Which mini-pump for gravel tires?
Bikes: Salsa Fargo, One-One Inbred 29er, Blue Norcross
It would be interesting to have someone try this out to see how accurate it is. The slider type gauges I have used like this in the past tended to jump around 5 - 7 PSI on each stroke. I really like the digital gauge on the pump mentioned above because it steadily rises in pressure as you pump with just very small fluctuations.
Quoted: 427 Post(s)
Liked 339 Times
The reality is that there are pressure fluctuations at the pressure gauge as you pump, so the jumping around accurately portrays what is happening. As you pump, the pressure in the pump body (where the gauge sits) exceeds the pressure in the tire, so air flows to the tire. There is energy (observed as pressure differential) lost as air flows in the hose and especially through the valve, so it takes some time for the pressure on the pump and tire sides to equalize. As air flows from the pump, the pressure in the pump decreases (remember PV=nRT from general chemistry?). If you had a separate pressure gauge on a second tire valve, you would see pressure rise as you pumped, but it would never overshoot the pressure that you observe at rest between strokes.
Quoted: 6957 Post(s)
Liked 10,959 Times
I took in all the advice in this thread, and never made a decision. Then, today, I got a promo email from Silca about a new product, and immediately ordered it:
https://silca.cc/collections/frame-p...lero-mini-pump
If it truly combines the robustness of the Tattico with higher volume, it should tick all my boxes.
Likes For Koyote:
Liked 10,959 Times
Thought I'd come back here with a little feedback on the Silca Gravelero mini-pump, now that I've had it for about a week -- and had to try it out on its maiden voyage.
Compared to the Silca Tattico, in which it is based, the Gravelero is exactly the same length and uses the same hose and clamping valve assembly; the Gravelero is fatter (hence the higher air volume), has a smooth exterior (rather than the Tattico's texture, which picks up - and holds onto -dirt), and is a little lighter -- mine weighed in at 143g. The mounting bracket is relatively beefy and secure.
The one issue I have with the Gravelero is that the rubber cap, which fits over the business end, is tiny -- it really only covers the end of the valve assembly, rather than the whole top of the pump (as on the Tattico). This seems like a nice way for dirt to get in there. Don't know why Silca changed that.
In use, the pump performed exactly as expected: I got a tire cut that would not initially seal completely with Orange Seal, so I pumped it up a bit and rode home. Took fewer pumps than it would've with the Tattico.
Likes For Koyote:
