18mph pace
#51
Habitual User
Quoted: 4929 Post(s)
Liked 8,062 Times
Similar story here. I was strongest in my 20s, while I was in the military. Did a lot of physical stuff outside of organized PT. Ran and rode a lot, especially in Okinawa. When I got out, my goal was to just "maintain", but life got in the way. Someone challenged me to a 5k about five years ago. I didn't do nearly as well as I expected. So much for maintaining. But I pushed to get back in shape. Then someone challenged me to do a triathlon. I signed up for April of 2020, then the WuFlu hit and all events shut down. I did my first triathlon last October, at age 51. This one was my fifth in 10 months, also fifth ever. Didn't start triathlons until I was in my 50s. Now I'm regretting not starting younger. I really wish I had at least attempted an Ironman back when I actually had a reasonable shot at finishing one.
My issue with triathlons is that I loathe running, and really suck at swimming - LOL . I had my time racing, and spent a lot of years where being on a bike meant suffering (always training to be faster for longer). I'm currently trying to learn how to ride my bike just for the fun of it. Sometimes fun is going fast, and bumping against the limits of my fitness, but it's definitely a different mindset now. When I hung up my bike in '04, my body was pretty done, and my motivation to keep pushing was gone. I focused on being a good dad to my new daughter, and took up some hobbies that kept me at home more. That little girl grew to become a very good softball player, and the last 10 years of our life has been dictated by her schedule. We have one last week of her final softball tournament, and in 2 months, she will be gone to college. I expect to ride a bit more often than I am right now.
Likes For VegasJen:
#53
Habitual User
Liked 8,062 Times
One of the first areas where you might think about upgrading to improve performance is your shoes and pedals. Proper stiff-soled cycling shoes with clipless pedals will eliminate the power loss you're currently getting with flexible running shoes on flat pedals.
As for position, reducing the height of your front end should be a goal, but it's something to adapt your body to a few mm at a time by swapping stem spacers from below you stem to above it. Scooting your saddle forward may also help you get your front end lower. TT/tri bikes tend to have steeper seat tube angles than road bikes in order to get more forward over the bike.
#54
climber has-been
Quoted: 3416 Post(s)
Liked 3,543 Times
Looks good, nice solid position. Back mostly flat.
After some stretching, you probably can lower the bars some more. Try moving one stem spacer from under the stem to above the stem.
Ride, Rest, Repeat. ROUVY: terrymorse
#55
Thanks guys. I don't have a lot of spacers on this stem. Maybe what I'll do is swap what I have above, and when I run out of those I can flip the stem. It's got 6* (I think) of angle. So maybe go down with spacers first and then drop with the stem to get lower. My biggest concern with doing that is just pain in the neck, literally, at that angle. But it won't kill me to try it at least.
#56
Quoted: 2333 Post(s)
Liked 2,097 Times
1, Work getting lower, step by step or spacer by spacer. Possibly shorter stem bringing arms narrower and closer.....maybe.
2. Tighter and faster kit
3. Aero helmet
4. Aerojacket for the rear wheel
5. Deep dish aero wheel with bladed spokes up front
6. Latex tubes or tubeless fast tires
7. Racing shoes and pedals
The order is basically the biggest bag for the buck. I suspect if you did all of the above, you'd be at 20 mph
You are making a lot of power to go 18 mph......I'd work on the aero
3. Aero helmet
#57
3. Aero helmet
3. Aero helmet
Likes For VegasJen:
#58
Liked 2,097 Times
Power, I have. One thing is pretty evident, I'm no stick. But the flip side of that is I'm about as aerodynamic as a brick. If the speed is about equipment, then $$$ is my limiting factor. I'm just a poor, unemployed nursing student. I would like to find a dedicated tri bike but that will have to wait until I'm out of school.
I'm 6'3 and a 220 brick.....I feel your pain.
#59
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
#60
climber has-been
Liked 3,543 Times
Your body has to get used to a new change, so make small changes, letting your body adjust to the new position until it's comfortable.
#62
OM boy
Bikes: a bunch
Quoted: 507 Post(s)
Liked 634 Times
Don't know much about Tri. I do know how to compete.
If you aren't already, join the Vegas Tri Club. Make friends, get pointers from others who have done what you are wishing to do.
Bike - the aero equipment will be important, eventually.
But 1st learn how to get the most out of you and the bike. Ride with others who will push you harder, not just alone. Learn your gearing and what works for you under conditions.
Only gear I would recommend is getting shoes and pedals which work for tri-bike - running shoes are not those. You need to get your position to what works for you, then modify as you improve aspects. Dont; know what shoes and pedals work best for Tri - the club members would.
You say you have power, so if that's not the main limitation then there are other aspects which hold you back - define those and work on them.
TT is an inner thing. 20 is not a boundary, it might/can be the next step.
Ride On
Yuri
The shirt you wore is fine, if not getting logged with sweat, lose the saddle bag for competition - what is the belt around the waist for? why? get Tri club help on a good position for you at this time, once you have shoes and pedals. Ride a bunch, know your gears and how you perform with them. Fuel the motor well. Be less 427 Chevy and more 12 cylinder Ferrari - power wasted is the same as not having it.
Ride On
Yuri
#63
just another gosling
Quoted: 3885 Post(s)
Liked 1,938 Times
Those racing photos . . .
You're doing great. You don't say how long ago you started training your 3 sports. How many years and how many hours/year are a big deal.
You are athletic, BTW. You're a Marine. Your build is not that different from my wife's. You can modify your fit to get closer to a TT fit. You need to open your hip angle to get as low as you can. Say you moved your saddle all the way forward on a zero-setback post. Then see what you'd have to do as far as stem length to get back your perfect upper arm/torso angle. You'll probably be able to go with a negative angle on that stem, too. If the mod was interesting, you should be able to find a setback seatpost which you can reverse.
From the knee angle on the far knee at TDC, I'd say you might do better with shorter cranks. For some of us, getting low becomes an issue of chest/quad interference.
The cockpit on my endurance bike. These Profile Design bars mount below the bars, which is quite a difference in height. With the bars set up like these, my forearms are approximately level. I agree that aero position is everything. Wring everything you can out of that before spending on fancy equipment
Running. Here's a good video, showing the 2 different techniques current in tri. I'm a glider, never was a gazelle. I keep my feet near the ground and my cadence as high as HR permits.
Results matter
Results matter
Likes For Carbonfiberboy:
#64
I am potato.
Quoted: 1784 Post(s)
Liked 1,622 Times
+1
Car dependency is a tax.
#65
OM boy
Bikes: a bunch
Quoted: 507 Post(s)
Liked 634 Times
since I don't/didn't know what would be considered most important in a Tri Bike shoe, I thought I'd start finding out a bit...
Found a good article with references for a variety of Tri Bike shoes.
Noting in particular the Louis Garneau Tri X-Speed 3 shoes. I always find Louis Garneau stuff to be a great mix of performance/fit/value/price in their range of products.
Certainly their cycling shorts/bibs are great stuff, at very reasonable cost, fit well and last... expect the same from their shoes ( I should get some and give a try... I tend to stick to Sidi, because for decades they have fit me, great performance/fit/value/durability, but you do pay for this.... for the amount of riding I do and the service life with never a fit issue, I don;t complain...
Ride On
Yuri
Ride On
Yuri
#66
Ride On
Yuri
Ride On
Yuri
As for the bag, the only thing in it is my car key since I was by myself and all my valuables were locked in the car.
I would really like to ride with other people, especially, like you say, others that will push me. But there are relatively few serious riders out here where I live. I need to hook up with some people and get serious about it. Unfortunately, at least right now, the only time I have to do that is during the summer, which is really terrible time to be doing anything outside in the desert. My school schedule has me pretty much buried the rest of the year.
https://www.youtube.com/watch?v=tJWPwVF30yo&t=196s
Thanks for the video. After watching it I think I am in the "glider" category also. Not so much because I want to be but I am so much more bulky than those women are. I don't have many good pictures of my stride but this one may be the best representation. As noted before, I'm carrying quite a bit of mass up top where it's not doing me any good.
At the risk of taking this thread too far off the subject, I went back to my previous tri and put together an image of my run. Not exactly the best image. I had to piece this together from several separate photos. Now, bear in mind that this was an Olympic and I was exhausted. But I'm never far off the ground. Again, I'm carrying a lot more mass than any of those true athletes. But it goes back to what I was saying earlier in that I don't have the spring in my feet I used to have. I think some of that is simply age-related muscle loss, and some of it is that I'm just carrying a lot more weight than most athletes.
Likes For VegasJen:
#67
Ride On
Yuri
Ride On
Yuri
#68
Quoted: 313 Post(s)
Liked 679 Times
Your position certainly isn't bad. I'd say you can definitely get more aero on that bike, it's just a matter of if your body can handle it (it will take time to adjust of course).
