How to get rear derailleur cable house to run straight on vintage steel frame?
Quoted: 9 Post(s)
I'm trying to build up a vintage steel bike for the first time and got to installing the rear derailleur. However when I tried installing the gear cable and rear derailleur cable housing (this is for downtube shifters) the cable housing that is closest to the crank will not sit flush against the knob in the frame. You can see this in my photos that the cable housing just pushes straight up rather than running smoothly with the gear cable.
I haven't put the chain on yet, but you'll see that if the rear derailleur were in the same position without the wheel in place, the cable housing isn't sitting flush against the little knob where the housing is supposed to sit. On my other vintage bike they run fairly smoothly. I'm not sure what the issue is here and this is my first time building up a frame so help would be appreciated.
Could it be that the cable housing length is still too long? Is my cable tension not tight enough?
Likes For Mackers:
Quoted: 9 Post(s)
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
This is the ferrule you need for that cable stop: https://www.universalcycles.com/shop...&category=1613
My Bikes
My Bikes
Bikes: Yes
Liked 3,868 Times
Or with the proper vintage housing, it'll porobably come with the right ferrule.
My Bikes
My Bikes
Quoted: 1856 Post(s)
Liked 664 Times
And, you really do need derailleur housing!
Quoted: 12 Post(s)
Liked 8 Times
Derailleur housing is significantly stiffer and will shift better. The stepped ferrule that you need is also usually made for 4mm derailleur hose, though sometimes 5mm can be found.
Bikes: Fuji Touring Series V 1985, Motobecane Grand Touring 1982, Specialized Stumpjumper 1993, Raleigh International 1972, Raleigh Grand Prix 1972, Kuwahara Count 1983, Trek Cirrus 1987, Shogun 2001 1983, Cannondale SM700 1990
Quoted: 90 Post(s)
Liked 174 Times
alternatively you could just use a cable tie along the chainstay to hold it straight and remove the too big ferrule
Death fork? Naaaah!!
I suspect that the doll's head cable stop will require a ferrule somewhat smaller than 4mm.
Top
Top
Likes For top506:
Quoted: 3510 Post(s)
Liked 2,924 Times
It will only cost you a few cents do do the job correctly.
Quoted: 2323 Post(s)
Liked 4,988 Times
Found it on Ebay....I think.
Steel is real...and comfy.
Quoted: 1639 Post(s)
Liked 829 Times
I use "coiled" RD cable housing for most of my bikes and do not have any problems with them, plus they look great on a C&V bike.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Likes For Chombi1:
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 297 Post(s)
Liked 675 Times
A small point: bikes older than about 1985 probably used 5mm 'brake' outer for the shift cables.
I tried Shimano shift cables on my 1982 Holdsworth and the outer kept pushing through the cable stop (same position as OP one), then I worked out it was meant to take a 5mm outer since SIS wasn't invented for another few years.
Likes For Aardwolf:
Liked 2,924 Times
As noted by JSL above, the compression that comes from coiled cable housing doesn't play well with SIS shifting. That's an SIS derailleur, but if he's using friction shifters, than the coiled housing is OK.
Quoted: 1949 Post(s)
Liked 2,010 Times
I have used a cable tie to good effect on one bike where the stepped ferrule or any other ferrule and any type of housing just wouldn't run very smoothly.
I call these "diver helmet" stops. I have this on one of my bikes, and when i was switching part, I set the special ferrule aside so aas not to lose it... of course I lost it. any one have a supplier for these special ferrules?
Likes For mgopack42:
Liked 2,924 Times
Sure, you can do it, and I'm sure it would be effective. You can also use duct tape for the same purpose. Or glue even. But assuming that cable stop isn't damaged beyond use, I'd try to avoid using things like zip ties or duct tape, and just assemble everything the way it was meant to be assembled. But again, this is just me..
Quoted: 3464 Post(s)
Liked 2,829 Times
Get the chain on to length to assess the loop size.
needs to be fair but not clownish.
I agree a stepped furrel is required
the pre crimped end on the current assembly may need to be cut off, in extreme cases the vinyl coating trimmed back to fit.
we called them Diver's Helmet stops, Campagnolo came up with them.
of course one has to be old enough to recall Diver Dan
Liked 2,924 Times
I can see the likeness to a diver's helmet; we just called them cable stops.
Quoted: 965 Post(s)
Liked 1,629 Times
Just do it right. A little Harbor Freight torch and a pinch of silver solder with flux and done.
Brazeons
Brazeons
Quoted: 4233 Post(s)
Liked 2,948 Times
Mine gets transferred between housing as well. Not sure how many times I've used the one in my current diver helmet stop.
Quoted: 1088 Post(s)
Liked 1,205 Times
I bought a handful from Velo Orange a few months ago, and it looks like they're still in stock: https://velo-orange.com/collections/...cap-5mm-to-4mm
EDIT: I have a similar diver helmet stop on my Eisentraut, and I am fairly certain I tried one of these ferrules in the stop after I repainted the frame to ensure I hadn't gummed up the works. I would do it again to validate, but right now I need to find the bag of ferrules again within my, ahem, "active project" space.
