SRAM X5 RD for 11-speed?
BF's Resident Dumbass
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 792 Post(s)
Liked 1,494 Times
Hi everyone. Can I use an existing SRAM X5 rear derailleur for an 11-speed conversion just by swapping the accompanying X5 nine-speed shifter out for an 11-speed NX? So far as I know, all of these components sgare a 1:1/exact actuation cable pull ratio.
Quoted: 792 Post(s)
Liked 1,494 Times
Thanks! Is there any other indexed shifter that will work, or do I need to go with an altogether different RD/shifter?
Clark W. Griswold
Quoted: 4331 Post(s)
Liked 3,955 Times
You will need the proper rear derailleur and shifter. If it were ten speed you were after you can find a friction shifter and probably make it work but not really with 11 too closely spaced.
Quoted: 713 Post(s)
Liked 796 Times
You could go to 10 speed with your current derailleur and a GX 2x10 shifter. The 2x10 version is Exact actuation and the 11 speed versions are X actuation.
Note that the Max cog size for the X5 rear derailleur is 36t, so not a good option of you are switching to a 1x drivetrain.
Quoted: 792 Post(s)
Liked 1,494 Times
If you want 11 speed SRAM, all of the shifters are X actuation, so you will need an X actuation rear derailleur.
