What's a good Tire Pressure for a Road Bike for sport riding?
#76
Quoted: 3948 Post(s)
Liked 7,291 Times
Clouds. So many clouds. So little time.
Likes For tomato coupe:
#77
Quoted: 4391 Post(s)
Liked 4,833 Times
Well I could set my tyre pressures randomly and probably not have any “serious” issues, but why not take advantage of the info? It takes about 10 seconds to use a pressure calculator and then you have a good starting point to work from. I found it most useful when I went to wider tyres and rims last year. Saved a load of guesswork, trial and error.
Likes For PeteHski:
#78
Quoted: 4227 Post(s)
Liked 2,488 Times
You don't need to be as exact with bicycle tire pressures as you are with your vehicle tire pressures. A bicycle tire can be easily checked by squeezing it with your fingers or even sitting on your bicycle, can't do the same to a vehicle tire...or just use a pressure gauge and go by the recommended pressure that is written on the sidewall of your bicycle tires, no need for any online calculators....I've run my bike tires between 15-20 PSI during winter without any negative effects, I couldn't do the same on my pick-up truck because it would be a safety risk.
#79
Quoted: 3502 Post(s)
Liked 2,917 Times
I just look at my sidewall. Takes even less than 10 seconds.
#80
Liked 4,833 Times
Likes For PeteHski:
#81
Liked 4,833 Times
Likes For PeteHski:
#82
Liked 2,917 Times
#83
Quoted: 4802 Post(s)
Liked 3,922 Times
And the great thing about tubulars at those pressures is there is no rim sidewall to blow out. The rims simply don't care. 400 psi would work just fine as far as they are concerned.
#84
Quoted: 1247 Post(s)
Liked 1,323 Times
I feel sorry for any new sport cyclist who may stumble upon this bike forum in general seeking an answer to any particular question. Any reasonable contemporary response gets drowned out by the same characters who are living out of a 1975 Bicycling Magazine. Riding around on tubulars at 140 psi or just pump to the sidewall max rating is just not done by any informed cyclist who is following current best practice. It’s been long proven that those high pressures are slower and exponentially more uncomfortable yet the myth persists and promoted by a vocal few. High pressure leads to less flats is another fallacy long disproven. By the way if flats are the problem just go tubeless and ride in comfort but that would start that cloud yelling extravaganza all over again.
Likes For Atlas Shrugged:
#85
Quoted: 430 Post(s)
Liked 460 Times
This thread is hilarious, hard to tell if people are just trolling.
Setting pressures to the max on the label - sure you can ride the thing and not get a pinch flat, but is it optimal?
Doing it by feel - what's the limit of one's perception? Can you tell a 10psi difference by pinching? A 10psi difference can be the difference between pinch flatting and not, or the difference between a supple ride or a harsh ride.
Use one of the several dozen calculators out there that does most of the work for you (factoring in your weight, tire size, riding situation) and fine tune from there. Or don't 🤷♂️
Traditional wisdom suggests to follow what on the tire label. I think we can agree that modern wisdom suggests going as low as you can without pinch flatting. How you get there, whether through trial and error, asking the internet, or using a calculator, is up to you.
#86
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
Meanwhile the OP is still wondering if they are inflating their tires correctly...
#87
Liked 4,833 Times
#88
Liked 2,917 Times
#89
Liked 4,833 Times
The OP asked for advice about optimal tyre pressures. Someone pointed to a well-known online pressure calculator and then you and a few others have to troll it as a dumb idea, just because you do things the old way as if that's the holy grail.
#90
Liked 4,833 Times
Likes For PeteHski:
#91
Liked 2,917 Times
Clearly you misread my posts. I only gave my opinion on what I prefer. If the OP, as you, construes this as advice, then that is his prerogative.
#92
Expired Member
Quoted: 3658 Post(s)
Liked 5,404 Times
Likes For shelbyfv:
Likes For badger1:
#94
Liked 2,917 Times
I don't think you need to worry about new cyclists.
#95
Expired Member
Liked 5,404 Times
Serial/Cereal
You can't be serial? The "use-a-calculator, run-low-pressure on ultra-wide-tires for comfort and speed" crowd is far largerthan the two or three of us heretics, no matter how "vocal" you think we are. The "new sport cyclists" will easily see that the vast majority of posts on this thread and others like it are, ahem, "reasonable contemporary responses."
Likes For shelbyfv:
#96
It's not complicated, it's just dumb. Making the simple too complicated is the problem.
I tried the SRAM calculator above. What a joke. It recommended 60 lbs in my 700 x 32 tires for road riding. That's gravel tire pressure. It's more like 70-80 for my tires on the road.
Never ceases to amaze how people want to make the simple so complicated.
With my rims, it suggests 58/61 for a 250 lb rider. If a more common 19mm hooked rim is used, it suggests 62/66 for a 200 lb rider.
#97
Liked 4,833 Times
Sounds like all of the correct information might not have been used. Either that or you didn't give it a reasonable try. I've used the calculator with all of my different rim and tire widths. I have the most modern 25mm internal width rims with smallest allowed 28mm tires. For a 140 lb rider, it suggests 52/56 psi. It works great. If I used 32mm tires it suggests 45/48.
#98
climber has-been
Quoted: 3422 Post(s)
Liked 3,559 Times
If the road surface is good and without potholes, you can use a quite low tire pressure without the fear of a pinch flat. But that low pressure will almost certainly have high rolling resistance, produce greater tire wear, and reduce the handling.
Ride, Rest, Repeat. ROUVY: terrymorse
#99
The sram calculator does NOT suggest a pressure likely to pinch flat. Tubed setups need much more pressure than tubeless and hookless goes even lower than hooked. I just got my second pair of BTLOS 25mm IW hookless rims that require no rim strip today. Swapped 28mm tires from my previous Fulcrum racing 3 wheels. Pressure will be 10 psi lower.
#100
Liked 1,323 Times
I don't know if "going as low as you can without pinch flatting" is the prevailing wisdom, but if it is, it's not wise.
