Sourcing for screws to attach clips on Campy Pedals
Quoted: 1607 Post(s)
Liked 2,216 Times
I bought these on the forum not noticing the built in ramps! Very cool!
CampagnoloTrap on Flickr
I like the way they fit on the pedal too! They will be on the Bianchi soon.
CampagnoloPedalTrap on Flickr
Question is, where do I find the appropriate attaching screws with the correct head?
It is always the small stuff, right?
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
Isn't it just a couple M5 nuts and bolts and lock washers?
Likes For USAZorro:
Quoted: 874 Post(s)
Liked 2,287 Times
You can buy them at Lowe's . They are not chrome plated like the originals , but they are hex head and have the correct look. I bought 5mm washers too. The pedals (Campagnolo pedals that I have are threaded so no nut required.
Likes For Kabuki12:
Liked 2,216 Times
Not only are they threaded, but if they haven't been used, they are tight.
Might consider button head with allen driver. I suppose hex is better so dirt isn't collected.
Liked 2,216 Times
Thought they might be familiar so looked in my small parts box that has an assortment of bike smalls like pinch bolts, axle cones, oil clips for hubs, etc. Found these:
CampagnoloPedalToeRamps on Flickr
Hate to break the package open but I can rob Peter to pay Paul.
Quoted: 235 Post(s)
Liked 349 Times
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
I'd use some stainless flanged screws, something like these.
https://www.amazon.com/Stainless-Fla.../dp/B01BXYN4UE
Likes For Schweinhund:
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 983 Post(s)
Liked 632 Times
I'd imagine the tab acting like a pedal flip -- but not in that location? If not -- purpose?
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Likes For tiger1964:
Quoted: 3464 Post(s)
Liked 2,829 Times
washers are an issue but the Original Campagnolo fastener head is ever so slightly domed.
if you want OEM you pay the Campagnolo price. Campagnolo’s are shorter, shorter than anything at a typical hardware store.
Likes For repechage:
Liked 2,216 Times
tiger1964 I thought the same. They really help the toe of the shoe slip into the cage. Without them the toe catches the edge of the pedal cage.
Señor Member
Liked 1,090 Times
I'm the guy who uses the rotary tool on stock 7mm bolts to create Stronglight/TA compatible chainring bolts.
Quoted: 1639 Post(s)
Liked 829 Times
The original Campy bolts are nice with their slightly domed tops. But the do tend to rust and pit badly as the chrome finish on them is quite thin.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Likes For Chombi1:
Quoted: 1303 Post(s)
Liked 1,911 Times
I would suggest getting four 5X8mm hex head bolts and cutting them down on a sanding disc or grinder. The SS won't rust or di-electric brinnel in the pedals, so it's a win. Smiles, MH
Liked 2,216 Times
If you havent used pedals with them, you should.
In this case, it is the functionality that is near beautiful.
When looking at the whole pedal system design, there is a lot of forethought in nearly every feature including the accommodation of using other toe clips brands that do not have the ramp feature.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
Well the domed is nice and the functionality is really a saver.
I have a house, a garage, and a patio with c&v stuff.
As a general rule I do things how I do them. I don't have the ability to think inside the box, so I tend to either recreate the wheel. or come up with solutions that most of the people here either don't understand or are dead set on doing a harder way.
Order bolts? Crap, cut some to length.
All of that being said, my take on campy is that it tends to be a gold plated hammer.
It's good, it's strong. classic lines, and the tendency to have ugly bits they call style.
Those bolts fall into that category.
Quoted: 983 Post(s)
Liked 632 Times
Yeah, I'll buy that explanation.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3886 Post(s)
Liked 6,481 Times
"Screws"? "Screws"? There are no "screws" in my bikes! They're bolts!
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4680 Post(s)
Liked 5,798 Times
Unless you're submitting the bike in a concours event, where originality is more important than function, just use whatever works.
Likes For gugie:
Liked 2,829 Times
You know of course the harshest critics are at the local coffeehouse.
no concours entry required.
Liked 2,829 Times
Bikes: 1946 Holdsworth Cyclone, 1969 Cinelli SC, 1972 Raleigh Pro, 1973 Merz road bike, 1974 Alex Singer Sportif, 1974 Merz track bike, 1975 Teledyne Titan, 1976 Ritchey road bike, 1977 DiNucci built Merz track bike, 1977 (?) Exxon Graftek, many more!
Quoted: 138 Post(s)
Liked 1,431 Times
Campagnolo toe clip bolts and washers
I made a batch of reproduction Campagnolo pedal bolts using 304 stainless steel for the bolts, I only have 2 sets left. I made the threaded portion the same length as the originals, and the dome shape of the head is the same. I sourced the correct zinc plated washers, these are not easy to find. The bolt heads have not been polished, but this is easy to do as the finish is very good. $20 per set of 4 as shown, plus shipping which is no more than $5 in the USA. Using hardware bolts and washer on Campagnolo pedals and toe clips is a sacrilege! Jim Merz
Likes For Portlandjim:
