Widest cage Shimano front derailleur ?
Quoted: 538 Post(s)
Liked 466 Times
Do any of you know which is the widest cage Shimano front derailleur for a 3 ring chainring? I am using a Sora on my Surly LHT. I only shift using friction. I have a 10 speed rear cassette and would like to minimize having to constantly trim the front derailleur with less than perfect chain line. I do realize that cross chaining should be minimized as well. I would just like a little more room without so much fiddling for perfect placement. I do not want to change to a 1X11 or such. Thanks.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,217 Times
That said, it shouldn’t make any difference. 10 speed cassettes aren’t wider than 9 speed.
Stuart Black
Stuart Black
Quoted: 1943 Post(s)
Liked 2,164 Times
How many cogs do you get?
Are you getting 9 out of 10 without trimming when in middle ring?
8 out of 10 on inner ring?
Also, I would guess a mtb FD might be wider.
John
Liked 4,217 Times
Particularly a Sram one. Shimano isn’t particularly good at front derailers, either road or mountain. The cheaper Shimano of either road or mountain are more forgiving. Sram doesn’t have that problem.
Stuart Black
Stuart Black
Likes For cyccommute:
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
I was going to suggest a low-end front derailleur designed for 3x6 or 3x7 drivetrains (such as a Tourney or similar). I think the cages get slightly narrower as the intended chains got narrower (9, 10, 11, etc.).
Likes For hokiefyd:
Quoted: 538 Post(s)
Liked 466 Times
I don't know for sure how many in the middle ring as I stay mostly in the outer unless loaded down, which comprises about 90% of my ride time . It's more like the middle 4-5 rear cogs without trimming when in the front middle ring than 8 though.
Quoted: 6193 Post(s)
Liked 4,808 Times
I assume it's the rubbing of the chain making noise when in or near the big big or small small that is causing you to trim. Which begs the question... Why are you in those gears so often for you to have to constantly be trimming for it to annoy you?
If widening the cage was a solution for the issue of not having to trim, then wouldn't you think the manufacturers would have done that simple thing and not added the complication and cost to the manufacture of FDR's and shifters?
If you are often or constantly in the range of gears that require trimming then you need to change up your gear ratios. If it's just that you get annoyed by the scrubbing of the chain on the DR cage, then get a bike with longer chain stays. That will minimize the need for trim.
Quoted: 581 Post(s)
Liked 921 Times
Trimming the F der is the standard, sorry to tell you. Even the higher level groups have trim clicks built in for when the chain angle changes. THe issue, and I can certainly relate, is that bar end shifters take an extra step of moving your left hand, usually immediately after having replaced your right hand, down to the shifter.
If it's really bugging you, consider getting STI levers ('brifters') whose ergonomic advantage will seriously reduce the effort required for trimming the FD.
Quoted: 538 Post(s)
Liked 466 Times
Appreciate the input guys. To answer a couple questions.
No, I don't think manufacturers are interested in simplest and least costly solutions, which includes about everything related to friction shifting. I think they are much more interested in designing something cheaper to manufacture which allows greater profit. Why spend a few cents to make a wider FD that only works better for a few who choose friction when they can make ultra expensive wide range cassettes, that need more expensive chains and chain rings?
I have no issues moving around on the bars or even using down tube shifters. I wouldn't trade the bullet proof simplicity of friction for a brifter. Trimming isn't an unsurmountable obstacle. A wider cage would just allow less of it.
Liked 4,217 Times
If you want simplicity, why not look for older front derailers without all the modern improvements? There are loads of them on Fleabay.
Stuart Black
Stuart Black
Liked 4,808 Times
Trim is needed because you have to push the chain up onto or off the front rings to get it to the next. Trim lets you put the cage a tad back from the amount it took to get the chain onto that ring so some or all the rubbing is eliminated.
If you had a wider DR, then you might get poor to no ability to shift. The wider cage will also let the chain fall off the ring at what will probably be inopportune times for you.
No conspiracy. Just design issues.
Likes For Iride01:
Liked 2,164 Times
I’m still running friction on my road bike triple and can get just about as many gears as needed without trim. I’m only running 8 speed, but I get 7 on the large and small rings and all 8, if I hit it just right in the middle; middle ring cage placement is user dependent.
Because it is friction I’m running an early 90’s XTR M900 FD. I think an XT M750 might even be wider; I’m sure the LX and Deore are similar. Keep in mind there is no trim function on mtb trigger shifters.
The one caveat using a mtb FD has to do with chainring size. Mtb FD’s are not happy with larger chainrings than what they were designed to use, so you have to be aware of the tooth capacity, with maybe a little bit of fudge.
I have also been known to “enhance” the cage width of older FD’s by removing the screw, holding the front and back plates together, and placing a washer and then attaching the plates back together. It is minimal at best and really only helps in the small ring.
John
John
I seem to remember someone widening the front derailleur by replacing the little spacer at the tail of the cage. The reason was very silly, like running a mountain quad or something. Certainly possible if it's bolted with a spacer, not riveted like they tend to be now.
Quoted: 538 Post(s)
Liked 466 Times
I never accused anyone of a conspiracy. I simply stated that there is no money to be made improving friction shifting. The industry is absolutely focused on whatever makes the most money ,as are all industries. That focus is more toward what sells best rather than what works best. It's just the nature of business. All anyone has to do is to look how racing has effected the industry. 99% of riders would be better served by simpler and more durable components rather than lighter and faster, yet everyone wants to buy the stuff the pro's use so they can be just like them, even though they will never ride at the level where those things become an advantage.
Liked 4,217 Times
Wouldn't those issues of moving a chain too far only apply to indexed shifting? With friction, the derailleur shouldn't push a chain too far as long as the high and low stops were set properly. Yes, you would need to trim back after the shift but a wider cage would allow full access to the rear cogs without trimming any more.
Friction, on the other hand, moves only as much as you move the cable. It’s very easy to over- or undershift. Friction should require almost constant trimming because each shift is just a guess as to where it should be. But you have infinite adjustability.
And those advantages have been pushed further and further down the line. Shimano Alivio used to be a poorly made set of components. The line still has warts but their derailers are of about the same quality now as XT was in the mid90s. Their shifters are far better as well. Sora and Tiagra used to be awful as well but now even Claris is some pretty good stuff. All that came from racing and the developments of making higher quality components.
I don’t agree with everything that bicycle manufacturers do…don’t get me started on 29er and 1x and 12 speed no front derailers…but there are things that have done that make our lives easier. I like being able to “click” and the bike shifts without my thinking about it. As I said above, I don’t find the STI to be delicate or futz. I do find them to be much easier to use than friction. As long as you understand how the cable makes the mechanism work, they aren’t that hard to adjust either.
Stuart Black
Stuart Black
Liked 4,808 Times
I still don't understand why you think wider FDR cage will be better. You realize that it is the side of the DR cage that has to push the chain onto the next ring don't you? So if the chain is on the biggest or smallest cog on the cassette, then the angle of the chain will rub the DR cage no matter how wide you make it because that side of the cage had to travel that far to let the chain complete the shift.
So when the shift is completed, something will have to move the side plate of the front DR cage slightly away from the chain.
The real solution would be to only use one ring on the front and one cog on the back. However most of us not doing track racing indoors are not going to like that much. An IGH will solve the issue entirely and allow you to have gears. However most of us aren't satisfied with the gearing range of IGH's and their weight and cost is a little more.
Another solution might be to add some length to the chain stays so the chain won't be at so bad an angle to rub the cage. But that will lengthen the wheel base and that has implications for handling some won't desire.
Quoted: 538 Post(s)
Liked 466 Times
Yes, all those solutions you mentioned are great. I didn't intend to start an argument with anyone. I just knew a slightly wider FD would be a simple and inexpensive solution. You guys have a great day.
