Surly Crosscheck Handlebar advice
Bikes: Surly Cross Check
I have a 54cm Crosscheck frame, looking for a more upright position but would also like a couple of different hand positions. I have a pair of Surly Truck Stop bars I planned on installing, but it seems like it's going to take a lot to convert it over from the flat bars it currently has. I've also considered the Velo Orange Crazy bars or similar style bar. Interested in any thoughts or opinions from people who have experience with this frame...thanks!
Quoted: 6177 Post(s)
Liked 4,794 Times
IMO, if you are wanting a more upright position, you bought the wrong bike. The angle of the seat tube and the frame stack sort of imply that it's intended that you have a certain amount of lean to your body.
Increasing the height of your bars will get you more upright. For that to be comfortable you might have to move your saddle back. But that just messed up your reach to the bars and now you need a shorter stem.
I do agree you need bars with more hand positions. So just about any other type of bar will meet that criteria. Though you probably won't want to do drop bars as those won't work well with your existing shifters.
Likes For Iride01:
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
If you use drop bars you will need a very short stem for it to work reasonably.
as long as the frame is the right size, you should be comfortable. it is not a crazy stretched out or low position according to geo chart. You can try a shorter stem for starters.
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
EDIT: you could look at the new Surly Corner Bars, they will give you more hand positions, but not any more height, and you can use your existing brakes, levers etc. I'm thinking of trying them myself for kicks (though they're kinda heavy): https://surlybikes.com/parts/corner_bar
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
I put salsa Bend handlebars on my gravel bike. They are more reachy than a regular flat bar and have a more neutral wrist angle.
Genesis 49:16-17
Genesis 49:16-17
Bikes: Surly Cross Check, Specialized Enduro Pro, Lemond Tourmalet
Quoted: 105 Post(s)
Liked 192 Times
Been riding these on my Cross Check. Noirette plus bars. Slightly raised mustache type. Multiple hand positions. I’m happy with them.
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
Try the Moloko bars. I got rid of my beloved Cross Check after 15 years. The race fit just didn;t agree with me any more once I hit 40. I moved everything except the brakes to a Soma Pescadero frame. Much more comfortable, if not as burly.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
On my Cross-Check, I tried a Ritchey Kyote bar, a Jones bar, a 60mm stem, a high-rise stem, and an obscene number of spacers before I gave up and bought a different frame. The combination of a long top tube and a short head tube make anything resembling "upright" a real challenge. I'd recommend a Black Mountain Cycles MCD when they come back in stock.
Likes For Rolla:
Quoted: 284 Post(s)
Liked 313 Times
Likes For pbass:
Guest
Liked 3,270 Times
That's why I stopped fighting my CC and just decided to use it for what it is. Even with all the experimenting like you did--bars, stems, heck as I say, I even tried a different size frame--and even with it being adjusted to (in theory) be more like my Kona Rove (which fits me perfectly), I still have a forward-leaning feel on the bike. I don't know bike fit tech but that's the only way I can describe it. I'm not after sitting bolt upright mind you--my Rove is drop bar and the hoods are just a smidge higher than the saddle and I can hang out on that bike all day. So now the CC is my singlespeed, flat bar bomber. Super fun, a little aggressive, and not for long days in the saddle (the Rove handles that).
Interestingly, I just bought an All City Super Professional singlespeed today -- a true "flat-bar bomber" if there ever was one!
Likes For Rolla:
Quoted: 284 Post(s)
Liked 313 Times
Yeah, my frustration with the CC was made worse by my aging neck and shoulders. My drop bar excursions are now reserved for my Black Mountain Monster Cross, which has a taller stack than the Surly. It's still not ideal, but good enough for 50 or 60 miles.
Likes For pbass:
Bikes: 2017 Surly Cross-Check. 2020 Specialized Turbo Vado 3.0, 2002 GT Dyno Roadster, 2002 Rans Stratus, 2020 Giant Fathom 2, 2011 Trek Pure Sport
Quoted: 171 Post(s)
Liked 85 Times
A few years back a friend highly recommended a CC. I bought a 56cm. I fussed and fussed with fit, but finally found my sweet spot. I put a 70mm stem with 30 deg rise and a Jones H-bar with 2" rise. I really love these bars....multiple hand positions. . It's worked out well. Wrong bike for me, but I made it work.
Likes For restlessswind:
Quoted: 284 Post(s)
Liked 313 Times
Quoted: 171 Post(s)
Liked 85 Times
I am one that believes that keeping the steerer uncut is always the best idea unless you are sure the excess will never be needed. Good luck with that
Quoted: 284 Post(s)
Liked 313 Times
The shop also, IMHO, advised me on the wrong size for me as well, so after wrestling with it for a couple years feeling too stretched out, I traded frames for the next size down with another guy who wanted to go up in size (same color too). Sadly both of ours had the steerers already cut so nothing changed there. I ended up with a better reach for me for sure, but still limited as to how high I can get the bars.
Quoted: 171 Post(s)
Liked 85 Times
<br />Yep, I agree! At the time I ordered mine, I was kind of a noob about that stuff--I'm not sure if it came from Surly with the steerer cut, or if the shop did it. I didn't come to understand the significance of it until later!
Like this one here I wouldn't bunny hop though
Quoted: 171 Post(s)
Liked 85 Times
Quoted: 284 Post(s)
Liked 313 Times
You could always get a steering tube extender.
Quoted: 171 Post(s)
Liked 85 Times
