I can('t) ride my bike with no handlebars
I have an old Fuji road bike and whenever I let go of the handlebars it veers to the left. It's rather annoying and borders on dangerous when I need my hands for other things. It was brought for a tuneup last year and they didn't mention anything although while biking the other day some guy yelled out his truck at me "You're frame is bent!" The frame looks fine when I inspect it but I'm no expert. Is there something specific I should be looking for that would cause my bike to veer to the left? and what could some guy driving by notice that I can't?
Thanks for any help
--Chris
Thanks for any help
--Chris
Elitist Troglodyte
Bikes: 03 Raleigh Professional (steel)
He probably yelled that because he could see that your wheels weren't tracking together. Yes, your frame is probably bent and you can't always tell by use of the Mk. I Eyeball. Your LBS should have frame alignment equipment. There are also tests you can do yourself. (Don't have the URLs handy...)
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
- Will Rogers
Quoted: 443 Post(s)
Liked 27 Times
Run a string from one dropout around the head tube to the same place on the other dropout. Measure the distance from the string to the seat tube on both sides. It should be the same.
I can't ride my bike with no handlebars either. Its really hard to grab the stem and turn it to make the bike turn.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Bikes: Stella
Giuliano Calore doesn't need handlebars. No stem either. Think how many kilograms he saves (and try to figure out where to mount a cycle-computer, eh?)
He does ok on flat surfaces, too. (as seen a little ways into this Italian broadcast)
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
If your bike would go straight ahead while you do a two-handed blackberry thing, then that would be safe.
Bikes: '85 Univega Safari-Ten (fixed), '84 Univega Supra-Sport, '85 Univega Gran Turismo, '86 Bianch Giro, '93 Cannondale R300, '68 Raleigh Gran-Prix (S3X fixed), '74 Schwinn Sprint (fixed), '5? Raleigh Lenton, '73 Raleigh Sprite, '36 Three Spires... etc.
sounds like my girlfriend's three speed. whenever I'm following her, I can see that her wheels aren't following the same path. And it amounts to the same kind of handling difficulty you mentioned.
Quoted: 2026 Post(s)
Liked 1,095 Times
Other possibly problems are:
The fork is bent
The wheels aren't true
The wheels aren't dished properly, This applies to the front wheel too if it isn't centered correctly.
Bikes: Cinelli Supercoursa 69, Ritchey Breakaway Cross, Mondonico Diamond Extra 05, Coors Light Greg Lemond (built by Scapin) 88, Scapin MTB, Stumpjumper 83, Specialized Stumpjumper M4, Lemond Poprad 2001
Quoted: 8 Post(s)
Take the bike to a good LBS with the tool to straighten out the front fork (if steel). Sounds like the front fork may be out of alignment.
If it is a carbon fork one of the methods mentioned above would probably work to check out the frame alignment.
Another even simpler possibility is that the brake/sti (or ergo) cables might be uneven and working to steer the bike for you. When you hold the bike by the saddle do the handle bars always settle to the left???
