Go Back  Bike Forums > Bike Forums > Framebuilders
Sizing a mixte frame
Framebuilders Thinking about a custom frame? Lugged vs Fillet Brazed. Different Frame materials? Newvex or Pacenti Lugs? why get a custom Road, Mountain, or Track Frame? Got a question about framebuilding? Lets discuss framebuilding at it's finest.
Old 06-29-22, 03:36 AM
oneclick
Quoted: 763 Post(s)
Liked 806 Times in 494 Posts
I have some old mixte frames being built into bikes, and noticed that the current one seems to have a very long head tube compared to a similarly-old road bike frame.
Two 70s Torpados, the mixte is 52cm crank to top-tube, 56 cm seat lug to head tube, 162mm head tube; the road bike (also hi-ten likely) is 55, 56, and 134.
Is this typical?
oneclick is offline
Old 06-29-22, 04:30 AM
unterhausen
Randomhead
Liked 2,316 Times in 1,637 Posts
My thinking on the head tube length on a mixte is that the same person wouldn't want a mixte and an aggressive racing position. So might as well make the head tube taller. Lots of mixtes were built as uprights, so it makes sense for the head tube to be taller.
unterhausen is offline
Likes For unterhausen:
Old 06-29-22, 08:13 AM
Andrew R Stewart
Andrew R Stewart's Avatar
Bikes: Stewart S&S coupled sport tourer, Stewart Sunday light, Stewart Commuting, Stewart Touring, Co Motion Tandem, Stewart 3-Spd, Stewart Track, Fuji Finest, Mongoose Tomac ATB, GT Bravado ATB, JCP Folder, Srewart 650B ATB
Quoted: 3570 Post(s)
Liked 2,427 Times in 1,542 Posts
I'll add to Eric's good points that many mixtes have a really long "top tube" for their seat tube size. For reasons like not having to do much change to a jig used for diamond frames to wanting some toeclip clearance. I have felt for a long time that mixtes were more about stand over or mounting issues and not a best solution for the smaller rider, unless additional steps are taken to shorten the TT length (like smaller wheels). Andy
AndrewRStewart
Andrew R Stewart is offline
Likes For Andrew R Stewart:
Old 06-29-22, 09:54 AM
Doug Fattic
framebuilder
Quoted: 500 Post(s)
Liked 1,319 Times in 487 Posts
Let me add some clarity to why Mixtes have long top and head tubes. Ot what would be the distance between the seat and head tube if there was a top tube. They are usually designed for upright sweptback handlebars. The kind used on most 3 speeds. One of those handlebar models is called "North Road". With drop handlebars, your hand position is way beyond the front of the stem. With upright bars your hands are positioned well behind the stem. That necessitates a longer "top tube" to compensate.
Using upright handlebars positions your body much more upright too requiring the stem to be higher as well. A longer head tube prevents a crazy amount of stem to be exposed. Everything looks much more proportional when a frame using upright bars has a longer head tube.
This is why a road frame designed for drop bars does not convert well to upright handlebars. The seat angle will be too steep, the top tube will be too short and the stem at it max height will still be too low. When I was designing our IGH Ukraine bikes with upright handlebars, I discovered these reasons.
It is possible of course that some Mixtes were designed for drop bars. That would mean a somewhat steeper seat angle and a shorter equivalent top tube distance but probably still a longer head tube because even with drop bars it is likely the rider will be somewhat more upright than when on a road bike designed for speed. The closer the seat height gets to the height of the handlebars, the higher the stem will naturally want to be placed with the result that a longer head tube is preferable. Bikes can look pretty ugly with stems sticking way out.
Doug Fattic is offline
Likes For Doug Fattic:
