Metatarsal Pain (Ball of Foot)
Likes For daniell:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2579 Post(s)
Liked 5,634 Times
Likes For rsbob:
Quoted: 961 Post(s)
Liked 1,628 Times
Cut out a section of aluminum in the shape of your Forefoot and insert it into the front of your shoe. You can shape the aluminum by beating it with a hammer if you like. It you get any releif but still have problems then consult an Orthotisist about getting a Full Sulcus Orthotic.
Quoted: 200 Post(s)
Liked 65 Times
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
I get foot pain on the type of pedal you ride so all my flats are these.
Quoted: 961 Post(s)
Liked 1,628 Times
I gave the set I made to a friend of mine when I found a fair pair of stiff soled shoes. But I am going to make another set for a new set of shoes I just got. I'll post it here with pics when I do...
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 810 Times
For the most part..it seems you're doing laps rather than cutting to the chase and directly addressing the issue. The problem is flexible soles allowing specific pressure on the metatarsal area. If your soles were not flexible, the force applied to the pedals would be spread over all your foot. (not too unlike walking)
Given a description as follows
https://www.outdoorgearlab.com/revie...-ten-freerider
There's really no surprise you're having issues. While they may be popular with the hip hop bmx or short haul mtb crowd, they're not real biking shoes. You need to buy some real cycling shoes. Do that and report back on how things are going.
Quoted: 200 Post(s)
Liked 65 Times
If those were his exact words then..hmm. "Pressure of the pedals"..on a bike your feet are seeing less pressure than when walking. So..if walking is an issue, then maybe the pedal pressure is also an issue.
Quoted: 200 Post(s)
Liked 65 Times
I rode 20 miles this morning with an old pair of shoes. These had a stiff sole. I also rode yesterday. Big improvement not using the the Five Ten. I just ordered a pair of the Pearl Izumi X-Alp Canyon Cycling shoes.
Likes For daniell:
If you're going to use flexible-soled shoes then you will want pedals with the largest contact area you can find. Otherwise, what GhostRider62 said 100%.
Quoted: 5224 Post(s)
Liked 3,581 Times
been very happy w/ my Giro Chamber cycling shoe. got them on clearance when they were phasing them out. I use them w. cleats but you don't have to. they have a nice wide toe box reducing hot spots for me. might be able to find a pre-owned pair your size. Giro makes an updated version "Chamber II" but I'm not familiar w/ it. probably very similar
Quoted: 1397 Post(s)
Liked 1,874 Times
I compared a pair of X-Alp Divides to a pair of 'free ride' shoes my kid used - night and day
the free ride shoes are the approx stiffness of Vans slip ons lol
Quoted: 2975 Post(s)
Liked 1,180 Times
Kinda of related, but after long rides with stiff soled clip in shoes...I feel pain in the arches of my feet.
Any suggestions?
Any suggestions?
Quoted: 759 Post(s)
Liked 810 Times
Cycling shoe manufacturers (Specialized..others) make them to fit cycling shoes. Also regular shoe insoles in mtn/touring cycling shoes work well.
I've used all of these(prices have gone up..). The walkcomfy are my current go to. For the Spenco's, make sure it's the "Max" version.
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Liked 1,874 Times
recently checked out a pair of Sixsixone Filter flat shoes
the sole is stiff - little bit of flex up front but remainder of the sole is very stiff
the toe box size is reasonable - but shoe feels a tad snug ; the thick / generously padded tongue probably contributes to this feeling
Quoted: 1109 Post(s)
Liked 1,200 Times
I had pretty significant "metatarsalgia" - literally pain in the metatarsal bone. In my case it was specifically the most proximal (closest in) joint of only the second toe on my left foot. The pain felt like there was a pebble in my shoe. It has been in the background for many years, but this year it was becoming worse, causing me to limp, even get fairly lame.
I went to see a podiatrist and he assessed it immediately: "does it feel like there's a pebble in your shoe?" Easy for him to assess and he gave me a VERY simple modification to my insoles which after just a couple of weeks has resolved the problem almost completely. The idea, as I understand it, is to modify the way the foot lands to have the big toe take more pressure and relieve the pressure in the painful toe.
After using this pad for just a few weeks, it now only gives a tiny bit of irritation, hardly "pain", and only when I'm walking barefoot. The photo shows the original insole modification he made in his office (white felt) and one of the many DIY's I've done. Since then, I've modified the insole on every single pair of shoes - casual, dress, athletic, hiking, biking, crocs, clogs and sandals. I've used cut outs from a felt insole I had on hand, approximating the thickness of the material he used. I've also used old cushy insoles I had laying around - see the sandal example. The sandal also shows how I'm dealing with shoes that don't have insoles, like clogs, crocs, etc.
Anyway, this is very simple - all it takes is some sort of thick soft felt or a sacrificed cushy insole cut to shape and applied with double sided tape.
RE: cycling. this guy is a pretty avid cyclist and told me to put the inserts in my cycling shoes which I've done. He also recommended moving my cleats as far back as possible to keep pressure off the ball of the foot. I haven't had a need to do that since cycling has had only a minor irritation for me, and now, with the insert, none.
He also advised me to not walk bare or stocking foot around the house. Since i usually wear crocs or clogs in the house, not a problem for me.
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 911 Times
Since your doctor recommended metatarsal pads, have you tried them? Mine are working wonders. They are fixing a pain point and callus located where the green M&M is:
Metatarsal pads and placement
These ones I got have really good stickum, and have held up well, for a month now.
https://www.amazon.com/dp/B019MAQSTA
I don't know why the illustration shows them stuck to a foot. I suppose you could...
Quoted: 3352 Post(s)
Liked 1,056 Times
There is a 90% chance your problem is caused by your cycling shoes being too narrow. Cycling shoes always seem to be on the narrow side. Get a pair that is clamed to be wide. Worked for me.
Quoted: 200 Post(s)
Liked 65 Times
My metatarsal pain is all gone for one principal reason. I have not been able to cycle because of severe knee pain. It is probably a meniscus problem. Five years ago I had the other knee operated on. I cannot complain however. That knee saved my life. After the knee surgery, I told the nurse that I did not feel well. The next day I had quadruple bypass surgery.
I had the exact same after a ride where I pushed the ball of my foot onto my pedals too hard. This was on a road bike with stiff shoes though. For my MTB rides, I have Specialized Trail Traction shoes, which have stiff soles and are very comfortable.
Since I am running as well, my physio blamed the running though and gave me some foot and toe exercises to strengthen my foot. I was told to stop running up steep hills (which stretches the big toe a lot). Combined with replacing old running shoes more often, putting the cleats as far back as possible on my bike shoes (road and MTB), and focusing on dividing the pressure over the entire width of my foot, it gradually went away (over the course of a year in my case).
I looked into cleat shims a bit to alter the pressure divide, but never actually tried them.
