Over lubricated free wheel
Quoted: 7 Post(s)
Good evening all. New to the forum, just finished building a early 80s road bike, my first attempt at doing so. I am in the process of working through a few issues, but a new one is I was concerned that I did not lubricate my free wheel enough, so I added a bit more. It’s what I guess is medium weight, Phil’s tenacious oil. Now I am noticing that it is no longer making that “ratcheting” sound. Did some research, my guess is the mechanism is “churning through it.” It’s also a little harder to pedal, which supports this theory. Will it seep out and fix itself, or do in need to flush it with wd40 or other solvent, and re-add the appropriate amount of lubricant? What even is the appropriate amount. This is going to be a lot of trial and error. Thank you
Quoted: 1944 Post(s)
Liked 2,164 Times
The rule of thumb I’ve used is to run oil through the freewheel body until it quiets down.
That said, there’s no hub bearings in a freewheel so there is no effect on pedaling whatsoever. As long as the pawls engage the wheel turns.
John
Edit added: If the pawls don’t engage, then you should soak the freewheel body in solvent until the pawls ratchet, let dry, and lube. It is possible for the original grease to have hardened over the years and the solvent should break it down.
I wouldn’t use WD-40.
John
Quoted: 3511 Post(s)
Liked 2,925 Times
Yeah, if your bikes is harder to pedal, it's not because of anything you did to the freewheel. The freewheel has nothing to do with pedaling effort (other than providing different gears).
I'd love it if mine was silent!
Likes For smd4:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Obviously should be posted in 'bicycle mechanics' not in GD.
Sunshine
Quoted: 10960 Post(s)
Liked 7,488 Times
Quoted: 6193 Post(s)
Liked 4,808 Times
There is no need to oil your free hub or freewheel other than to keep enough very light lube on it to prevent corrosion. IMO. The free hub only does anything when you are coasting. So unless you ride downhill all the time and coast, there isn't much opportunity for wear.
Lube will make noisy free hubs and freewheels quieter than they were if used in excess.
Now if you waited till this thing was completely gunked up and rusted from age and then tried lubricating to free it up, then there is no telling what might be going on. Most of the time, that's worked well for me with rusted up freewheels to just spray them with light lubes and solvents or even WD-40. But I wasn't at all worried if the made no noise afterward as long as they allowed me to pedal the bike forward. Coasting is not a big concern!
