see if it is comfortable on the more aggressive bike? Could you possible borrow a Swift to see if you like it? Personally I prefer empirical evidence over theoretical.
JTTDF is offline
Old 09-16-14, 10:30 PM
peugeot mongrel
peugeot mongrel's Avatar
Bikes: 84 Coppi - 94 Hujsak - 82 Colnago Superissimo - 78 Ciöcc - 70's Galmozzi - 73 Lambert - 78 Motobecane Grand Record - 87 Peugeot Triathlon - 66 Peugeot H-40 - 78 Peugeot U08 - 85 Raleigh C-40 - 82 miyata 310 - 82 Univega - 85 Sterling SIS Mixte
Quoted: 37 Post(s)
Liked 22 Times in 12 Posts
I really like my Swift. I like it better than my Pro. Both are very comfortable to me on long and fairly fast rides. Both are on a fairly aggressive set up. My B-17 is a little wider than I like. I'm thinking I might lace it & see if it works better. I'm 160, 5'10" & old with no clue the width of my sit bones.
peugeot mongrel is offline
Velocivixen
Velocivixen's Avatar
Quoted: 399 Post(s)
Liked 29 Times in 22 Posts
@JTTDF- many bike shops have a gel device you sit on and it measures your ischial tuberosities. Very common.
@DOS - go with what you think. Actually if you order from Wallingford bikes they have a generous return policy on their Brooks.
Velocivixen is offline
Old 09-16-14, 11:03 PM
JTTDF
JTTDF's Avatar
Thanks Velocivixen. I didn't know that.
JTTDF is offline
Old 09-17-14, 12:03 AM
ofgit
Senor Puppet
ofgit's Avatar
Bikes: Mostly '80s MIJ steel.
I am comfortable on the 175mm wide unpadded B-17s on some of my bikes and am also comfortable on the 130mm wide padded WTB Rocket Vs on a couple of other bikes. Have not had my sit bones measured.
Old Fat Guy In Tights.
ofgit is offline
Old 09-17-14, 01:38 AM
Big Block
Quoted: 183 Post(s)
Liked 95 Times in 53 Posts
the topic is addressed in this article
The Four and a Half Rules of Road Saddles
with a Brooks saddle, the normal rule is varied by
Brooks and similar leather saddles are constructed with a rigid steel cantle plate supporting the perimeter of the leather top; you don’t want to sit on the cantle plate, so consider the area between the edges of the cantle plate the effective seating surface, and measure there.
I have been researching for a cycling friend with very narrow sit bones.
Big Block is offline
Old 09-17-14, 03:36 AM
DOS
DOS's Avatar
Quoted: 251 Post(s)
[QUOTE=Big Block;17137538]the topic is addressed in this article
I have seen the article and the approach is what I have been following. On top of that guidance, other sites seem to advocate, making sure the "effective seating surface" is significantly wider than the sit bones. For example, one of the links I posted earlier says
"There needs to be some room to deform so I think you need to deduct at least 2cm from (the effective seating surface), 1 cm from the left and 1 cm from the right where your sit bones can come so that deformation and a comfortable riding position is possible."
The so called effective surface of a Pro is 130, the Swift is 120, and I am 110. I fit within the surface of both but barely on the Swift.
As Velocivixen points out, Wallingford and others have very generous exchange so it's hard to go wrong. At the moment, my heart wants the very pretty Swift (also I like variety) my head says go with what I know works, which would be Pro.
DOS is offline
Old 09-17-14, 03:43 AM
DOS
DOS's Avatar
Quoted: 251 Post(s)
There are also at home approaches on the internet. I didn't use the bike shop gel device.I did measure distance across the very apparent deformations I have in an old leather saddle and then compared by doing this
https://m.youtube.com/watch?v=E7j9LUVJrjA
I doubt my measurement is precise but I am somewhere north of 105 and south of 115.
DOS is offline
Old 09-17-14, 04:53 AM
Road Fan
Road Fan's Avatar
Quoted: 1595 Post(s)
Liked 498 Times in 377 Posts
[QUOTE=DOS;17137602]
Your measurement differs depending on how tilted your pelvis is. If you ride upright and never slouch, your contact points are widely spaced. If you ride in a very aggressive position with a straight back, your pelvis is strongly tilted forward. The contact points are closer together in this case. I think this is a considerable part of the apparent contradiction.
My normal ride is about 45 degrees back angle with pelvis nearly in-line with my back. A Pro can work for me, but it's not flat enough laterally. My favorite is a Selle AnAtomica set rather stiff, which tightens the top surface and loosens the skirts. This effectively narrows the thigh rub area while giving more support (improves flatness viewed from the side) where the contacts are. If I lower my bars a few cm, my B17N Imperial starts to feel very good, but I do experience pubic bone pressure and ... other issues.
