Upgrading from 1x GRX to 1x GRX di2
Quoted: 412 Post(s)
Liked 664 Times
OK, I'm thinking of upgrading my 1x GRX group to a 1x GRX di2. As far as I can tell, all I would have to upgrade is the right shifter, the rear derailleur, and then get the battery and wiring... Am I missing something? Thanks in advance...
Pedalin' Erry Day
Yep, you got it. Shifter, 'A' junction box (you need this for the battery charging port), battery, derailer, and wires to go between those 4 parts - and probably a 'B' junction and wire unless you do something out of the ordinary with your battery to avoid needing it. And grommets to go on the wires where they enter/exit the frame - Santa Cruz should offer these.
Likes For lasauge:
A B junction isn’t strictly needed, without it you would need to run a wire from the battery to junction A and another from junction A to the derailleur. If you do just a right lever, this is easy enough, all available A junction boxes have at least 3 ports. The downside is the wires would be very long (and depending on bike size the longest available wire might not be long enough) and you give up some flexibility for future changes or additions to the system.
Likes For grolby:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1938 Post(s)
Liked 1,460 Times
Quoted: 3220 Post(s)
Liked 2,042 Times
Likes For Steve B.:
Liked 1,460 Times
This is an excellent reason. I was once stranded after my RD cable snapped. From then on I resolved to replace shift cables every other year.
Quoted: 412 Post(s)
Liked 664 Times
Shimano makes a device for their off road groups called the SCMT800. It's a h-bar mounted display unit that also has 3 - E-tube ports, a battery port and a BT connection built in. You can use this to send 2 E-Tube cables to the battery and a R derailer as well as R shifter. Also has a useful battery status display as well as gear indicator.
Liked 2,042 Times
Likes For Steve B.:
Quoted: 1455 Post(s)
Liked 1,477 Times
I'd love to see "after" photos if you go through with this.
I have a 3 year old GRX 1x bike and am thinking of doing the same. Was debating SRAM AXS just because it seems more simple to install, but hadn't thought about the idea of GRX 1x only needing the right shifter, and keeping the existing left.
Likes For msu2001la:
Bikes: 2022 Trek Checkpoint ALR5, 2014 Cannondale Trail SL1, 1983 Fuji Royale II
Quoted: 144 Post(s)
Liked 582 Times
I believe GRX is the only remaining Shimano Di2 groupset that is still fully wired. Dura Ace, Ultegra, and the new 105 use wireless shifters. Given that GRX was introduced in 2019, an update would seem likely sooner rather than later. If this is a "nice to have" upgrade, you might consider waiting a bit to see what comes out this year. Depends on the value one places on reducing wires/cables. Just a thought.
Likes For bike_tom:
Quoted: 412 Post(s)
Liked 664 Times
Likes For Caliwild:
Since this a electronic vs mechanical thread I like to pose this question. Anyone have any thoughts/concerns of using electronic shifting and the impact dirt and gravel roads would have on longevity? Long time mt.biker and I see the abuse my bike takes compare to my road bike. Trying to decide on SRAM or go with GRX.
Liked 1,460 Times
Regarding electronic groupsets, Shimano has a single battery under the seat post which requires wiring to the derailleur(s), whereas SRAM has one battery per derailleur. The former system seems more weatherproof, while the latter allows easier installation and replacement.
Liked 2,042 Times
Interesting, you think just the opposite. Appreciate the input.
