Tire Pressure
#51
Quoted: 1008 Post(s)
Liked 1,232 Times
Bro ride your own ride... I work with physicists all day (im at a national laboratory in group looking for dark matter), there are too many variables to math out the fastest tires. The only reliable test is one done in real world conditions. Some people enjoy thin hard tires.
And if you do indeed work there, as an amateur astronomer I'm jealous.
#52
Quoted: 2630 Post(s)
Liked 470 Times
Then try this https://www.researchgate.net/publica..._Cycling_Power
#53
Liked 470 Times
Yeah I work at SLAC, one of the particle accelerators. My father is one of the higher ups in an experiment looking for dark matter and during covid they lost manpower and I was available. Bit of nepotism going on
Likes For LarrySellerz:
#55
2-The friction between tire and road surface is mostly static friction, not sliding kinetic friction, meaning that there's not much frictional energy dissipation happening at the interface.
3-The two above points have very little to do with rolling resistance. Ignoring vibration, Crr on a sealed road surface is largely driven by friction internal to the tire (i.e. hysteresis of the casing and tread and whatnot), not friction between the tire and the road surface.
Likes For HTupolev:
#56
Quoted: 6866 Post(s)
Liked 10,827 Times
Please tell us precisely what you contribute to this project. I'd love to know.
#57
Liked 470 Times
also what does that matter? mind your own business bro. Ride your own ride
#58
Quoted: 875 Post(s)
Liked 1,998 Times
I like math it out. I think I'll use it.
In the car repair business, at least back in the day of distributor caps and rotors, they'd say "throw a tune-up on that Chevy". So how about
throw some math on that
I like it. Awesome thread.
Likes For downtube42:
#59
Liked 10,827 Times
#60
Liked 10,827 Times
In grad school, one of the standard texts would offer these hairy mathematical problems, work most of the way through them, and then -- rather than showing the last several steps in solving the problem -- the author would use the line "And the rest is obvious to the casual observer." One day while studying, one of my friends said, "I'm as casual about this as anyone, and it's not obvious to me."
#61
Cheerfully low end
Quoted: 641 Post(s)
Liked 1,034 Times
Anyway, I’ve always disliked the notion of dark matter and thought of modern cosmology as a bit of a shambles. Thankfully, Bahram’s monograph from 2017 holds some hope that we are better understanding the history dependence and nonlocal aspects of gravitation which actually produce many similar results that some have explained with what seems to me a hand waving notion of dark matter.
I’m not necessarily going to recommend you actually buy a copy and try to work through it but here is the book. It’s an Oxford Press monograph.
https://global.oup.com/academic/prod...c=us&lang=en&#
Otto
#62
Liked 470 Times
In grad school, I had the good fortune to be able to take two classes on gravitation from Bahram Mashoon, who, as a gravitational theorist who worked with John Wheeler, was here because we had a research reactor with thermal neutrons and techs who could make working neutron interferometers from single crystal silicon ingots. (Gravity experiments aren’t so easy on charged particles where the gravitational interaction is 39 orders of magnitude less than the electromagnetic)
Otto
Otto
#63
Liked 1,232 Times
Pretty cool, Larry. During Covid a lot of places needed manpower, many still do. The fact you're still there says something. Nothing wrong with taking advantage of a good opportunity.
#64
#66
Quoted: 4193 Post(s)
Liked 4,616 Times
Probably a reasonable approach if you happen to weigh 350 lbs.
#67
Liked 4,616 Times
In Newton's pendulum, the kinetic energy of the first ball is transmitted through all the balls to the last because they are perfectly elastic and very hard. If the balls were perfectly inelastic, the last ball would not move at all because all of the balls would have absorbed all the energy.
In a hard tire, all the energy is transmitted through and you can feel all the vertical bumps. Not only do you go up and down, you go forward.
In a soft tire, the rubber absorbs all the energy and reduces your forward motion. Try riding on grass and sand where the soft ground is absorbing all the energy. Then compare that with riding on concrete, asphalt or on a perfectly smooth and hard track of a velodrome. The hard surface transmits all your energy.
Where people get confused is attributing speed with a harder ride. Beyond a certain point it becomes counter-intuitive.
#68
Quoted: 3361 Post(s)
Liked 2,743 Times
#69
Quoted: 5216 Post(s)
Liked 3,555 Times
Likes For rumrunn6:
#70
Quoted: 790 Post(s)
Liked 348 Times
A Silca engineer, when interviewed, said that if you want to go fast you are much better off running pressure that is lower than higher. And he said this is because although there are gains to be made by running high pressure, they are much smaller than the losses that can occur from vibrations induced in the bicycle from the texture of the road surface. He said that as he and his crew were traveling around the world being technical support at races, they almost never used their tire pumps when adjusting the pressures of bicycles they adjusted for various riders, in almost every case they were letting air out of the tires they looked at.
This engineer said that the only surface that could use higher pressures would be a sanded smooth and varnished velodrome track, an outdoor concrete velodrome, although being very smooth, would not use higher pressure for optimal performance. So the take-away is that anyone riding on any sort of public paved road, is certainly better off running pressure that is low, not so low that there is any danger of damaging the tire in use, but not pumped up to the max pressure that is on the sidewall of the tire.
So I have been riding with lower pressures lately in my road-bikes, not worrying so much about them being pumped up to the sidewall pressure, but having them ten or fifeteen pounds lower. There are a few local courses I ride which have been used for time-trials in past decades, and eventually I will get round to timing myself on them while riding with lower pressures. All the science says that I should be faster with the low pressure, but I do not use any sophisticated methods of measuring, just the stop-watch feature on a wrist-watch over a dozen miles. I am guessing the low pressure will not hurt my speed at all, it may make me a little faster, and it will certainly be a bit less fatigueing, so all I see are advantages.
#71
Liked 2,743 Times
Now if I could just find some 700 x 20C clinchers that went to 140.
#73
Liked 10,827 Times
That's your decision. But don't be deluded into confusing your feeling with facts.
#74
With the latest hookless rims like my Zipp 303s wheels, 73 psi is the maximum recommended pressure for any tire. If that's not enough, then you buy wider tires. Zipp's pressure calculator recommends only 51/54 psi for my weight and 30mm tires. I found that a bit too squishy and increased it by 5 psi. Works great. I use 62/66 for 19mm internal width hooked rims and 28mm tires, as recommended by the Zipp calculator.
#75
Liked 2,743 Times
Which is why I qualified my "doing it wrong" with, "if you're interested in performance."
Don't confuse your perception with reality. They're slower, they have a smaller contact patch, and being "less cushy" is the conversion of forward momentum in to upwards momentum.
There's a wide range of optimal, depending upon the rider, the tires, the surface, etc, but 140psi on pavement is well outside of the feasibly optimal range.
You're confused.
More confused.
You guys that think high pressure is fast because 'it feels fast' just don't get it. What you're feeling is the very definition of rolling resistance. If you're feeling every little bump and bit of texture it's because the bike AND you are going up and down. Not as efficient as if the bike AND you weren't going up and down. 'Feels' count for very little here, we're dealing with physics. Which are known as the LAWS of physics.
More confused.
1-Friction forces between a typical sealed road surface and a tire are substantially more proportional to total normal force than to contact area. A small contact area mostly just makes the friction less consistent, i.e. traction can be sketchier.
Anyway, constantly telling folks they're just "wrong" is probably the easiest way to explain things. But thanks anyway.
