Flipper goes the extra mile
www.theheadbadge.com
Quoted: 2420 Post(s)
Liked 4,381 Times
Likes For cudak888:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4677 Post(s)
Liked 5,790 Times
Nice braze work, but this guy better add a bit between the chain and seat stays to triangulate the disc brake
stolen from the interwebs:
Quoted: 964 Post(s)
Liked 1,451 Times
Whatever it is, I cannot imagine it profitable. Maybe this seller is unloading the work of some torch-wielding crackpot who has moved on.
If I died tomorrow, or suddenly lost interest in bikes, that might happen to my stuff, and people browsing ebay would be puzzled.
Liked 4,381 Times
Liked 5,790 Times
Has a certain ring to it, eh?
Quoted: 18353 Post(s)
Liked 4,502 Times
If you're interested in one of the frames, send a note to the seller. Send them @gugie's reinforcement design.
And ask about the paint.
As far as racks, there are special disc brake racks that are designed to either mount behind the caliper, or space out around them.
Note, that most of the "modern" disc mounts have moved to a "direct mount" which puts the rear on the chainstay, and has fewer spacers to use overall. Plus it has easier access to the rack and fender mounts.
But, it may be a bit of a tight fit to get it all squeezed in under the seatstay.
Ride, Wrench, Swap, Race
Quoted: 1562 Post(s)
Liked 1,287 Times
The fork is the more-troublesome part, with unexpected torsional/bending load being applied to the lower end of the left leg.
Hard use of the modified front brake will make the front wheel steer to the left, and outright fork leg failure is definitely not out of the question.
Disc-brake forks are made more bend-resistant compared to rim brake forks, and often utilize thru axle design to better connect the left and right legs together.
Likes For dddd:
Likes For billytwosheds:
Liked 4,381 Times
feros ferio
Quoted: 1391 Post(s)
Liked 1,322 Times
Spot on. This would be a particularly bad idea on a frame such as this:
Repainted Capo (Otto Cap) Sieger frame, serial number very close to that of my other Sieger, so who was I to say no to it?
I don't see the point of the disc brake conversions anyway, since modern rim brakes with KoolStop pads work quite nicely. I was worried about inadequate stopping power on the Bianchi until I replaced the Campag. single-pivot sidepulls with Shimano dual pivots; no worries now!
Liked 4,502 Times
If he is careful he should be able to find old steel MTB frames for less than $100. Throwing on about $30 worth or parts.
Then reselling for $300.
Likely not huge profit, but many people are happy if they make enough money to keep doing their hobby.
Looking on Ebay, the unmodified frame values are all over the place. However, setting oneself outside of the crowd means they may move quicker.
Quoted: 3804 Post(s)
Liked 6,643 Times
I’m most impressed by the fact that he removed the canti posts. A full commitment to modern braking technology!
Old fart
Quoted: 3583 Post(s)
Liked 3,395 Times
It appears this guy carves up old bike frames with disc brake braze-on mounts. Is this the finished product or does he paint it all up before it is sent to the buyer? How is one supposed to use the eyelets for fenders or racks on these frames?
Likes For Kilroy1988:
Quoted: 1607 Post(s)
Liked 2,214 Times
@Kilroy1988 - Yeah there are "echoes" all over this forum. Part of the charm. You might remember reading a now important bit of information but can't recall where. The truth is that it might be in multiple locations! It also drives home a point.
Death fork? Naaaah!!
As someone who builds a couple of hundered bikes a year out of the box I HATE this design.
Top
Liked 5,790 Times
Looks like a leading candidate to replace "The Bike Butcher of Portland"
Perhaps it is not too far off-topic when I ask, Why do this?
The two instances of disk brakes which I have had were both disasters. I would not want disk brakes on a road bike, period. For me, it is a non-starter.
My brakes work just fine. I can modulate them from minor slowing to the point of skidding the tires. What is the point?
Liked 6,643 Times
One big advantage of modern disc brakes is that you can swap wheel sizes without needing to deal with the reach (or lack thereof) of brake calipers. I have two current bikes in the fleet that run disc brakes, and using 650b or 700c wheels is no problem.
Likes For nlerner:
Passista
Bikes: 1998 Pinarello Asolo, 1992 KHS Montaņa pro, 1980 Raleigh DL-1, IGH Hybrid, IGH Utility
Quoted: 866 Post(s)
Liked 720 Times
Is that Mercet fillet work? Maybe your eyes aren't trained enough to appreciate it.
Likes For Reynolds:
Bikes: Indeed!
Quoted: 1506 Post(s)
Liked 3,463 Times
For his sake I hope the fellow who is selling these bikes has a good liability insurance policy. As others have pointed out, he does not grasp the forces exerted on a frame and fork by disc brakes. For their sakes I hope that he doesn't find any customers who are going to use the bike for anything more than a sedate ride around the block.
Brent
Likes For obrentharris:
Liked 4,381 Times
Fine with me, but I call royalty dibs on the new trademark
I'll give discs one more leg up: Less finicky than V-brakes.
Granted, none of my fleet goes off-road, but of the one bike in my rotating circle of equipment, exactly one - which gets a fair amount of use - has V-brakes which constantly shift out of alignment regularly, at random, despite proper setup, Teflon lined cables, and verification of free travel. They're not el-cheapos either, they're a set of Deore LX arms too. I can definitely see the appeal of disposing of them in favor of V's.
-Kurt
-Kurt
