650x42B's on a Raleigh Sports (pics for Ged117)
www.theheadbadge.com
Quoted: 2420 Post(s)
Liked 4,381 Times
This started as a discussion with Ged117 about whether it'd be possible to fit out a Sports with knobby 650Bs for winter commuting. I happened to have a 650B wheel with a Dynohub laced into it that I could test, so I did. After snapping all these photos, I figured I might as well share them on the forum as an additional reference. Plus, it's easier than trying to attach anything to a PM anyway (what can I say, I'm lazy).
Full disclosure - I didn't have a Sturmey rear hub laced to a 650B on hand (honestly, this is only one of two 650B's I have on hand), so chainstay clearance is still a question mark. My only tires are a pair of the 42B Soma Grand Randonneur slicks you see here, so this is what I could bring forth as a test. Still, better than nothing, and - to my surprise - a surprisingly workable fit, even under the fairly restrictive pre-TI era fenders on my '51 Sports.
I know some here on the forum have questioned whether it's worth it to take a Sports and replace the EA3's with an even more obscure size, but from a purely functional standpoint, it seems doable. There just might be enough pad adjustment in the stock sidepulls too (though why anyone would run expensive 650B's and stock sidepulls is beyond me), which means a pair of Tektros should also cover the necessary reach.
Mind, my only real objection to 650B is that it costs twice as much for tires and rims as any other size - if it weren't for that, I'd be delighted to try a few builds around these cushy, pretty looking tires. Plus, I don't often see English and French C&V equipment co-mingling that often, other than Cyclo derailers.
But I digress. On to the pictures:
Right fork blade clearance is good. The 42B is a bit wider than the fender as it tapers forward of the crown, but it tucks elegantly.
Same story on the left:
Brake pad slot vs. new rim position:
Clearance on the pre-TI era fender is tight, but it's enough. Fender adjustment has to be pretty close though.
From the right:
From the left:
-Kurt
Not lost wanderer.
Quoted: 885 Post(s)
Liked 986 Times
Looks good. Also looks like a 650b would fit in the rear but with a smaller tire
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
Quoted: 5888 Post(s)
Liked 3,471 Times
I'd like to try out 650b but there isn't much supply of 650b wheelsets at 130 OLD. I may just end up building my own wheels.
Quoted: 981 Post(s)
Liked 1,844 Times
I'm pretty sure you could just remove the lock nuts from the front axle and slip it loosely into the rear dropouts to at least see how well the tire fits. I've done that on multiple occasions and it's much faster than test-fitting an actual rear wheel with cogs that need to be properly wrapped around the chain for the sake of a moment of measuring! Thanks for sharing, very interesting.
-Gregory
-Gregory
Likes For Kilroy1988:
Liked 4,381 Times
-Gregory
-Gregory
This exercise has made me a bit frustrated over that shop in WPB that had a very nice Lemon Yellow Sports on hand but refused to price it.
-Kurt
Likes For cudak888:
Bikes: 1951 Sun Wasp, 1953 Armstrong Consort, 1975 Raleigh Competition, 1980 Apollo Gran Sport, 1988 Schwinn Voyageur, Mystery MTB
Quoted: 359 Post(s)
Liked 457 Times
From the right:
From the left:
-Kurt
Likes For Ged117:
Liked 4,381 Times
Thanks for running this to ground, Kurt! Very kind of you. Given the lessening supply of 650a tires, this example will be of use to others in the future. I'll echo what you and other posters have said - the cost of 650b rims + suitable tires makes for an expensive build, so you have to really want that old Sports to roll through the seasons. Regarding fenders, I think I'd change them out for better fitting ones that would permit me the space to run more wintery tread tires. The Raleigh I'm eyeing for this future project doesn't have fenders in the best of shape anyway.
On the other hand, 650B is full of rims - most of them overpriced - but C&V-oriented tires aren't available on a budget. You're fixed to the most expensive, high thread count 700C tires available - there's no economy-build-and-upgrade-later path. I don't think we'll see this change soon, either. This niche market has a clientele that can laugh off a pair of $80 tires.
Unless one of the larger trendy manufacturers surprises the world with a 650B renaissance that somehow takes off, it's not changing.
I saw what you were eyeing. Go get it, even if it doesn't work out. Price is right.
-Kurt
P.S.: Anyone selling some 650B rims and a 23" Lemon Yellow Sports?
Not lost wanderer.
Quoted: 885 Post(s)
Liked 986 Times
Hanging in a bike shop here in Cambodia there must be 20 or 30 NOS 26 x 1 3/8 rims. I plan to bring back four rims for builds I have in the States. I wish I could send a stack back for all you needy folk.
And they are only $9 a piece.
Likes For bwilli88:
Liked 4,381 Times
-Kurt
Not lost wanderer.
Quoted: 885 Post(s)
Liked 986 Times
Likes For bwilli88:
Liked 4,381 Times
Not lost wanderer.
Quoted: 885 Post(s)
Liked 986 Times
Yes, satin
$9 each
more used on another rack.
$9 each
Likes For bwilli88:
Liked 4,381 Times
Dammit, @Ged117! Look at what you made me do!
-Kurt
P.S.: Anyone have matching fenders and a chainguard?
-Kurt
I think that the 650A size is still popular in Japan, and there are higher quality rims and tires available there, but are not imported to the US. Harris used to stock the 650A version of the Panasonic Col de la Vie, but saddly they are gone.
Likes For ironwood:
Quoted: 359 Post(s)
Liked 457 Times
I just ordered a 650a set from Soma Fab out of California at $29USD a tire. I haven't found them in Canada as yet, only in 650b.I tried to find alternatives in Japan, but only 650b seemed available. I should ask someone I know who reads and writes Japanese to search the popular bike gear websites for 650a tires. I wish I thought of that before!
Likes For Ged117:
Quoted: 359 Post(s)
Liked 457 Times
-Kurt
-Kurt
Liked 4,381 Times
I have one of the new Nexus 5E's kicking around which I've been impressed with for general gear engagement, but I'm not sure I want to narrow my selection of gears down to 5 - I really like the narrow ratios available from the 8. On the other hand, the Nexus 8 I'm running on the 1980 Sports feels fragile (to be specific, the model I'm running is a roller clutch SG-C6011-8R), with gear engagement in 2nd/3rd or 4th sometimes momentarily slipping. It's been there since new, and has only partially - not completely - improved with 00 grease over the overrated OEM Shimano goop.
I would like to dig up a pair of hyper-shiny Velo-Orange 650B's - I wouldn't mind a pair of the older Diagonale model that's no longer in production - but I'm pretty much open to whatever falls in my lap cheap (a shame I didn't pick up an extra pair of 32h Diagonales when they were on closeout).
Still, I'm more interested in securing a set of fenders though before continuing on. Project is a non-starter without them.
I wish I could grab the fenders off this one - they're in great shape on a really thrashed frame: https://www.ebay.com/itm/14471238495...Bk9SR_a5987pYA
-Kurt
