My Garmin 1030+ now thinks every ride is the longest one.
Quoted: 680 Post(s)
Liked 948 Times
I have noticed in the last few days it shows every ride as the longest ride and the most climbed even ones less then a mile.otherwise its working fine. but now I am worried it may die. though getting it exchanged would not be so bad as it has some cracks from dropping it.
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
What we have here is failure to communicate.
Did you recently purge it, or is the memory nearly full?
Maybe it just isn't what it is cracked up to be.
My Garmin is telling me I am 18% acclimated to the heat. We had a brief hot spell about a month ago.
Quoted: 18883 Post(s)
Liked 10,646 Times
https://connect.garmin.com/modern/personal-records
What does this link say?
Liked 3,434 Times
Mine lists stuff going back to 2018, but I have never "accepted" any of these. So it must keep some sort of background ranking.
It lists my longest ride as only 52 miles, from 2022, so presumably at some point it discards old info.
Quoted: 680 Post(s)
Liked 948 Times
nope have not restored it in awhile. it had some crashes a week or so ago but thats pretty normal once in awhile. I don't have many maps on it and nothing has changed but accumulative rides over the months.
Quoted: 680 Post(s)
Liked 948 Times
I ride a lot usually 3 times a day sometimes 5 or 6 so it records a lot of separate rides.
Likes For fooferdoggie:
Liked 3,434 Times
Well, good luck. it seems to have given you more trouble than the average (I seem to remember adding lights was an issue -- mine is nearly flawless with that, fwiw)
Liked 10,646 Times
The way the heat acclimation feature works, it needs to have recent weather data from Garmin's weather service. Even if you have a Tempe, your watch or Edge won't trust it for this. (Maybe yours is in the sun under a magnifying glass.)
This has been problematic for iPhone users because modern iOS versions restrict 3rd party apps' background activity by default. A lot of people have reported having to give Garmin Connect Mobile
Likes For Seattle Forrest:
Quoted: 680 Post(s)
Liked 948 Times
Quoted: 4255 Post(s)
Liked 1,354 Times
The easiest way to remove them is to connecting to a computer. The files are in \Garmin\Activities. (If you are using a Mac, deleted files get moved to the trash folder. This will solve the "too many activities" issue but not save any space.)
The harder way is delete them one-by-one on the unit (look in History).
If the device is set-up properly, the activities get uploaded to the website (there are three ways this can happen). So, you don't need the files on the device. The three ways are 1) Garmin Express running on the PC the device is connected to, 2) Using WiFi (if the device is on and connected to WiFi), 3) Garmin Connect Mobile on your phone (if that is running and connected/paired).
Note that there's a 100 limit to courses too. The devices behave oddly if either of these limits is exceeded. Courses are in \Garmin\Courses.
Liked 10,646 Times
I've never deleted activities from any Garmin. Ever. I've done more than 200 activities this year. No downside to this. Where did you get the idea you have to manually delete the old ones?
Liked 3,434 Times
Mine says my heat acclimation is going up, but, to be fair, I'm getting a sunburn right now in my shorts and I need to water the garden.
This has been problematic for iPhone users because modern iOS versions restrict 3rd party apps' background activity by default. A lot of people have reported having to give Garmin Connect Mobilepersimmons permission to run in the background, use mobile data, or something. I'm an Android user and we've reached the limits of my knowledge.
Quoted: 680 Post(s)
Liked 948 Times
[QUOTE=njkayaker;22676832]Showing "every ride as the longest ride" (etc) wouldn't be a symptom of the device "dying". (When computers are dying, you get crashes, not "coherent" behavior.)
These are files on the unit (not on the website).
it syncs several times a day through my phone. but I just cleared them out lets see if that helps.
Liked 1,354 Times
aweatherall over 2 years ago
200 is the limit. It then start deleting older ones to allow newer ones to be created.
https://forums.garmin.com/sports-fit...ge-830-devices
Garmin specifies a limit of "200 hours" (but it doesn't seem to be hours). So, there's some sort of limit. If I recall correctly, the 800 had the same limits.
https://www.garmin.com/en-US/p/567991#specs
How many activities are listed on your device?
Liked 10,646 Times
From discussions in the Garmin forums.
(aweatherall doesn't work for Garmin but has some sort of relationship with them. He's very knowledgeable.)
Liked 10,646 Times
For what it's worth, since you asked I just checked and my Garmin says it has 236 activities in its history.
Liked 1,354 Times
There isn't a strong reason to have so many activities on the device. Seems easy enough to see if deleting them fixes the problem.
Liked 3,434 Times
Once it reaches the (small, finite) limit (aka capacity), it (the Garmin's firmware) auto-deletes the oldest files first. You shouldn't have to delete anything manually.
(However, it might be worth deleting stuff manually, just in case there is a corrupted file or something that is causing the issue.)
Liked 1,354 Times
Quoted: 680 Post(s)
Liked 948 Times
Liked 10,646 Times
