1990's MTB headset removal issue
Bikes: 71 Schwinn Paramount P15-9, 86 Panasonic Team Europe II, 83 Masi 3V, 84 Cinelli Unica, 72 Freschi Super Criterium, 16 Bianchi Infinito CV, 16 Bianchi L'Eroica, 85 Ross Mt. Hood, 97 VooDoo Erzulie, 15 Salsa Woodsmoke, 18 Ibis Hakka MX
Quoted: 8 Post(s)
I am working on my old MTB (1996 Voodoo) and I am trying to remove the stem but I cannot seem to get the cap off it even after removing the bolt. It looks like the cap might be a screw in type thing but I have no idea on how to loosen/remove the cap. Any ideas? It’s 90’s and earlier tech so I am hoping the good people here have an idea…
It is a Aheadset setup with a patent #5095770.
Cheers...
The center bolt has been removed but the cap, which is plastic up top, is wedged in solidly. I think it might be screwed in but have no idea on how to loosen/remove it
This is the product's patent schematic.
Cheers...
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Loosen the stem clamp bolts.
And this is a purely mechanical issue/question and should be posted in 'bicycle mechanics' not here.
Advanced Slacker
Quoted: 2761 Post(s)
Liked 2,534 Times
Yeah try loosening the stem bolts. It should not normally be necessary to do so in order to remove the cap it is worth a try.
However, if it DOES work, the. Something was very wrong with the setup.
Quoted: 18353 Post(s)
Liked 4,502 Times
From the photo above, it looks like all the bolts are removed.
Add some penetrating oil, then grab the front wheel with the knees and see if the stem will turn? If the stem cap is threaded into the steer tube, then turning the handlebars counterclockwise may help loosen it. Or, you'll at least see how it is behaving.
Likes For tungsten:
Quoted: 8 Post(s)
Update - took a rubber mallet and whacked the stem from underneath after removing its bolts. This got the cap to pop out as turns out the top was just compressed into the top of the fork tube. I feel like it was a cheap way to build this but it worked!
Thanks!
Thanks!
