For the love of English 3 speeds...
#1626
Bikes: 1968 Raleigh Sports, 1970 Raleigh Twenty
Quoted: 9 Post(s)
Is there any reason to leave the AW hub in 3rd gear (i.e. slack shift cable) when parked or stored? My habit is to leave it in 1st when parked. But I notice if I leave it in 3rd, I sometimes encounter a "stuck shifter" if I try downshifting when stationary. Pushing the bike backwards about a foot "unsticks" it. Is this normal? (Pretty sure I've got Cable Adjustment a' la' Sheldon mastered, but I could be wrong!)
#1627
Bicycle Repair Man !!!
The factory settings for cone lock nuts ranges from 87 in/lbs to 150 in/lb... they need to be very tight.
I leave my SA equipped bikes parked in 3rd to release all the cable / spring tension... if things stick when parked you just have to move the pedals a little.
Likes For Sixty Fiver:
#1628
Cottered Crank
Bikes: 1954 Raleigh Sports 1974 Raleigh Competition 1969 Raleigh Twenty 1964 Raleigh LTD-3
Quoted: 8 Post(s)
Liked 11 Times
87 inch-lbs is 7.25 ft-lbs & 150 inch-bs is 12.5 ft-lbs. My torque wrench only goes down to 10 ft-lbs and I doubt it is very accurate at the low end of the scale.
I've got a pretty educated hand as far as torque values as I'm an electrician who has built quite a few high-voltage switchgears. Everything is torqued inside a switchgear since it is pretty important and copper buswork tends to heat and cool so things that are too tight will actually fatigue and break with expansion/cooling cycles. I rarely, if ever, pull out my torque wrench when working on bicycles or even motorcycles unless it is specific things within the engine. I don't even bother with brake work any more since I've got a pretty good feel where stuff should be. So I've can guesstimate torque values when I remove a fastener as wel as when I am "torquing by feel."
Over-torquing is one of my pet peeves when working on things. I really hate it when I pull a fastener off and look at the threads and they look like a saw-teeth instead of nice even zig-zags -time to replace! People have no idea how easy it is to over-torque and damage threads. All they know is that the fastener got loose so they must not have tightened it enough when really it got loose because they OVER tightened it and damaged the threads... /rant.
#1629
Amesja - I have a torque wrench that I only use on CF bikes... decades of practice teaches you what is and isn't right when it comes to torque and snug plus a 1/4 - 1/2 turn is a good rule of thumb as is using the right wrench and avoiding longer ones and snipes / extensions as these magnify effort.
I have had to remove a few seriously over torqued fittings in my life and it is a pain and conversely, have serviced a lot of wheels where the cone lock nuts were so loose you could spin them off by hand.
I also have a tension meter for wheel building but my hands, fingers, and ears know what proper tension feels like and only pull that out when I am working on out of the ordinary builds or where I am not familiar with a new component.
My step father was a master mechanic and a human torque wrench... he had mad skills.
#1630
Cottered Crank
Quoted: 8 Post(s)
Liked 11 Times
I think if I were working on one of those new-fangled wheels with only 12 or so spokes in them I'd want to use a tension gauge too.
#1631
Quoted: 7346 Post(s)
Liked 2,452 Times
I've never used a torque wrench or tension meter. I'm not against them, but I'm beyond needing one. I've damaged enough things to calibrate my wrists. Interestingly, when I started wrenching, my tendency was to undertighten, not overtighten.
#1632
Cottered Crank
Quoted: 8 Post(s)
Liked 11 Times
For the most part someone with an educated mechanic's touch doesn't need to use one. I've used a torque wrench so many times that I've literally worn them out. A larger switchgear can take up a very large room and can have a thousand or more torqued fasteners in them, every one of which gets painted with a paint-pen across the nut and lockwasher after torquing to show that it has been torqued correctly. After spending hours crawling around inside a gear like a jungle-gym hitting every fastener on the copper bus bars, the standard torque values start to get imprinted directly into your nerve passages.
#1633
Liked 2,452 Times
That's what I was trying to say, but your expression is more complete and eloquent, as usual.
#1634
1976 Raleigh Sprite 3 Speed
Hi All, I just joined recently and thought I would share how this evening I acquired a 1976 (though it looks to more like a '77) Raleigh Sprite 3 Speed 25 inch Frame Mens bike. The cost so far is $20. Unfortunately, the bike was left out all winter long. The old Brooks saddle is ruined, the chain, brakes, and shifter are all dry and sticky, the brakes squeal, there is surface rust, and thus the bikes is in major need of lubricants and a major tune up. I actually wanted to walk away after seeing it but the seller kept lowering the price until they threatened to load into my car regardless of payment (I am not keen on the color, ruined seat, or the amount of work the bike will need, since I have no repair experience yet and will have to take it to my local bike shop, but who am I to say no, per se, when they lowered the price by $100?). On the plus side, it is a tall frame, so I can actually fit properly on it and it is a Raleigh. I will see what the bike guys say...
#1635
Schwinnasaur
Nobody answered my question about seat clamp orientation for classic 3-speed Brooks saddle. See post #1610.
I noticed in looking at pictures posted in the thread that many had post behind the clamp. I think that there is a correct position and it is with the post toward the front of the seat. This gives more springiness and at least for me puts the handlebar closer to the optimal position of the nose being the length from elbow to tips of fingers to front center of handle bars. I know its preference but I think the saddle was designed to have the post toward the nose.
My two cents.
My two cents.
