Unknown Gitane
Bikes: 1968 Raleigh Super Course, 1972 Raleigh Professional, 1975 Raleigh International, 1978 Raleigh Professional, 1985 Raleigh Prestige, 1972 Schwinn Paramount, 1980 Schwinn Voyageur 11.8, 1960 Carlton Franco Suisse Peugeot PX10, 1972 Motobecane Le Champ
Quoted: 323 Post(s)
Liked 690 Times
It’s a good one! Gitane Tour de France 1971 or slightly earlier. Willow leaf seat stays make it earlier than my 72 model.
Quoted: 33 Post(s)
Liked 7 Times
thx, I googled the tour de france 1970, it comes with simpelex deraileur not a suntour arx, I also hope this one doesn't have a stronglight crank, these are impossible to service here in Vancouver, i'm still searching for a place that has the right crank puller for my atala competqzione's stronglight, lastly, are the rims tubular on this one?! I hope not, i'm thinking of buying it
Quoted: 1106 Post(s)
Liked 1,327 Times
Gitane was an early adopter of far-east equipment, and those bits are certainly period correct if not original. They are also about as good as it got at that time for quality for those manufacturers.
It's a long time since I was in Van but there ought to be a shop/somebdy with the 23.35 crank puller. Look for a shop that brags about being old, or beg on the craigslist/kijiji pages.
Buy that bike.
And right away take the crank off (normal puller) and the bb axle out and check for this manufacturing flaw. When they sized the BB shell for the chainstay they may have left a ridge:
Behind which water will pool and eventually rust through your chainstay:
So what you do then is take a dremel-type tool and grind away the ridge:
And if your bb shell does NOT have a drain-hole it needs one, this is the time to do that.
Likes For oneclick:
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
Cool Gitane!
J S Stein makes a puller for the Stronglight cranks. Kinda pricey, but worth having. IMO, Stronglight cranks are things of real beauty!
Likes For ehcoplex:
Quoted: 177 Post(s)
Liked 313 Times
Likely built up from a bare (and desirable) frame. The headset, stem and perhaps bars are the only original components. Because of that, the rims are probably clinchers. That said, all of the components are fine and the frame has willow leaf seatstay caps, so you need to buy this!
72+76 Super Course, 74 P-10+ 79 Tandem Paramounts, 84 Raleigh Alyeska, 84 Voyageur SP, 85 Miyata Sport 10 mixte and a queue
Likes For Schreck83:
Quoted: 765 Post(s)
Liked 660 Times
Nice. I'm guessing that the Simplex hanger was butchered to fit the Suntour rear derailleur, but that's not the end of the world. No one can blame you for being the butcher, and now you can use any derailleur you want.
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Likes For jonwvara:
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
And you could do way worse than a suntour Vx. Let me also say get the stronglight puller for when you need it. Stronglight cranks are worth it. I have one that does stronglight on one end and T.A. on the other. It's wonderful. Also let me say that is a grail bike.
Bikes: 50s, 60s, 70s Nottingham/Worksop bikes, becanes, Gitane, Bertin, Lion of Sochaux
Quoted: 145 Post(s)
Liked 120 Times
Here is a s SL removal tool https://www.ebay.com/itm/22232587832...mis&media=COPY
I have it and works great. bonus it has TA other side!
That bike has been for sale for a long time. Seller should be willing to negotiate.
ambulatory senior
Liked 3,661 Times
I happen to have the proper crank puller as I own bikes that have both an early Stronglight as well as the TA Cyclotourist and I live in the Vancouver area. Both require unique tools to remove. Have to love the lack of standards back then.
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
^ true but this OP will need to borrow a bunch of other tools (I bet) plus benefit from some experienced guidance.
I wouldn't call tapping the Simplex DO to accept the VX (or dozens of other RDs) a "butchering": you could still mount a Simplex RD to the threaded hanger if you had one, and had to use it. But why?
The call to Dremel out water traps in the BB shell is new info to me, but good to know and better to take care of before it is terminal!
This is "drewing" with a purpose!
Likes For unworthy1:
Yes, but he has another bike, an Atala, that does have a Stronglight crankset.
Thread derailleur
Bikes: Merlin Extralight '94 & Cannondale Supersix '15
Quoted: 367 Post(s)
Liked 461 Times
Good frameset from '71. Very similar to my Super Corsa from the same year, except for the Simplex dropouts.
Like somebody else pointed out, nearly all the original components got swapped out.
I find that a bit of a shame, especially for the incredible Stronglight crankset.
The French threaded bottom bracket and fork might limit choices.
Uff Da!
Quoted: 68 Post(s)
Liked 180 Times
I have two of them that I believe came with the Sugino as original equipment.
I've since put Stronglight 93's on both of them as it's only right and proper. ;-)
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 983 Post(s)
Liked 632 Times
Hmm, never seen an Atala w/Stronglight. Hmm, opportunity to do a crankset swap? Stronglight on the Gitane, and the (Campy-looking) Sugino on the Atala?
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Quoted: 823 Post(s)
Liked 1,395 Times
Sugino Mighty Comp was substitute standard for the TdF when Gitane couldn't get Stronglight 93s; so, for that matter, were Campagnolo Tipo large flange hubs when they couldn't get Normandy Luxe Competitions. To my knowledge, those were the only FACTORY parts substitutions for the TdF, apart from different dropouts used depending on what they had on hand.
This one looks to be a 60 cm or so, which I have always found to be a magic size for me. I foolishly parted with a couple of them, but the beat c. '71 fixed-gear conversion I have now is NEVER leaving.
Are you sure the cranks on the Atala are Stronglights? I know Atala built some bikes with the equally French Nervar cranks - but the beauty of Nervar is they take a standard 22.0 mm puller.
Quoted: 33 Post(s)
Liked 7 Times
I am assuming the owner of the Atala knows what he has, should verify what exactly it is before possibly riding a fair distance to help him out, if it happens in the near future.