- Lowering the front end is a good start, either with fewer spacers or flipping that stem.
- Getting your head tucked down lower and out of the wind.
That's all free and will take some testing. When it comes to spending $$$ then...
- A better cycling / tri style top, doesn't need to be much tighter but it will be smoother with less flap/wrinkle.
- I can't tell what tyres you're using, but some faster ones paired with Latex tubes may net some additional speed.
- Expensive, but some deeper section wheels.
- An aero helmet will net some savings, but I'd put it low on the list.
There's a bunch of other stuff as well and the rabbit hole is endless, but that's a very good starting point! 😀
#69
Quoted: 3241 Post(s)
Liked 2,512 Times
#70
Liked 2,512 Times
If you're looking for some inspiration, the current men's Olympic tri champion has a somewhat atypical build for a triathlete. Stocky and heavier than the usual builds you see in tri. Kristian Blummenfelt.
https://www.instagram.com/kristianblu/?hl=en
#71
OM boy
Bikes: a bunch
Quoted: 507 Post(s)
Liked 634 Times
I'll have to check into Las Vegas Tri, but the problem is I don't actually live in Vegas anymore. I'm still close, about 50 miles away, so I do drive in from time to time. But it's not like it's right down the road either.
How do you carry the key/keys in 'swim', run?
Your personal situation is something which can only be addressed by you. BUT, the fastest way to increase your learning curve/performance curve is to learn from others who have and are climbing the same mountain, hiking the same long trail, wanting the same faster... That knowledge may be the most valuable thing you can get. It may require some changes on your end. What that can be is only what you decide.
My comments are purely to encourage thought, in some obvious directions which can give sizable gain. Not every direction.
You're getting some valuable insights here, but other experienced Triathletes,living in your area, your desert, can put that into better perspective and with better priorities...
https://www.backcountry.com/pearl-iz...v6-shoe-womens
We're not gonna do the work for you, nor can we. You need to determine WHAT you need to do, and find a way to get there. If you decide to 'shop', there's plenty out there.
It may require some work, digging and not getting $250-$400 shoes, or whatever else you decide you need. But there's good stuff out there...
https://www.rei.com/rei-garage/produ...E&gclsrc=aw.ds
https://www.trisports.com/product/lo...xoCrtEQAvD_BwE
The "beginner's category' of shoes in the article shows some very fine shoes - way better than what you're using...
If you say you have 'power', getting it down to the wheels and the road is primary to any other improvements. Everything else you do to improve will depend on how good your connection is to the bike.
Don't know your Euro or Mondo size? Figure it out.
There is no 'hidden' something which will get you from 18 to 19 and to 20 without the work.
... here's one thing I would put vegas money on...
if you were to buy a 'real' Tri TT bike, without working on the other things, it won;t get you to 20, prolly won;t get you to 19... it will make the path smoother, maybe a little easier, but it's not 'magic'
Ride On
Yuri
#72
That was a 'competition' photo, yes? A large saddle bag has aero disadvantages - think it thru - if all you're carrying is a key/or keys - is there a better way to carry?
Sure, Companies would love you to buy their 'best' products (price wise). But there is some very fine stuff available for well below even the current mid-price point...
https://www.rei.com/rei-garage/product/214672/garneau-jade-ii-cycling-shoes-womens?CAWELAID=120217890013764163&CAGPSPN=pla&CAAGID=118742105195&CATCI=aud-1396942685475la-297455113653&cm_mmc=PLA_Google%7C21700000001700551_2146720007%7C92700061060353182%7CNB%7C71700000080 080004&gclid=CjwKCAjwrNmWBhA4EiwAHbjEQAJC0t9SPE2oyyzYYiN3nCcJLwmkYgWSnXKVk_H30jctKbYS5fmphhoCMaYQAvD _BwE&gclsrc=aw.ds
Ride On
Yuri
Ride On
Yuri
What is a Mondo?
#73
climber has-been
Liked 3,543 Times
I carry my roadside kit in this minimalist Lezyne Roll Caddy. Enough room for all the necessary bits. Stuff doesn't jostle around, and the roll tucks tightly against the saddle. Very aero.
#74
Should Be More Popular
Quoted: 22579 Post(s)
Liked 8,919 Times
So basically a roadside kit for puncture repairs.
#75
Quoted: 3943 Post(s)
Liked 7,286 Times
Likes For tomato coupe:
