Frame Material
#76
Quoted: 1743 Post(s)
Liked 1,280 Times
I have 4 road bikes and a cross bike. The Colnago cross bike, a Masi and my CAAD 12 are aluminum. The other two are both Gurus. One a Photon (CF) and one a Sidero (Steel). I have not experienced a hollow feeling/sound or vibrations on any of the AL bikes. In fact, my CAAD 12 set up with tubeless Mavics and all 105 weighs in at 17 lb 11 oz and is one of my favorite bikes in over 40 yrs of cycling.
#77
Quoted: 18397 Post(s)
Liked 15,492 Times
Likes For indyfabz:
#78
Ive had sensory issues my entire life. Some things are very unpleasant for me. I know things I say or do are odd to most people. I was just passing along something I found with certain materials, for me. If you don't notice these things that is good, life is easier for you.
This shows there is some difference in frame materials and vibration/shock but I don't think its a detailed report.
https://web.mit.edu/2.tha/www/ppt/Bike-ISEA.pdf
#79
Quoted: 1854 Post(s)
Liked 661 Times
Experience and expertise, basic tools of exposition, a blind reliance on raw numbers without taking into account human empirical observation.
Neither am I not surprised in the least.
But at the tire sizes and pressures you guys run at, perhaps it isn't surprising that all sense of road feel and vibration, without regard to fame material, has disappeared?
#80
Liked 661 Times
Likes For Road Fan:
#81
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
There are indeed differences in frame materials. I think it takes decades of practice to learn which generalizations are accurate, if any. All of us are trying to reason from a few specifics to some general characterizations. I'd be surprised if any of actually have that ability, objectively.
Your saddle, tires and their pressure, and bar tape/grips influence your ride more than your iconic classic steel frame or carbon wünderframe.
I'm also going to go out on another limb..If your last name is not Vingegaard you're not going to be able to buy your way to speed so relax and buy the bike that makes you want to stare.
Likes For Germany_chris:
#82
Quoted: 4227 Post(s)
Liked 2,488 Times
Frame material is irrelevant and unimportant.
Likes For wolfchild:
#83
climber has-been
Quoted: 3410 Post(s)
Liked 3,542 Times
Likes For terrymorse:
#84
Bikes: Casati Laser, Colnago Tecnos, Ciöcc Exige, Black Mountain Cycles Road
Quoted: 129 Post(s)
Liked 177 Times
To be perfectly honest with you neither frame material nor 'design' have really anything to do with ride quality. Unless you have some kind of mechanical pivot in the frame (Trek Domane) all frames are so close in ride quality you'd never be able to tell the difference in a blind test. Tire pressure is another story.
Likes For Oldguyonoldbike:
#85
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
In fact, I have three steel bikes and one carbon fiber bike. The most comfortable one is the one with the most tire clearance (now running 30c). The least comfortable one only has room for 23c. Both of those are steel. The carbon fiber one sits in the middle and is running 25c. Each bike handles a little differently and behaves a little differently while pedalling, but frame material is only one of several factors at play (tube diameter, geometry, wheel quality/flex, etc.).
Likes For cxwrench:
#86
Wider tubeless tires and rims with the pressure set according to the pressure calculator at zipp. com will make any bike more comfortable, but many bikes won't fit 28-32mm tires. My current frames will all fit at least a 30mm. I run 54/57 psi on 23mm internal width hookless rims and 30mm tires. I get a good ride with a stiff carbon frame.
#88
On most of my bikes I can watch the fork tips flexing while riding. On the Bates with the Diadrant fork (look it up- yes, steel) the fork tips move so much it startles other riders. The frame contributes nothing to ride comfort?
On any steel fork with significant rake try mounting a fender and then push down on the handlebar. Watch the tire come closer to the fender. If you have a stiff fork nothing will happen. With a flexible fork it doesn't take much load to get very visible suspension travel, with very flexible forks you might need to mount the fender higher.
Bikes are not all the same. Different ride characteristics can be engineered into steel, aluminum, titanium, or carbon. Ever ride a Vitus 979? Aluminum frames that were super flexible. Built in quantity for many years and won thousands of races. No aluminum frame remotely close to that in current production. If you buy production frames built in current era they are all massively stiff. The buying public asked for that. Or a vocal segment did. Now those who want something different have limited choices. Simplest is to ride wide tires and keep the pressure down. Or you can buy custom from a builder who listens when you ask him for something non-fashionable. Or you can ride old bikes. New bikes ride like brick walls. And windrows of commenters will tell you that is the only possibility. There is no alternative. Bollocks, there is always an alternative.
That Bates mentioned above is also the most precise steering bike I've owned. In spite of the fact that I am way heavier than would have been anticipated when the frame was built. A flexible fork is not a sloppy fork.
Likes For 63rickert:
#89
Sorry, I didn’t mean to interrupt all the fun of arguing frame material for yet another time. How many years will people argue over the same thing?
Not a wheel builder, although I’ve built wheels. I only know what I’ve experienced. And deeper stiffer wheels do ride harsher to me. Shallow rims with more compliant spokes ride smoother. Whether it is deflection or transmission of vibration I don’t know. It would be nice to hear from people who actually build wheels.
I don’t recall seeing 29er mtb’s with deep profile rims. Maybe that has changed. The obvious answer is that speeds don’t justify them; all the while people average 15mph on their road bikes with deep profiles.
But I do know shallow rims would ruin the look of a modern road bike.
John
Edit added: I do agree that wider tires with lower pressures have a greater impact.
John
Without going all the way back to that kind of rim it is all pretty much the same. A 20mm tall rim is now considered very shallow, it is going to ride just about the same as a 30mm tall rim. In current production I like Pacenti Brevet and H+Son TB14. They are not really like vintage, some of the effect remains. Heavier and taller than vintage. Stronger too.
The way vintage wheels got their ride was nearly all of them were built too loose and they were built with erratic tension. A wheel can run perfectly true while spoke tension is all over the map. That was the only reason for 36 spokes, only a dozen of them were doing much work. The wheel kind of flopped and shimmied down the road and sometimes that felt good.
Everything affects how the wheel rides. High flange hubs do ride stiffer than low flange. Butted spokes ride smoother than straight gauge. Real butted spokes at 2.0/1.5mm ride better than fake butted at 2.0/1.8. Lower spoke count rides better. These are small effects but they add up.
Quality of the build matters more than any of the other little details. I have used salvage rims and hubs to build for clients with $3000 wheels and my wheels were preferred. When the order was build a cheap set of spare wheels and the customer sells the name brand wheels because they just don't match up to hand built you did good. And having just said that I build really good wheels I will also say that some pre-built system wheels are just as good as mine. But they are not all the same, they are not interchangeable widgets. The price is mostly the cost of advertising. Quality does not equal price.
#90
Quoted: 1943 Post(s)
Liked 2,164 Times
I build wheels. Yes, wheels can change how a bike rides and rim height is part of that. Yes, taller rims are much stiffer. Find an antique flat section tubular rim and you can flex it with your hands. It won't support your body weight until it is filled with spokes.
Not sure if it pertains, but my old Cannondale Criterium went from 36 hole MA40’s to 32 hole TB14’s. Hubs were Superbe Pro to DA 7700.
Although most would say comfort is not even remotely an appropriate term for the ride, I’m still riding the bike at 70.
John
#91
Bikes: lots
Liked 2,932 Times
Likes For cxwrench:
#92
You may build wheels but I think you're confused when it comes to the physics involved. And you have some rather odd opinions. 'Fake butted'? High flange hubs are laterally stiff, not radially. At least not that anyone can feel once they get past the tire. You don't think people knew how to build wheels years ago? I completely and totally disagree. Built too loose and erratic tension? Sure, that happens today as well...it was definitely not the rule in the 'vintage' days.
Yes, there were good wheel builders in past. One wheel I have in regular use was built by Oscar Wastyn in 1959. I checked it, glued a new tire, I ride it. Needed nothing. There were certainly other good builders. They somehow established uniform tension before meters existed. Quite a trick. OEM or shop built, most vintage wheels were bad. My memory is not failing on that one. I still come across vintage wheels and racks of vintage wheels and most are pretty useless. When the wheels come with provenance it is disappointing to find all the known names who just did not build well.
The most used spoke when I began was Berg-Union .080"/.060". Same thing as 2.0mm/1.5mm. We got them from Schwinn. All sizes in stock, always, and they were cheap. Schwinn used those spokes on millions of bikes. Only small wheel juvenile bikes and heavyweight trucks got straight gauge. Now 2.0/1.5 is considered exotic. Millions of Schwinns say it should be normal.
I am an old man and likely a confused old man. Saying "confused" and "Physics!" is what you attempt when you got nothin.
#93
climber has-been
Liked 3,542 Times
Thin spokes are "exotic" because wheel building machines have trouble tensioning spokes that thin--they tend to wind up when tensioned. Not a problem when tensioning a wheel by hand.
Ride, Rest, Repeat. ROUVY: terrymorse
#94
Bikes: lots
Liked 2,932 Times
Take a ride on a wheel with a really high flange hub like a Prior. You will feel the difference. If you do the comparison test with two flat rims you will feel it more. Tall rims remove so much feel nothing matters.
Likes For cxwrench:
#95
Quoted: 567 Post(s)
Liked 563 Times
Exactly right, only you know your requirements. At soon to be 73 with arthritis in my hands & knee I am sensitive to road/trail conditions, frame builders and their materials, tires, anti-vibration gloves, etc. I ride my bonded aluminum 1990 Vitus 979 in our retirement community with very well maintained bike lane conditions but today up at our mountain cabin it would do me in very quickly.
#96
Liked 661 Times
I'll throw out my generalizations
#97
Placebo effect, at least for vertical compliance. No human is sensitive enough to detect the vertical compliance difference between two identical rims, laced to a high- and low-flange hub.
Not really that hard to do. I was tensioning by ear in the 1970s, a technique I learned from my dad (who built wheels for Jobst Brant in the early 1960s, including some interesting tubular wooden rims that Jobst wanted). Tap each spoke with the spoke wrench, listen for the note. My wheels stayed true.
Some can get even tension by tone. Most using that technique don't. Off the top of my head Ron Boi, Davey Danek, Ike Safter built uniform tension before meters and none of them could be bothered with listening to pitch of a spoke. No idea how they did it. Most could not.
Yes concerning automatic wheel machines. No to all the mysticism (from others, not pointing at you) about thin spokes being unmanageable or unworkable on drive side right. It is really a shame riders don't get to use thin spokes any longer or if they do pay an arm and a leg. Again, millions of Schwinns. 2.0/1.5 works quite well.
The other commenter saying I make it all up not worth responding to.
#98
climber has-been
Liked 3,542 Times
The vertical compliance difference between otherwise identical wheels with small and large flange hubs is undetectable by a human.
#99
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2134 Post(s)
Liked 1,643 Times
I tried to keep up with all of the latest fads. I ended up with top end carbon bikes and to tell you the truth most of them rode like garbage. I am not a pro-racer and I'm not going fast enough to smooth the bumps out with speed. Then they started making carbon bikes for people who just tide. These carbon bikes are pretty light but to tell you the truth my bike and body weigh a little over 210 lbs. and changing this weight by a couple of percent as a normal sports rider doesn't make a detectable difference in climbing or riding on the flats.
So it began narrowing down to whether it was worthwhile to pay a small fortune to have a new or even newish bike.
I began riding more and more aluminum bikes and while they rode OK, I didn't like the cables ringing like a bell when they slapped against the headtube on the terrible roads around here. So now I will be turning back to steel bikes. Tomasso, Tomassini, Masi and other really nice bikes using modern groups and such can end up almost as light as a top end carbon racing bike,. Certainly as good as my Colnago C50 which I keep around for old times sake.
At 77 I neither climb fast enough nor have the guts to descend fast enough to make aerodynamic drag even worth mention. So shouldn't ai ride a nice comfortable bike that doesn't put my bank account in the red?
#100
Anyone interested in frame compliance should look up video of ISO 4210 frame testing. You don't need me to find that, you need a search bar. And you will see that all frames move around quite a bit. A frame with no compliance at all would be no fun to ride and then it would break.
At least some of you must have had a ride on zero compliance disk wheels for TT. Again no fun to ride. Why it is controversial that shorter spokes at higher tension, taller rims, larger hubs all move a wheel in direction of a disk wheel is beyond me. Everybody recites stiff, stiff, stiff stiff stiff stiff stiff . There are examples available of what zero compliance is and how it rides. You can ride on solid rubber tires too if you think stiff is good.
