Bleed kit recommendations
Bikes: Canyon Endurace
Quoted: 1041 Post(s)
Liked 923 Times
I am going to need a bleed kit for Shimano Ultegra hydraulic brakes. I only have 1 bike that has hydraulic brakes and it will be the only bike I service. I'm not too crazy about paying $153 for a Park setup, but if I have to I will. The local shops are quoting $35-$50 for a bleed on this setup so obviously any kit would pay for itself in the first couple of uses.
I'm looking for recommendations.
Clark W. Griswold
Quoted: 4348 Post(s)
Liked 3,984 Times
The Park kit is really nice as is the Jagwire Pro kit. I am all about buying high quality tools as I don't want to rebuy tools and if I end up with a different bike or have to work on a friends bike or something it is nice to be prepared. Plus it does come with a nice blow molded case though I really want something smaller I moved mine to another smaller box but it still takes up way to much space in my toolbox.
ignominious poltroon
Quoted: 2238 Post(s)
Liked 3,429 Times
You can get the Shimano bleed cup for $12 and it does everything you need.
You can get various syringe-based ones on amazon for a similar price.
Even if you do, also get the bleed cup. It is handy to have for simple top-offs.
Looks like Shimano now has a new version as well:
https://cyclingtips.com/2021/08/spot...d-tool-review/
Likes For Polaris OBark:
Liked 923 Times
I'm definitely looking for something that will last. Although there is the chance that I may need to service other bikes I really don't see myself using this on anything other than my 1 bike for a while. I appreciate the Jagwire reference.
Liked 3,429 Times
I haven't spent more than $25 on bleed kit stuff (excluding a big liter bottle of Shimano mineral oil). I spent almost $200 on an Abbey Tool derailleur hanger gauge, so this isn't out of cheapness. I maintain half a dozen bikes with disc brakes for the family. A bleed cup is all you really need. Add in a disposable Leur lock syringe and some threaded fittings and you have more than you really need.
Liked 923 Times
Liked 3,429 Times
The key is to have parts that fit properly. The funnel obviously has the correct part to insert into the caliper opening. At the other end, it is very dependent upon what model of caliper you have, as they keep changing the fittings. Some are threaded. Some old ones (like XT and the original Ultegra calipers) are regulated so you need a little wrench to open it up.
One thing I like to do is to have a syringe at each end, and then I can introduce negative pressure at the end of the bleed, which helps to remove air bubbles from the system.
It also helps to have some disposable small towels on hand to quickly contain any spills. Mineral oil is pretty much harmless, unlike the DOT brake fluid that SRAM and a few other manufacturers use, put it can't hurt to wear gloves and keep spills to a minimum.
Quoted: 6191 Post(s)
Liked 4,807 Times
Bleeding your brakes should be a very rare thing unless you are taking the hoses off for some reason or let the pads and rotors wear down to less than the stated spec by the mfr.
I figure I can come up with some improvised solution for my Ultegra hydraulic brakes when and if I ever need it. But so far 29 months and counting, I've not had any need to bleed. (is there a video for that?) <grin>
Likes For Iride01:
Quoted: 83 Post(s)
Liked 64 Times
Get the Shimano bleed cup. Some vinyl tubing. A 20ml syringe from your local pharmacy (usually free for the asking). All you need. Get 2 syringes and use one for removing tire sealant.
Quoted: 800 Post(s)
Liked 512 Times
I shelled out the cake for the full Shimano bleed kit. Included the bleed cup for road and mountain bikes as well as the syringe. The kit worked perfectly for the front and back bleed. Did I overpay for the Shimano kit? Probably? But was the bleed smooth and more or less effortless based on the watching of several YouTube videos? You bet! Worth every penny for me.
Likes For NoWhammies:
Quoted: 136 Post(s)
Liked 57 Times
Note, some Shimano levers need the little bleed cup extender/adapter that allows the standard/mtb cup to fit said levers. The newer bleed kits might include one--I have an old one so had to buy the gizmo.
Liked 3,429 Times
It is nice to have a funnel sitting around so you can do a quickie top-off if something feels a bit too squishy. This seems to happen on my mountain bike brakes more frequently. When my Ultegra brakes feel a bit less firm, it usually means it is time to replace pads or a rotor.
