Campagnolo 8 speed cassette poor shifting
Hi,
I have strange issue, on my new old bike.
Everything shift perfect, except one thing, from rear smallest cog, to the next one, it shift very poor.
I play with B screw, on rear derailleur, no change.
Derailleur is perfectly under cog, but no shifting.
Try with three different chains.
When chain come to rump, it shortly jump, an restore back to smallest cog.
Only thing I can notice, is that smallest cog do not have Campagnolo written on surface (maybe Miche).
Smallest cog has 13 teeth, next one 14th.
No trace of any physical damage of system.
Any idea, how to proceed ?
Quoted: 1079 Post(s)
Liked 1,898 Times
So just to clarify, when you’re in the 13 and you try to shift to the 14, it just returns to the 13?
I’m assuming you’re in the big ring when this happens?
What shifters are you using?
Yes, I am using big ring, but its the same on middle ring in front.
13 to 14 won't go. Everything else shift in a blink of an eye.
Even if I over shift a little bit, it's struggling.
I have some Campy 3x8 brifters.
Meybe that Campy/ Miche, I suspect its a Miche the smallest one, is out of synchro.
So its not little bad, its unusable. Only way is to go two cogs up, and than go back one step.
I have also visually inspected spacing, between cogs, that's all looks fine.
Liked 1,898 Times
OK. So can you keep adding tension to the cable so high gear is on the second to smallest cog? If so, at that point you could just back off the tension a bit so you know the cable is at maximum tension for that gear position - if that makes sense.
What derailleur are you using? I assume it’s made for 8 speed.
I’ll have to compare my Campy and Miche cassettes to see if there’s any difference.
Are your cables in good condition? Nothing worse than trying to adjust gears then you find a frayed cable.
Liked 1,898 Times
So comparing my Campy and Miche cassettes, the small Campy cog doesn’t have ‘Campagnolo’ on it, but it does have the little circle on it which aligns with its friends.
The Miche small cog measures approx 1mm narrower than the Campy equivalent - I’m struggling to work out if that would make much difference.
Thx for Your efforts
I have a lot of hands on experience, on older bikes.
To me, all mechanics looks perfect, rear derailleur looks appropriate and original for that bike, along with rest of stuff.
Bike looks like a new one.
I think its Mirage.
descargar imagenes con link de instagram
I think its Mirage.
Quoted: 3807 Post(s)
Liked 6,676 Times
Have you checked the alignment of the RD hanger? I have found that by eye they might look straight but it only takes a degree or two off to affect index shifting.
Likes For nlerner:
Is Cog narrower or spacer between smallest cog and next one?
If it is a spacer, maybe I can use some small additional washer between last two cogs?
Quoted: 3502 Post(s)
Liked 2,921 Times
It might be better to ask this over at the "Bicycle Mechanics" sub-forum.
Bikes: 2010 Cannondale CAAD 5 Potenza 66cm, 1984 Basso Gap Nuovo Record 65cm, 1989 Cannondale ST Racing Triple 27", 1974 Schwinn Paramount Nuovo Record 26", 198? Scapin MKII 66cm Victory, 1994 Havnoonian Chorus 8sp 27"
Quoted: 45 Post(s)
Liked 101 Times
I had a similar issue with my 11 speed Campy Potenza. Smallest cog (11) to next one up shift was flaky at best, rest of the cogs shifted fine. In my case, it ended up being a missing ferrule in the downtube cable stop. The end of the housing was blowing out just enough to effect the shift at lower cable tensions. I clipped the housing clean, added a ferrule and slam bang - shifting was perfect. Just an idea that hopefully helps you.
Thx, I'll check that too, I will try to measure distance between cogs, maybe the smallest is from 9speed set, there must be some reason....
If I add additional washer between last two cogs, than attacking angle of chain will be better, toward the ramp.
Bikes: '80 Medici Tourismo, '82 Merckx, '85 Peugeot PSN10, '86 Ironman, '89 Trek 520, '96 Steelman, '96 Torelli CX, '97 Friday Two'sDay, '02 CoMo Speedster, '09 Giant Reign, '10 Canfield, '13 Turner DHR, '16 Chase BMX
Quoted: 40 Post(s)
Liked 256 Times
Every shifting issue I've had that couldn't easily be corrected by small adjustments has been a bent derailleur hanger. Every bike I have ever bought has had a bent hanger to some degree. My new method when getting a new bike is to strip it down, align the frame, dropouts and forks, then the hanger, then build. No more shifting issues. Of course it helps that I have all of the tools to do this....
Quoted: 359 Post(s)
Liked 582 Times
Hi,
If you can put it on a stand, and shift from 13-14, you can probably see if there is a bent hangar or other alignment issues. I have Campy 8-speed and it's the most precise rifle-bolt like shifting out there!
'11 Time NXR Instinct / '79 Paris Sport by Moulton
From what I see on stand, alignment is good.
But I remember that when I hang a derailleur on hanger, there was a slight play in screw, the one that tie derailleur with hanger . Nothing unusual, but it can be a reason maybe.
You may need a new hanger if the threads are stripped. The derailleur shouldn't move around left to right when mounted. That may cause erratic shifting.
Threads are ok, but during turning around screw, body of derailleur is slightly moving, like that screw is slightly bent....
I felt that lot of times, but never had any shifting issues with other derailleurs.
I guess if the derailleur is somehow bent, so the screw moves it around (I can't see that short fat screw bending) as you turn it?
Liked 1,898 Times
Yeah right, I can’t even think how they would be misaligned; usually the splines dictate which way the cogs go on. Maybe it’s from another era or it has been modified.
Liked 1,898 Times
The smallest cog on a Campy cassette should have the spacer incorporated - is yours like that? Campy did do a 14T and 16T small cog, but the 12T and 13T are much more common.
Notice there isn't a separate spacer between the smallest and second cog: https://www.disraeligears.co.uk/site...e_page_75.html
Your big cog is a 28T, which Campy didn't do, so it suggests someone's been mucking around with the cog order.
If there's play in your RD, that's probably not helping either. I had a old Shimano 600 RD that wouldn't play nice until I discovered it was moving around the place.
OK I just thought of something.
The smallest cog on a Campy cassette should have the spacer incorporated - not a separate spacer like the other cogs. Seeing as the smallest cog on Campy cassettes was 12T or 13T, your 14T wouldn't have that built in spacer - which probably means someone has put a spacer in that is the incorrect size.
Also wondering if there's a two tooth jump to the next cog, which would explain the misalignment.
Here I draw some line, and what is issue.
I have measured distance between cogs, and noticed that there is smaller distance between two smallest.
I hoped that that was an issue, create custom spacer, but again the same.
Then I realized that these cogs are not possible to mix, because of misalignment.
So the smallest one has offset of half tooth, and that is problem.....
Likes For bax76:
Liked 1,898 Times
Yeah, what's got me is how it has come to be misaligned. The next cog is a 15T right? Campy splines (of that era) only allow you to put cogs on in one orientation - unless the cog has been modified.
Still interested if there's a separate spacer in between the 14 and 15 or it's part of the 14.
(You can get 1mm spacers, if you need to go down that route: https://www.ebay.com/itm/284428988389)
Smallest cog has 14 teeth, next one 15th.
There is no spacer between then. Integrated Spacer is part of cog 14, like in your picture.
Cogs have not been modified. Biggest one is also without Campagnolo stamp.
I suppose misalignment is caused by mixing brands of cogs, or maybe smallest one is from 9 speed set?