Sorry for the TMI, but this is all to illustrate the effect of pelvic angle in my experience.
The ischials are IMO like a pair of crescents where the front corners are closer together than the rear corners. If you sit on a flat hard horizontal surface your contact points move together as the two crescents are rotated so the front corners get closer to the flat surface. That's my mental model. I'm an engineer and not an anatomist, so go with my picture, not my attempted medical (???) terminology.
Road Fan is offline
Old 09-17-14, 05:38 AM
pastorbobnlnh
Freewheel Medic
pastorbobnlnh's Avatar
Bikes: Snazzy* Schwinns, Classy Cannondales, Aero Lotus & a Lonely '83 Santana Tandem (* Ed.)
Quoted: 1027 Post(s)
Liked 941 Times in 489 Posts
I regularly ride a Professional, Swift, Colt, B5N, B15, and B17 on my various bikes and all are comfortable. I have no idea what my sit bone width happens to be. In comparing the first four Brooks saddles I listed, I find no difference. In a blind ride test, I doubt I could tell which is which.
On the last two, the B15 is the widest followed by the B17 and I can notice the difference on these. Which is not surprising.
Bob
pastorbobnlnh is offline
Old 09-17-14, 05:53 AM
clubman
Youngman Grand
clubman's Avatar
Quoted: 2149 Post(s)
Liked 1,608 Times in 1,016 Posts
I 've had the near identical experience except that I don't have a Colt. I find the Swift to be identifiable as I suspect the Swallow would also be. Old Pro's and B17's are faves.
clubman is offline
Old 09-17-14, 05:58 AM
stevel610
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 327 Post(s)
Liked 385 Times in 200 Posts
I was going to suggest Wallingford as well due to the return policy.
First though, is there anything stopping you just putting the Pro on the other bike and riding it? Try it out and see how comfortable it is for you.
I have both a B17 and a Pro. The B17 is comfortable but the Pro a little more comfortable.
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
stevel610 is offline
Old 09-17-14, 06:24 AM
SJX426
SJX426's Avatar
Quoted: 1364 Post(s)
Liked 1,552 Times in 817 Posts
I have a 41 year old Pro with small rivits that fits like a glove. Unfortunatley it was not taken good care of by me and is starting to crack and flake off the surface. I will ride it until it falls apart!
[IMG]P1000087 by superissimo_83, on Flickr[/IMG]
To that end, I bought a well used Pro with the large rivits and use it on my commuter. It is more comfortable now than in the beginning but the rivits have bothered me in the past until I hammered the endges down. It is very tolerable and better than any other saddle options I have available.
Another CL find was a near NOS (in the box with the adjustment tool and cover) Swift. I mounted it on the Colnago with the SR post. I could not get the nose down far enough to get comfortable. Last week end I move the saddle forward and the problem is gone. It is not fully broken in but it feels pretty good. I would like to have a Swallow but can't swallow the cost without knowing if it will fit comfortably, hence the reason for obtaining the Swift.
[IMG]P1010190 by superissimo_83, on Flickr[/IMG]
I don't know my SB dimensions, but(t) would like to find out. I try to set all the riding dimensions to be the same within reason. The tandem is close to the Italian bikes as well as the RockHopper. Only crank length varies.
The old Pro sold me on Brooks and it is hard to let go. None of my other saddles are nearly as comfortable. The closest one is the Flite Ti which is only good for about 30 miles.
SJX426 is offline
Old 09-17-14, 07:38 AM
rootboy
rootboy's Avatar
Quoted: 554 Post(s)
Liked 123 Times in 72 Posts
Hang on,
I gotta go measure my itchy tubers.
Never checked before.
rootboy is offline
Old 09-17-14, 08:14 AM
Velognome
Get off my lawn!
Velognome's Avatar
Bikes: 1917 Loomis, 1923 Rudge, 1930 Hercules Renown, 1947 Mclean, 1948 JA Holland, 1955 Hetchins, 1957 Carlton Flyer, 1962 Raleigh Sport, 1978&81 Raleigh Gomp GS', 2010 Raliegh Clubman
Quoted: 93 Post(s)
Liked 85 Times in 43 Posts
Rode a B17 for years, 1" drop to the bars...felt great until I got a Swift....Ooooooo it was like no saddle at all, ride a all day and forgetaboutit. Got back on the B17 and it felt I was sitting on a hammock, so comfy and huge! Same thing happened with my Swallow, B117 Narrow, Pro and Flyer.
My conclusion is "sit-bones s_it-bones", it's all about the configuration and getting it set up right. So don't spend too much time reasoning on which one is the best. Brooks Saddles is like bananas...by the bunch, and be done with it.
Velognome is offline
Old 09-17-14, 09:13 AM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3644 Post(s)
Liked 2,092 Times in 1,327 Posts
I think the top shape is more of a confound than the width would indicate. I had a not-awesome experience with a Pro (which should be the perfect width for me, but the top was too rounded to agree with my undercarriage), but love the B17 Narrow (which is even narrower than the Pro) I now have on that bike. It's just wide enough to support my sit bones, but flatter on top and narrow enough everywhere else not to chafe.
I'd be interested to try a Swift or Colt, based on that, but haven't gotten around to it.
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 09-17-14, 09:30 AM
Michael Angelo
Michael Angelo's Avatar
Bikes: Treks (USA), Schwinn Paramount, Schwinn letour,Raleigh Team Professional, Gazelle GoldLine Racing, 2 Super Mondias, Carlton Professional.
Quoted: 77 Post(s)
Liked 20 Times in 17 Posts
I like my Brooks pros, and B17. Narrow saddles are not for me, The most comfortable saddle I have is a Selle SMP plus it's 159mm wide. Very similar to my Brooks pro.
Michael Angelo is offline
Likes For Michael Angelo:
Old 09-17-14, 10:45 AM
Lascauxcaveman
Lascauxcaveman's Avatar
Quoted: 1591 Post(s)
Liked 533 Times in 306 Posts
Originally Posted by rootboy View Post
I gotta go measure my itchy tubers. ...
If they're itchy, I have an antifungal cream I can recommend for you
Lascauxcaveman is offline
Old 09-17-14, 11:34 AM
squirtdad
squirtdad's Avatar
Quoted: 1829 Post(s)
Liked 1,576 Times in 955 Posts
Can't comment on widths etc, but fwiw here is my experience
I ride a B-17 in a very upright position on my commuter/utility bike..... it is simply fantastic
I tried a B-17 Narrow imperial on my road bike. (miyata 1400 bars just a little lower than seat) this did not work.
I looked at the B-17 narrow compared to my sella italia turbo and the top shape of the b17 n was way less rounded.
I got a swift and put it on my road bike......it is great. Chose the swift because it looked closer in top shape to the the turbo than the pro or the swallow
I kinda eyeballed/measured the indents in the b17 and they looked like they would work with the swift width...the did
so for me top shape is more important than width
(looking for Torpado Super light 56,57 or so)
squirtdad is offline
Old 09-18-14, 04:51 AM
rhm
multimodal commuter
rhm's Avatar
Quoted: 1880 Post(s)
Liked 436 Times in 278 Posts
Just so. Therefore the width of the saddle should be determined by the angle of the pelvis when riding, rather than the width of the sit bones. If you like your handlebar several inches lower than your saddle, you'll want a "narrow" saddle. If you want your handlebar higher, you'll want a correspondingly wider saddle.
I put the word "narrow" in quotation marks because Brooks used to make both the B.15 and B.17 models in two widths, "narrow" and "standard." Wrights used the same frames; so a "narrow" Wrights saddle (the ubiquitous W3N and Swallow models) is the same width as either a B.15 or B.17 "narrow." The "professional" was wider than a "narrow" and a "standard" was wider still.
www.rhmsaddles.com.
rhm is offline
Old 09-18-14, 05:08 AM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1891 Post(s)
Liked 669 Times in 391 Posts
Time for ya'll to check in:
International OCD (Obsessive Compulsive Disorder) Foundation - What Is OCD?
trailangel is offline
Old 09-18-14, 05:22 AM
Bikedued
Bikedued's Avatar
Quoted: 159 Post(s)
Liked 25 Times in 20 Posts
I wanted a Swift until I got one. I was either sliding off forwards with achey forearms from holding myself up, or going numb. There was no in between for me, and it was an expensive lesson. A Pro or B.17, I can ride for hours pain free.,,,,BD
So many bikes, so little dime.
Bikedued is offline
Old 09-18-14, 05:28 AM
rootboy
rootboy's Avatar
Quoted: 554 Post(s)
I like the Professional.
Always have.
Fits my scrawny azz just fine.
rootboy is offline
Old 09-18-14, 06:06 AM
Fred Smedley
This ^, the Swift sucked, the guy who bought it off me on CL said the same thing.
Fred Smedley is offline
