If I convert to bullhorns, do I need new levers?
Fullies & old iron abuser
Hi folks,
I recently picked up a Nishiki Rally and I'm finding a drops a bit odd (I've ridden mountain bikes for the last 20 years or so ).
So I've been looking around and figure that some Nitto Riser might work for me. And I realize I need a 25.4 mm bar (spent some time searching the forum before posting).
What I don't know is, do I need to switch my brake levers? Or will the existing ones work?
Thanks in advance.
Bjorn
Thanks in advance.
Bjorn
you'll need new levers with the nitto risers. With bullhorns you wouldn't necessarily need new ones. Drop bar levers can be reverse mounted on bullhorn bars, but typically won't even fit on risers. The clamp size is smaller for risers.
Just keep pedalling!
Bikes: 1987 Schwinn Circuit, 1987 Panasonic DX-4000, 1984 Peugeot PSV10, 1989 Centurion Prestige, 1973 Raleigh Sprite, 1987 Peugeot Canyon Express, ~1986 Raleigh Capri, 1994 Trek 850, 1984 Centurion Pro Tour 15, 2012 Gravity Zilla
You should try riding on the hoods, it's more comfortable than the drops, and it feels more stable. It would give you the same hand position as bullhorns, without changing a thing.
I've tried a number of different hand positions.
Unfortunately, none of them seem quite comfortable. I'm certain part of that is due to having more weight forward (vs a full suspension mountain bike) part is probably the fact that the bars are much narrower than what I'm used to).
I may try changing the rotation of the drops a bit to see if that helps
I have found that I am most comfortable with the top of the bars level (see below). This also makes the drops a little slanted, which keeps your wrists straighter when you are in them. You might also need a shorter stem.
b_h: Thanks. My brakes look much different (much lower end) and I don't think they'd be as comfortable as they seem to come out much "straighter" from the bars. I'll definitely try tilting the bars up a bit and testing. I think it will be more comfortable
I may take some photos tonight if I still find it bad. Course it could just be a matter of the bike not having broke me in yet
Bjorn
Edit: found an image from the original catalog (my bike is less shiny of course )
Bjorn
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,390 Times
You could try these:
https://www.harborcountrybike.com/Pro...LR1121&click=2
They might just be the most comfortable brake levers ever made.
Bikes: ca.1975 Gitane Interclub - 90's Colnago Master Competition- ca.'84 Merckx Corsa - '77 Groene Leeuw - ca. '78 Guerciotti - ca.1984 L'Express - 1974 Gitane 'Super Olympic' - Peugeot 1981 PXN10 - 1975 Peugeot PR10 -1974 Norta -1974 Peugeot PX10 LE
Joseph
Good suggestions. I actually just got back from a LBS that deals mostly in older bikes.
Picked up some tape and already cut that foam crap off. Now to try my luck at wrapping the bars without making a mess of it
I'll post a photo when I'm done, it might be good for a laugh
Overall it feels better, though I haven't ridden the bike yet.
Looks ok from far away:
Not as good up close. I wasn't sure how to make the ends stick, ended up using a bit of electrical tape.
Bikes: Rocky Mountain
Looks like a decent job - but I think you'd definitely find brake levers with hoods more comfortable, and probably safer. I bet you have trouble braking effectively unless your hands are in the drops.
