Need education on electronic groups - SRAM Force AXS vs Ultegra Di2
#51
Originally Posted by BTW... i was at the LBS yesterday and they had a Dura Ace crank that the bonding came apart and the drive side split in half gouging the leg if the rider. The shop told me that this is the 5th one that came in and it is also happening to Ultegra.
[url
[url
https://www.bikeradar.com/features/shimano-crank-failure/[/url]
https://carlinthecyclist.com/epic-fa...1-speed-crank/
#52
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
Uh... no.
It happened to a Ultegra crank and then to a Dura Ace. This guy must be laying down some serious wattage, for a old guy that's a cancer survivor.
"The Shimano Dura-Ace FC-9000 crank snapped off just as I stood to pedal up a small hill."
https://carlinthecyclist.com/shimano...00-crank-fail/
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
#53
Bikes: Bianchi Oltre XR4 Celeste, De Rosa SK Pininfarina, Giant TCR SL, Giant Revolt Advanced Revolt 0 Gravel Bike, Trek Madone SLR, Cervelo R5 Disk
Quoted: 376 Post(s)
Liked 124 Times
#54
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Seems the be a rash of people backing their cars with their bike on them into things.
It happened twice to this guy. And a lot of others.
https://www.bikeradar.com/features/s...crank-failure/
https://singletrackworld.com/forum/t...ling-analysis/
https://weightweenies.starbike.com/f...c.php?t=143022
#55
Quoted: 376 Post(s)
Liked 124 Times
Shimano is more like Toyota reliability with Porsche performance. But you were right comparing the other brand to Ford and Chevy.
#56
On Your Left
Liked 2,433 Times
Then why does the new Supra have a BMW engine in it?
https://www.motor1.com/news/298196/t...e-explanation/
And i bet there's not a single part based on a Toyota part in any of the Toyota NASCAR or NHRA race cars.
#57
Quoted: 376 Post(s)
Liked 124 Times
Uh... no.
#58
On Your Left
Liked 2,433 Times
But so far you've failed on every other attempt.
You're really hung up on the side of the batteries. Is there anything else you have an issue with size?
#59
Bikes: Canyon, Bowman & Colnago
Quoted: 132 Post(s)
Liked 39 Times
I have never tried Shimano Di2 or Campagnolo EPS. However, when I decided to go with electronic shifting I faced the same question. For me, however, it was a no-brainer. I went with SRAM Force eTap AXS. Why?
- It's not Shimano. Not that I have anything against Shimano but all I've really used has been Shimano and I wanted something entirely different.
- It's not Campagnolo. I've had too many problems with Campy parts failing and being unreliable.
- There are no wires!
- There are no junction boxes or batteries in inconvenient places
- It's easy to stow an extra battery in your pocket or saddle bag.
- The shifting is very intuitive, left goes up, right goes down, both move the front.
- The Shimano paddles looked too small and seemed like they would be clumsy to shift in the winter with thick gloves.
- The graphics. Ugly and garrish.
- Limited choice of chainring sizes.
- Front shifting feels a little slow.
#60
Quoted: 1248 Post(s)
Liked 1,323 Times
A couple of pluses for Shimano from my perspective.
The Shadow style derailleur which prevents damage as its much lower profile than SRAM.
The industry standard for many components such as brake pads, wheels, free hubs and chains is a big deal for me when traveling or touring.
1 Battery over 4
Brakes are awesome and stay centered longer.
Its wired (wireless only advantage is initial build is faster )
1 Battery over 4
#62
On Your Left
Liked 2,433 Times
#63
Some of us like Shimano & some of us like Sram.
I have Red eTap 22 on one bike, Red 22 mechanical on another, and Shimano Ultegra 6800 on another bike.
I have never tried Di2 & probably won't.
I prefer the eTap method of shifting, then Double Tap, then Shimano's.
eTap Red is the lightest of them all, I think that Sram made a mistake in making AXS heavier all around, in fact when I build up an Emonda SLR over the winter I won't use AXS, I'll stick with eTap Red 22.
As far as charging goes, I haven't had an eTap battery go dead during a ride, but I have had to change a shifter coin-cell battery before a ride once in two years.
No one I ride with has had eTap go dead on a ride, but several friends have had Di2 go dead. Because eTap's charges don't last as long, charging them is more in my routine.
#64
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
Also, looks like Toyota more importantly borrowed the BMW multi-link suspension system - so why not use their perfectly fine engine as well. As opposed to every other Toyota/Lexus out there with Macpherson struts and a low-compression ratio engine. You get ride comfort or performance, but not both since any travel significantly alters the steering geometry, and once the suspension is worn and travel increased performs very erratically on bumpy roads or in tight corners. Especially under braking, like how most people approach freeway off-ramp donuts - brake dragging. Loads the front. If the suspension is worn nose dives, and the resulting steering geometry makes the car want to change direction. You compensate, which shifts the weight, which again changes the direction. So the car under suspension load goes any which way except where you want to. With multi-link all you get is the wallowing, but handling remains solid and steering predictable, even under hard enough braking to trigger the ABS. Mcpherson struts are fine if travel is very limited and a hard ride acceptable, but not exactly a daily driver for most of us. So, basically, the partnership is a way for Toyota to step up its game a little.
#65
I have Sramanolo groups. Both have Campy brakes and crank. One has a Campy 11-34 cassette and the other has a SRAM 10-36. I could care less if you're tired of reading it. A lot of people have no clue that both brands have parts that work well together. I've come to prefer the AXS chain. The force chains wear well and only cost $35.
If there's anything else I can post to further your irritation let me know. This is fun.
#66
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
So just don't use the Shimano cranksets; I use Quarqs anyway.
#67
Quoted: 376 Post(s)
Liked 124 Times
#68
On Your Left
Liked 2,433 Times
#69
On Your Left
Liked 2,433 Times
I do like the more intuitive shifting of eTap, left moves it left and right moves it right. I also work on my bike, i put a lot of miles on, and being able to remove the RD and crank and not having to deal with wires or junction boxes is just easier for me. And if I wanted to take a spare battery... they are very light, easily fit in eh saddle bag and take 2 seconds to change.
Likes For GlennR:
#71
I did some searches for sellers of force axs complete groups and found little. There are plenty of partial groups. My big complaint with the AXS groups is the 13T difference at the crank. First they add range with a 12th sprocket, then take it away at the crank. Their initial advertising compared the small increases in range to shimano 11 speed and ignored the fact that Campy had 12 speed and cranks with a larger range. Hence my choice to use Campy 12 cranks, but the only options that make sense with a 10T sprocket are the 50/34 and 48/32. A 46/30 would be great.
The axs brake/shift levers are great for small hands. The brake levers have 3 positions. I use the shortest reach. Campy levers only have two positions.
#72
Quoted: 1851 Post(s)
Liked 678 Times
My wife's new bike came with Force AXS. On her other bikes, she has run Red 11-spd, Red 10-spd, Force 10-spd, Utlegra/105 9-spd and Rival 10-spd hydraulic disc.
She likes the AXS a lot. She never really liked the Shimano shifters, which is why she moved to Sram, which fit her hands better. Also, her Ultegra/105 set up was 9-spd triple, so shifting kind of sucked anyway.
I know lots of people with Ultegra Di2, and they like it a lot.
You really can't go wrong. Just figure out which one you like best and go for it.
Likes For topflightpro:
#74
On Your Left
Liked 2,433 Times
I'm just calling out H@TERS.
BTW.. you must be new to the interweb. Topics are always derailed by the 10th post.
The OP posted in the 1st and 4th and hasn't been back. 70 posts later and now it's my fault. Sure.. go ahead.
#75
OP is back. Just trying to catch up! I'm looking at two endurance bikes, identically priced, similar weight and build, one has the new SRAM Force12 speed AXS, the other Shimano Di2 Ultegra. That's my quandry. I've never had any electronic group, and if I pull the trigger I assume I'll have this for awhile. I ride a 10 speed Ultegra group right now and use a climbing cassette (12-32), so I can feel the gaps (not "feel" as in shifting is bad, but as in not always being able to land on a cadence sweet spot.) Where and how I ride I'm fine with spinning out when the speed tops just over 30 as long as I have low low gears that will let me hang on to double digit grades for a long time. The 12 speed AXS interests me because at a wide range it seems like I would have smaller gaps. My friends who own Di2 all love it, but none have SRAM experience. My only real SRAM hesitation is the stories that keep popping up about how the new Force AXS group is really loud, and that you can't seem to work the noise out of the cassette without updating to Red, and not even then does it go away. I think the Ultegra Di2 group has a fantastic look to it, and while I don't like the Force as much it doesn't turn me off either. On the internet especially, small problems seem to get overblown so I don't know how prevalent the Force eTap rear cassette/chain noise issue really is. On the flip side, I've never to my recollection heard anyone complain about Di2 noise or reliability (the connectivity interface on the other hand though...). I realize this choice is nowhere near a dilemma (it's not bad at all in fact), just hoping to gather as much data, info, and opinions as I can.