#1636
Liked 2,452 Times
planetirving, we can walk you through any repairs you want to do yourself. Welcome to the group. You've found the right place.
Schwinnsta, my understanding that the traditional way is to have it with the post ahead of the clamp on road bikes but behind the clamp on upright bikes like the three speed. If you don't have it behind the clamp, your weight might exert too much torque on the clamp and force the back of the seat down, leaving you with a nose pointing way up. And having the clamp this way puts your seat farther forward, which we presume the rider to like, because he doesn't want to sit far behind the handlebars.
However, I do it your way. I find I put my saddle all the way back on all my bikes. I'm not sure why, but I'm not happy unless I do. Maybe I have short thighs and long shins. Or something. But it's the way I ride. If I ruin my clamp, I'll replace it. Easy enough.
#1637
Bikes: 1969 Raleigh Sports: The Root Beer Bomber
Just because this photo is so awesomely springy, and I want to post it EVERYWHERE. It's also in the "where did you ride today?" thread.
raleighblossoms by snarkypup, on Flickr
#1638
Bikes: The keepers: 1958 Raleigh Lenton Grand Prix, 1968 Ranger, 1969 Magneet Sprint, 1971 Gitane Tour de France, 1973 Raleigh Tourist, 3 - 1986 Rossins, and a '77 PX-10 frame in process.
Quoted: 221 Post(s)
Liked 237 Times
Interesting thought. Whenever I'm working on my 3-speeds (and now the Lenton) I automatically reach for the Whitworth wrench set. And they tend to work perfectly.
Syke
“No one in this world, so far as I know — and I have searched the records for years, and employed agents to help me — has ever lost money by underestimating the intelligence of the great masses of the plain people. Nor has anyone ever lost public office thereby.”
H.L. Mencken, (1926)
Syke
#1639
Quoted: 221 Post(s)
Liked 237 Times
I'm currently running an AMF Hercules as my lunch time errand runner at work. It was the end result of 35 years of hanging in a damp shed, so you can imagine the appearance when I dragged it out. The chrome currently shines, and while the paint will never look great close up, it still protects the steel nicely and the bike functions perfectly. Remember, these babies were designed to get the mister off to and from work every day, otherwise the wife and kids would be in dire straights. Therefore, if anything they're overbuilt and virtually unbreakable.
Syke
Syke
#1641
Cottered Crank
Quoted: 8 Post(s)
Liked 11 Times
Oh, those chrome fenders look like they are going to be beautiful after a dip.
The other day one my neighbors who is moving threw away an old rubbermaid container (with the top!) that is extra long and will fit nearly half a bike frame inside and a whole fender easily without any of it sticking out like the container I am using now. It'll even fit two wheels at the same time instead of my old one that I needed to have it in crooked and flexing the corners with it inside. Yoink! It came right back to my porch. Score! I'm sure all my neighbors wonder why I always have these big containers of water out back...
This summer I am going to keep my eye out for a kiddie pool...
#1642
Hi Everyone, thanks the words of encouragement. I am feeling adventuresome, maybe I will try to do the work myself (or at least some of it). The Brooks seat is a total loss. The front part broke off and is gone. I found a local craigslist Brooks B72 (off of an old Raleigh from 1968) for $60 in well preserved condition. I know he B66 is more springier (but there are none listed) but does this sound reasonable and is that the seat to go with? Thanks again!
#1643
Liked 2,452 Times
Yes, $60 for a B72 in good condition is good. The B72 is wonderful. I've never tried a B66.
#1644
Cottered Crank
Quoted: 8 Post(s)
Liked 11 Times
I like the B66's springs. Call me an old fart but I really appreciate them on the pothole-strewn streets of chicago.
I wouldn't totally write off that seat though. Parts are available for it and a good shoe cobbler could re-attach the leather to a new front nose. See if you can sell it to someone else who might want to repair it or at least use it for parts.
#1645
That is, the front part of the leather is gone. I would consider salvaging it but the original reviews of these mid 70's bikes was that the stock brooks saddle that came with them was wanting anyhow and not very good for long rides, so any other Brooks saddle would be a big step up.
#1646
Get a new saddle, Planetirving. I kept the original saddle on my '69 Sports. It was horribly uncomfortable, and one day it simply self-destructed. Get a new one, and get one with springs.
Much better on your rear end, looks great on the bike, and will last as long as you need it.
#1647
Well then, the final question is, how much can I do with my limited experience, even with advice (I am handy, just not versed in mechanical repair)? I would ideally like to strip down the bike and clean all the steel, chrome and painted surfaces, as well as lube it up and update the breaks pads, cables, etc, but how much of this can I do with just a wrench and screw driver? Will there be torquing issues and such? I guess I could strip it down, clean it up, and what ever I cannot put back together, take to my local bike shop for installation (My older brother once tried to rebuild the front brakes of his '69 Eldorado Cadillac: he'd still be working on it 33 years later if it had not been for the timely intervention of our neighbor who was a part time mechanic). Of course, if I do go ahead, where to start?
#1648
Liked 2,452 Times
I pick my rear up when going over bumps so I don't need springs in my saddle. I was assuming everyone does this, but I guess not.
#1649
Cottered Crank
Quoted: 8 Post(s)
Liked 11 Times
#1650
Bikes: 2000 Litespeed Classic, 1984 Schwinn LeTour, 1998 Gary Fisher Marlin, 1969 Hercules, 1977 Sekai 5000 Superlite, 1993 Koga-Myata TerraLiner, 2013 Trek Farley.
I finally took my restored Hercules out for spring!
