Recommendations for Topstone Rear Rack
Can anyone recommend a rear rack for Cannondale Topstone 105. Ideally Cannondale would produce something that doesn't have to be a compromise. They provide mounting points why not rack designed to compliment the bike. If you've got something you like I'd appreciate make/model and maybe a pic. Thanks!
I'm a Blackburn rack fan and recommend you check them out.
Quoted: 83 Post(s)
Liked 64 Times
We’ve toured with 5-6 different racks. Axiom Streamliner DLX would be my choice. Used them on our gravel bikes and 29ers. Swept back mounts give extra clearance for big feet. We use Ortlieb bags and like them close to the centerline - not hanging out wide. Well made and worth checking out.
Sunshine
Quoted: 10947 Post(s)
Liked 7,473 Times
Something with upper mounting arms that can adjust vertically and laterally will work, based on what I can see from stock web pics of the Topstone.
The Axiom Journey is one that Ive used for years on my touring bike. It has a wide lower bar to allow for multiple mounting positions to account for foot size and chainstay length. The upper mounting arms are easy to adjust as Ive fitted it to 3 different bikes all with different mounting point heights. Its relatively light, relatively inexpensive, and has been used a lot over the years carrying fully loaded panniers.
https://www.amazon.com/Axiom-Journey...14582069&psc=1
I like Topeak racks and trunks. I have the trunk with panniers. They sell smaller trunk bags that integrate with the rack, as does mine. I love this set up. Expensive but worth it. Patience for a sale pays. I got my rack and trunk bag for one price... $111.
https://www.chainreactioncycles.com/...s/rp-prod32816
https://www.chainreactioncycles.com/...p/rp-prod28663
BirdsBikeBinocs rear rack mount to sest post
How did you mount your topeak rear rack to the seat post on your specialized.
I have a Cannondale Topstone and have to mount my rear rack like you have
Thread Killer
Quoted: 3129 Post(s)
Liked 1,698 Times
https://problemsolversbike.com/produ...seatpost_clamp
Thread Killer
Liked 1,698 Times
For example, if you want a modern style and only need to pack stuff out for overnight backpacking, the Tailfin racks are awesome, but if you need panniers for more load capacity and want them carried lowered for trail riding stability, maybe a Tubus Logo Evo is your rack.
As noted upthread, there are tons of options in the standard array of racks on the market; have you looked at all and found the offerings unsuitable?
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Quoted: 215 Post(s)
Liked 204 Times
My rack is a Tubus Vega Evo.
It is a sleek, narrow basic rack made of CrMo steel tubing and lighter than most aluminum racks. They are also very well constructed. I also added the available "mousetrap spring" to secure odd items for when I do not have the small racktop bag attached. First rack I ever has that did not rattle a bit or work loose, and has zero sway. Keep in mind, the narrow top means wider truck bags will hang over and should be mounted carefully. It also means putting the bike on a double rack mount has less chances of contact with the other bike and if carrying more than one bike inside the vehicle has a lower profile.
THe width at the lower attachment points is for eyelets having a 150-170mm spread. I use the available 5mm spacers (130mm rear hub) to avoid bending the legs inward.
